Interrupts "Arduino"
Hey Guys,
I´m not a good english student, but i´ll try my best.
I have got a problem with interrupts. --> they work that´s not the problem
The problem is that in my interrupt routine a Serial.println is. When the interrupt trigger the interrupt i get two times the output of it. why?
My attachInterrupt is:
void top()
{ state=1;
  digitalWrite(13, state);
  Serial.println("T");
Please post your complete sketch.
Interrupt routines need to be as short as possible. increment a counter set a flag or so but not somethins as slow as a serial print which uses interrupts. As Arduino is single threaded it cannot handle it.
Solution: set a flag and do the printing in the main loop if the flag is set.
(and your English is fine!)
I have got a Arduino Mega 2560. How do I set a Flag?
int Pin = 2;
volatile int state = LOW;
  pinMode(Pin, INPUT);
  pinMode(ledPin, OUTPUT);
  attachInterrupt(0, top, CHANGE);
  attachInterrupt(1, low, CHANGE);
void top()
{ state=1;
void low()
{ state=0;
  Serial.println("L");
Because attachInterrupt(0, top, CHANGE);
Sure I forgot... you are right ]:slight_smile: RISING
sorry for the question. stupid question. :frowning:
// not tested
int Pin = 2;
volatile boolean stateChanged = false;;
  attachInterrupt(0, top, RISING);
  attachInterrupt(1, low, RISING);
  if (stateChanged)
    staeChanged = false;
    if (state == 1)  Serial.println("T");
    if (state == 0)  Serial.println("L");
void top()
  state=1;
  stateChanged = true;
void low()
  state=0;
