Interruptions digitalRead iteration
I use interrupt function to fill array with values received from digitalRead.
       attachInterrupt(0, test_func, CHANGE);
    void test_func(){
      if(digitalRead(pin)==HIGH){
          test_array[x]=1;
        } else if(digitalRead(pin)==LOW){
          test_array[x]=0;
         x=x+1;
That problem is that when i print test_array there are values like: 111010 or 1011000. As i understand if i use CHANGE option in attachInterrupt function data sequence should be always 0101010101 without repeating.
Can you post all your code?
How to use this forum
http://snippets-r-us.com/
How fast are these changes arriving?
Depends on if you are keeping up.
int rxPin = 2;
int pulse[360];
int width[360];
int x=0;
int timer;
char found=0;
  Serial.println("Serial initialized");
  attachInterrupt(0, parse_wave, CHANGE);
void loop(){
  if (pulse[x]==0 && width[x] > 500 && width[x] < 800){
    detachInterrupt(0);
    if (x>73){
      for (int i=x-72; i<=x; i++){
       Serial.print(pulse[i]);
    Serial.println(width[x]);
    x=0;
void parse_wave(){
  if(digitalRead(rxPin)==HIGH){
      width[x]=micros()-timer;
      pulse[x]=0;
    } else if(digitalRead(rxPin)==LOW){
      pulse[x]=1;
    x=x+1; timer=micros();
    if (x==360){x=0;}
Changes are arriving quite fast, since it is RF data from radio module.
Edit: May not be bounce, as you have since suggested more info
You are experiencing 'bounce' - where the button contacts trigger the interrupt multiple times.
My method for this is to set a flag on entering the method and unset on exit. You may need to delay on exit fractionally too.
You are also seeing the delay from interrupt -> read, hence the 111010 readings, due to the contact bounce.
Try:
boolean debounce = false;
void test_func() {
  if(debounce)
    return;
  debounce = true;
  //Read pins, do other code, etc.
  debounce = false;
This is really only suitable for button presses - if you're measuring relay contact chatter, you will need to add a low-pass filter to your input.
Note: detachInterrupt() appear to cache interrupts, triggering them all when re-attaching, so may not be worth a try. I did try re-routing attachInterrupt() to a dummy method, but was far simpler to just set a bool until complete.
One interrrupt may be cached. You can clear that.
http://www.gammon.com.au/interrupts
width, pulse and x should be volatile.
How fast? Put a figure on it.
So whats the problem with your CURRENT code. It's total different for the first lot you posted.
Mark
