Interrupting a cycle depending on a value given by a sensor
Hello guys! I am a newbie in this world, so please be kind :slight_smile:
We have this program, how we stop "initiere_ciclu_pietoni" if at some time in running, the value of "flex" is above 200?
const int led_verde_pieton = 2;
const int led_rosu_pieton = 3;
const int led_verde_vehicule = 4;
const int led_galben_vehicule = 5;
const int led_rosu_vehicule = 6;
const int led_alb = 8;
const int t_galben = 2000;
const int t_siguranta_1 = 2000;
const int t_siguranta_2 = 2000;
const int t_traversare = 4000;
const int t_intermitent = 400;
unsigned long t_min_ciclu_vehicule = 10000;
unsigned long t_ultimul_ciclu_pietoni = 0;
const int flex = analogRead(0);
  pinMode(led_verde_pieton, OUTPUT);
  pinMode(led_rosu_pieton, OUTPUT);
  pinMode(led_verde_vehicule, OUTPUT);
  pinMode(led_galben_vehicule, OUTPUT);
  pinMode(led_rosu_vehicule, OUTPUT);
  pinMode(led_alb,OUTPUT);
  digitalWrite(led_verde_vehicule, HIGH);
  digitalWrite(led_rosu_pieton, HIGH);
  Serial.print("Valoare flex: ");
  Serial.println(flex, DEC);
  if (flex < 200 && millis() - t_ultimul_ciclu_pietoni < t_min_ciclu_vehicule)
    delay(t_min_ciclu_vehicule - (millis() - t_ultimul_ciclu_pietoni));
    initiere_ciclu_pietoni();
  if (flex < 200 && millis() - t_ultimul_ciclu_pietoni > t_min_ciclu_vehicule)
  void initiere_ciclu_pietoni()
  digitalWrite(led_verde_vehicule, LOW);
  digitalWrite(led_galben_vehicule, HIGH);
  delay(t_galben);
  digitalWrite(led_galben_vehicule, LOW);
  digitalWrite(led_rosu_vehicule, HIGH);
  delay(t_siguranta_1);
  digitalWrite(led_rosu_pieton, LOW);
  digitalWrite(led_verde_pieton, HIGH);
  delay(t_traversare);
  for (int x = 0; x < 5; x = x + 1)
    digitalWrite(led_verde_pieton, LOW);
    delay(t_intermitent);
  delay(t_siguranta_2);
  digitalWrite(led_rosu_vehicule, LOW);
  t_ultimul_ciclu_pietoni = millis();
Thank you very very much!
Well, you can't since "flex" is in another function. Make flex global and then test it's value in the initiere_ciclu_pietoni function.
Your topic was MOVED to its current forum category as it is more suitable than the original
If I counted correctly there are about 18 seconds worth of delays in the initiere_ciclu_pietoni() function. You can check the analog during the initiere_ciclu_pietoni() function but it won't be any more responsive than your shortest delay (400ms) and may take up to 4 seconds to respond. If you want it to immediately stop when the analog is more than 200 then you need to restructure your code to use only millis() calls and a state machine to implement the LED pattern in the initiere_ciclu_pietoni() function.
Besides what @ToddL1962 recommended, remove the declaration of flex from void()
And change this
to this
int flex = analogRead(0); <== not "const"
so it becomes a global variable that you can change and interrogate from everywhere in your sketch
