Interrupts dont work anymore
I am using an Arduino duemilanove I may have fried the ATmega by connecting it to a low current, high voltage. My program stopped detecting interrupts after this. Now, not even the basic sample interrupt program works. So I replaced the ATmega with a brand new one and it also doesn't detect interrupts. What could be wrong? Thanks in advance.
edit: I've also tried using both pins (0,1).
Pins 0 and 1 are used for serial communication. Are you trying to detect interrupts on these pins?? If not, which pins are you trying to detect interrupts on?
-- Check out our new shield: http://www.ruggedcircuits.com/html/gadget_shield.html
I thought interrupts could only be detected on pins 0 and 1? Ive only tried these two.
Nah, leave those pins alone. They're used for communicating with the PC.
Have a look at the sample code library for some interrupt samples on other pins:
http://www.arduino.cc/playground/Main/GeneralCodeLibrary
And no more hooking up high voltage sources to your board! ;)
That can't be right. Ive used pins 0 and 1 with no problem before.
"Most Arduino boards have two external interrupts: numbers 0 (on digital pin 2) and 1 (on digital pin 3). The Arduino Mega has an additional four: numbers 2 (pin 21), 3 (pin 20), 4 (pin 19), and 5 (pin 18). "
http://arduino.cc/en/Reference/AttachInterrupt
I dont understand why, even after replacing the processor with a new one, it still doesnt work.
ughgh you know what? Ive been using pins 0 and 1 when I should be using pins 2 or 3. Its confusing because the attachInterrupt function labels pin 2 as '0'.
attachInterrupt(0, blink, CHANGE);
Anyway, thanks for helping.
Yea, it's not real intuitive is it, and I'm sure your not the first to get tripped up by that. They probably should have written the function to use 2 and 3 instead of 0 and 1, but now several years gone by, too many old sketches would not work if re-compiled if they changed at this late date.
Lefty
