I’am trying to read 4 IR temp sensors and writing that data to an sdcard, all with an attached interrupt using timerone library.
All this is working great until i try to add my function setupTime(), wich is (from my understanding) just checking if a few things are done right with the RTC.
The problem occurring is that this line of code in the void setup() is never being finished: Timer1.attachInterrupt(priouppgift);
Main loop is just using serial.println the same global values the interrupted function is reading but with a delay.
Any help is greatly appreciated
#include <Arduino.h>
#define SDA_PORT PORTD
#define SDA_PIN 1
#define SCL_PORT PORTD
#define SCL_PIN 0
#include <SoftI2CMaster.h>
//Interrupt
#include <TimerOne.h>
//SD KORT
const int chipSelect = 10;
#include <SPI.h>
#include <SdFat.h>
SdFat sd;
SdFile myLog;
//Time and date
#include <RTClib.h>
#include <Wire.h>
RTC_DS1307 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
//tempsensor adress
int AA1 = 0x5B<<1; //stod 0x5A<<1 innan och i exempel.
int AA2 = 0x5C<<1;
int AA3 = 0x5D<<1;
int AA4 = 0x5E<<1;
//temp values that change in the attached timer.
volatile float celcius1 = 0;
volatile float celcius2 = 0;
volatile float celcius3 = 0;
volatile float celcius4 = 0;
Serial.println("Setup...");
//setupTime(); //<-- this is my terrorist...
setupI2CBus(); //stup i2c bus
setupSDFat(); //setup SDfat
Timer1.initialize(1000000); //slow update rate
Serial.println("initiate timer");
Timer1.attachInterrupt(priouppgift); //start function for reading values and writing to SD card
Serial.println("attach timer");
//prints values
Serial.println(celcius1);
Serial.println(celcius2);
Serial.println(celcius3);
Serial.println(celcius4);
//refresh rate on screen
Serial.println("delay i loop");
// helper functions
void setupI2CBus()
i2c_init(); //Initialise the i2c bus
//PORTC = (1 << PORTC4) | (1 << PORTC5); //enable pullups
Serial.println("satt i2c bus");
void setupTime()
Serial.println("innan time");
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
Serial.println("Time is set");
void setupSDFat()
// Initialize SdFat or print a detailed error message and halt
// Use half speed like the native library.
// change to SPI_FULL_SPEED / SPI_HALF_SPEED for more performance.
if (!sd.begin(chipSelect, SPI_FULL_SPEED)) {
sd.initErrorHalt();
Serial.println("sdfat done");
void priouppgift(void)
//populera med nya tempvärden
celcius1 = readDevice(AA1);
celcius2 = readDevice(AA2);
celcius3 = readDevice(AA3);
celcius4 = readDevice(AA4);
// make a string for assembling the data to log:
String dataString = "";
dataString += String(celcius1);
dataString += ",";
dataString += String(celcius2);
dataString += ",";
dataString += String(celcius3);
dataString += ",";
dataString += String(celcius4);
if (!myLog.open("test.txt", O_RDWR | O_CREAT | O_AT_END)) {
sd.errorHalt("opening test.txt for write failed");
myLog.println(dataString);
myLog.close();
Serial.println(dataString);
float readDevice(int address)
int dev = address << 1;
int data_low = 0;
int data_high = 0;
int pec = 0;
// RAW READ
i2c_start_wait(dev + I2C_WRITE);
i2c_write(0x07);
i2c_rep_start(dev + I2C_READ);
data_low = i2c_read(false); //Read 1 byte and then send ack
data_high = i2c_read(false); //Read 1 byte and then send ack
pec = i2c_read(true);
i2c_stop();
//This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
double tempFactor = 0.02; // 0.02 degrees per LSB (measurement resolution of the MLX90614)
double tempData = 0x0000; // zero out the data
int frac; // data past the decimal point
// This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
tempData = (double)(((data_high & 0x007F) << 8) + data_low);
tempData = (tempData * tempFactor)-0.01;
float temp = tempData - 273.15;
return temp;
A massive waste of resources. Output to an SD card is buffered. Collecting all the data in one memory mangling String object does not make writing to the SD card more efficient or faster. So, why are you doing this?
You are aware that priouppgift() is a interrupt service routine, and that interrupts are disabled while the function is running, aren't you? You know that Serial relies on interrupts to send data, making more room in the outgoing buffer, right? You know what will happen if that buffer gets full, right? So, why are you using Serial.print() in an ISR?
Do you know whether the SD class uses interrupts? If not, why are you using the functions anyway?
I was not aware of the "blink without delay philosophy, so i will absolutely try that.
And thanks for the Example Nick
I went for the interrupt because later on i will try to add a TFT and did want to favor reading values from sensors and writing to SD card instead of updating the graphics. But i will probably be able to that with this blink example.
The reason the String was there was simply because i found it in an example. But i will absolutely remove it as i want this code to be fast.
And i was Not aware of the buffer limits.
I have now tried to narrow it down as much as i can, and make it really simple.
And i still have a problem with RTC and reading i2c sensor.
I have to comment out DS1307RTC.h and associated functions in the below code to be able to read sensor values… i really have no idea why.
#define SDA_PIN 1
#define SCL_PIN 0
#include <TimeLib.h>
#include <Wire.h>
//#include <DS1307RTC.h> // a basic DS1307 library that returns time as a time_t
// setSyncProvider(RTC.get); // the function to get the time from the RTC
i2c_init();
// digitalClockDisplay();
Serial.println(readDevice(0x5B<<1));
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
int data_low = 0;
int data_high = 0;
int pec = 0;
// RAW READ
i2c_write(0x07);
i2c_stop();
return temp;
