Interrupts are firing when nothing is connected
I have two interrupts using push buttons on pins 2 and 3. They are used to initiate powering On or Off of the project. The issue is both are unresponsive to when I press the buttons but come on randomly when nothing is plugged into the respective pins.
Here is the code:
// these constants won't change:
const int pumpPin = 7;      // pump switch connected to digital pin 7
const int coilPin = 8;      // pump switch connected to digital pin 8
const int waterSensor = A0; // the piezo is connected to analog pin 0
const int threshold = 950;  // threshold value to decide when the detected sound is a water or not
// these variables will change:
int sensorReading = 0;      // variable to store the value read from the water sensor pin
int pumpState = LOW;        // variable used to store the last pump pin status. Helpful for debouncing.
int coilState = LOW;        // variable used to store the last coil pin status. Helpful for debouncing.
int pwmPin = 9;             // Analog pin used to send PWM signal to coil
void setup(void) {
  //enable interrupt 0,1 which uses pin 2,3
  //jump to the increment function on falling edge
  attachInterrupt(0, powerRequest, FALLING);
  attachInterrupt(1, powerDown, FALLING);
  Serial.begin(9600);                       //turn on serial communication
  // read the sensor and store it in the variable sensorReading:
  sensorReading = analogRead(waterSensor);
  float voltage = sensorReading * (5.0 / 1023.0);
  Serial.println(sensorReading);
  Serial.println(voltage);
if (sensorReading < threshold) {
    if((pumpState == HIGH) && (coilState == HIGH)) {
      // toggle the status of the pumpPin and coilPin:
      pumpState = LOW;
      coilState = LOW;
      Serial.println("Water level is low!");     // send the string "Water level is low!"
      digitalWrite(pumpPin, pumpState);       // Turn the pump off
      Serial.println("Pump is off!");         // send the string "Pump is off!"
      digitalWrite(coilPin, coilState);       // Turn the coil off
      Serial.println("Coil is off!");         // send the string "Coil is off!"
      analogWrite(pwmPin, 0);                 // set the PWM off
      Serial.println("PWM is off!");          // send the string "PWM is off!"
    else {
      Serial.println("Not ready for power!");    // send the string "Not ready for power!"
else if (sensorReading >= threshold) {
    if((pumpState == HIGH) && (coilState == HIGH)){
      Serial.println("Water level is good!");    // send the string "Water level is good!"
      digitalWrite(pumpPin, pumpState);       // Turn the pump on
      Serial.println("Pump is on!");          // send the string "Pump is on!"
      digitalWrite(coilPin, coilState);       // Turn the coil on
      Serial.println("Coil is on!");          // send the string "Coil is on!"
      analogWrite(pwmPin, 102);               // set the PWM on
      Serial.println("PWM is on!");           // send the string "PWM is on!"
    else {
      Serial.println("Power when ready!");    // send the string "Power when ready!"
      pumpState = LOW;
      coilState = LOW;
else {
  Serial.println("Water level is low! Catch Error");    // send the string "Water level is low!"
  Serial.println("Not ready for power! Catch Error");    // send the string "Not ready for power!"
delay(2000);
// Interrupt service routine for interrupt 0
  void powerRequest() {
    // Update pins if water tank empty
    if (sensorReading < threshold){          // Water level is low
      pumpState = LOW;
      coilState = LOW;
    else if(sensorReading >= threshold){
      pumpState = HIGH;
      coilState = HIGH;
    // Else update pins if water level is good
    else {                                    // Water level is good
      pumpState = LOW;
      coilState = LOW;
// Interrupt service routine for interrupt 1
  void powerDown() {
  pumpState = LOW;
  coilState = LOW;
These MUST be volatile, since they are used by the ISRs AND by loop().
The internal pullup resistors for pins 2 and 3 are not enabled, so you have external resistors connected to the pins and ground or 5V, to prevent floating pins, right?
I did not connect any external resistors to pins 2 or 3. I just had two buttons to ground. So you are saying I should change the code to be:
const int powerRequestPin = 2;    // pump switch connected to digital pin 2
const int powerDownPin = 3;       // pump switch connected to digital pin 3
const int waterSensor = A0;       // the water sensor is connected to analog pin 0
const int threshold = 950;        // threshold value to decide when water is detected or not
//***********************added**********************************
volatile int pumpState = LOW;     // variable used to store the last pump pin status.
volatile int coilState = LOW;     // variable used to store the last coil pin status.
void setup(void) {
  pinMode(powerRequestPin,INPUT);
  pinMode(powerDownPin,INPUT);
  digitalWrite(powerRequestPin, HIGH);
  digitalWrite(powerDownPin, HIGH);
      pumpState = LOW;
      coilState = LOW;
    else {
    else {
      pumpState = LOW;
      coilState = LOW;
else {
delay(2000);
      pumpState = LOW;
      coilState = LOW;
      pumpState = HIGH;
      coilState = HIGH;
      pumpState = LOW;
      coilState = LOW;
  void powerDown() {
  pumpState = LOW;
  coilState = LOW;
I put // ******** to block off the changed code. Is this what you were suggesting?
Yes, and you need something connecting the pins to a known voltage. If the pin is unconnected, or worse yet connected only to a button that isn't closed, then the pin is floating and will fire your interrupt anytime it picks up a little stray signal.
http://www.gammon.com.au/switches
