interruptchain (using 433Mhzforarduino ThermoHygroReceiver AND rf-switch)
could anyone help me getting this together?
I’d like to use the ThermoHygroReceiver from <SensorReceiver.h> (fuzzilogic 433MhzForArduino) and the .enableReceive from the <RCSwitch.h> (rf-switch library) together so i can receive both transmission.
Sadly i could not figure out how to use the <interrupchain.h> to trigger the mySwitch.enableReceive(0) function.
Would be great if anyone could help.
Thanks in advance
For what? What are you trying to receive data from?
RC or RF? Again, for what? What are you trying to receive data from?
You need to post some links. and describe what the project is all about. And some code.
Thanks for reply! Project goal: build an homesecurity / burglar alarm system based on:
  • TP-LINK wrt703n wireless router (with openwrt) (with arduino and usb loudspeaker)
  • arduino nano v3.0 (on wrt703n usb)
  • 433mhz transmitter/receiver (on arduino)
  • several door/window contacts, smoke sensor, ir motion detectors
  • sending email on alarm
  • playing audio on motion detection (dog sounds for burglary prevention)
  • receiving data from weatherstation
  • switching devices/light on/off triggered by alerts or web-interface
depends: Steven Cogswell's SerialCommand.h fuzzylogics 433MhzFor Arduino library AND/OR rf-switch library
i've ordered the following parts:
the arduinos part: receive data from the 433mhz receiver, decode it and send the data to the wrt703n on the serial port. The rf senders all are the old ones that have dipswitches/jumpers for homecode and id. further the arduino shall send switch commands when receive commands on his serial port.
Problem: when i use the fuzzylogic's library only, i can use its interrupchain.h like the following:
InterruptChain::addInterruptCallback(0, RemoteReceiver::interruptHandler);
InterruptChain::addInterruptCallback(0, NewRemoteReceiver::interruptHandler);
InterruptChain::addInterruptCallback(0, SensorReceiver::interruptHandler);
but as far as i know, this library can't handle my door contact senders (can't test it right now, they are still on the way). So i'd like to use the rc-switch library function instead.
