Interrupts getting ignored
Hello friends, recently I wrote few days back
#include <EEPROM.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS3231 rtc;
int chiran = 0;
int anchi = 0;
boolean ang = true;
boolean star = true;
int address = 0;
int yogesh = 0;
int yog = 0;
int nil;
//Debouncing Time in Milliseconds
long debouncing_time = 400;
volatile unsigned long last_micros;
void inc()
  chiran ++;
  EEPROM.write(address,chiran);
  ang = false;
void dec()
  chiran --;
  ang = false;
void ANG()
  if((long)(micros() - last_micros) >= debouncing_time * 1000)
    inc();
    last_micros = micros();
void CHI()
    dec();
void setup ()
 pinMode(9, OUTPUT);
  if (! rtc.begin())
    Serial.println("Couldn't find RTC");
    while (1);
  attachInterrupt(digitalPinToInterrupt(2), ANG, RISING);
  attachInterrupt(digitalPinToInterrupt(3), CHI, RISING);
void loop ()
 DateTime now = rtc.now();
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.print("EEPROM:");
    Serial.println(EEPROM.read(address));
    Serial.print("chiran:");
    Serial.println(chiran);
    Serial.print("ang:");
    Serial.println(ang);
     if(star == true)
    Serial.println("Motor ON time update ENABLED");
     nil = now.hour();
     nil = nil + 1;
     yogesh = now.minute();
     Serial.print("star: False & Motor Will be ON at:");
     Serial.print(nil);
     Serial.print(":");
     Serial.println(yogesh);
     star = false;
     if(nil == now.hour()&& yogesh == now.minute())
      Serial.println("Motor ON");
      digitalWrite(9, HIGH);
      ang = false;
      nil = 25;//enter the value which will never occur
      yogesh = 61;//value for minnute which will never occur
       if (ang == false)
      Serial.println("Motor ON time Updtae EnABLED");
      Serial.println("Updating ANCHI");
      yog = now.hour();
      anchi = now.minute();
      anchi = anchi + EEPROM.read(address);
      Serial.print("MOTOr will be OFF at:");
      Serial.println(anchi);
      ang = true;
    if (anchi == now.minute())
        Serial.println("Mtr OFF");
        digitalWrite(9, LOW);
        anchi = 61;
        star = true;
       if (star == true)
          Serial.println("Motor ON time update DISABLED");
          if (ang == false)
            Serial.println("Motor OFF time Update ENABLED");
            Serial.println("Motor OFF time update DISABLED");
    delay(3000);
My problem is that once the pin 9 goes HIGH the interrupts are just ignored and nothing happens even when the interrupt occurs.
I have connected to reset switches on each of the interrupts triggered as rising. Any help!!!
Thanks in advance
Variables which are updated in a call chain from an interrupt service routine should be declared as volatile e.g. chiran .
I did that too but it still doesn't work
Have you a pull down resistor (say 10K) on pins 2 & 3 ? You changed both ang and chiran to volatile ? What board / processor have you and what is connected to pins 2 & 3 ?
I have those pull down resistors exactly 10K. I am using Arduino UNO. Strange thing is that Interrupts are detected when the PIN 9 is LOW, But once it goes HIGH interrupts are just ignored. Sometimes the if loop turning pin 9 HIGH not even execute even if its condition becomes true.
The Arduino is failing when you switch the motor on?
I guess that points to a power problem.
Do you have a proper power supply for the motor?
Right now I have just connected a LED on pin 9. I haven't connected any ext power the arduino is powered with USB only
Then this question:
If the device generating the interrupt is not giving a sharp enough rise, you could use a pin change interrupt instead.
And maybe comment out ang here :
  if (nil == now.hour() && yogesh == now.minute())
    // ang = false;
because I guess you are assuming that an interrupt has not worked based indirectly on the value of ang.
Why are you doing this multiplication in your ISR
just change debouncing_time from 400 to 400000 or do the calculation once in setup()
...R
But then wouldn't the interrupt occurring twice in a single key press. Major problem is that I have to wait for complete one hour to see if the program works or not. and now you would say that I should test it for minutes. So another strange thing is the program works fine when I test it for minutes like comparing minutes from the RTC. It even works great when I manually assign the values to variable rather than getting it from the RTC. but when I get the values from RTC like hours and minutes the problem starts
OK. You are using an RTC to generate an interrupt.
Have a look at this to see if it matches your problem:
http://forum.arduino.cc/index.php?topic=342672.0
6v6gt: Then this question: If the device generating the interrupt is not giving a sharp enough rise, you could use a pin change interrupt instead.
    // ang = false;
    // ang = false;
I have kept this command bcoz I want the if loop that sets motor OFF time to be enabled only after the pin 9 goes high. If I am wrong implementing that please tell me how do I correct it
6v6gt: OK. You are using an RTC to generate an interrupt.
No I am not using RTC to generate Interrupt I just fetch time from it add decimal 2 to it and then compare it with current time and when the current time and that is equal it turns pin 9 high. I do this bcoz I want to make pin 9 HIGH after every two hrs.
[/quote]
Robin2: Why are you doing this multiplication in your ISR
...R
How do I do that can you guide me please
OK. For the third time:
Then this question:
Also: how are you determining that an interrupt has not been detected ?
Ignore the last test code change I gave you and temporarily replace your loop with this which will determine if interrupts are working or not or maybe point to a logic error in your code.
void loop ()
  if (ang == false )
    Serial.println("Interrupt detected");
    ang = true ;
Count:
Just change
to
long debouncing_time = 400000;
To be honest, if you can’t figure that out without my help you are probably too inexperienced to be using interrupts. Spend some more time learning the basics.
…R
Robin2: Just change
to
To be honest, if you can't figure that out without my help you are probably too inexperienced to be using interrupts. Spend some more time learning the basics.
...R
Thanks robin2 for your reply I know I need to learn alot more. But I was asking about how to make those calculations in setup.
6v6gt: OK. For the third time:
Then this question: Also: how are you determining that an interrupt has not been detected ?
void loop ()
  if (ang == false )   {     Serial.println("Interrupt detected");     ang = true ;   }
Two reset switches are connected to pin 2 and 3 when pressed it gives HIGH to these pins. I press them manually.
After I use the code that you gave to me, in serial monitor I can see " Interrupt is detected" every time I press any of the two switches. Is it what is expected to happen?
Count: Two reset switches are connected to pin 2 and 3 when pressed it gives HIGH to these pins. I press them manually.
OK. That would all imply that interrupts are indeed being detected and the interrupt service routines correctly triggered.
Your post is entitled "Interrupts getting ignored". What is not happening in your sketch which you believe should happen ? In other words, how have you concluded that interrupts are being ignored ?
Count: Thanks robin2 for your reply I know I need to learn alot more. But I was asking about how to make those calculations in setup.
That is straightforward also - something like
debouncing_time_millis = debouncing_time * 1000;
...R
