i try to learn how thinks work, and how i can continue and finalize my project, with lot of reading and playing with the codes i manage to make a code to send midi from pins A2 -A3 it work SUPER fine if i upload it to Arduino alone.
problem is when i adopt my code to the big code (second code i post) is not working good, is working only when encoder turn CW and very rare when encoder turn CCW.
so i assume that some how with interrupt i i will pause the big code and all MCU power will go to read my enoder, when encoder stop working code will run again.
if i manage this i will add one more encoder on PINS A4 - A5 . and code finish..
i need to mension that traktorino code is not mine, i didnt write it, i try to modify it, and i have never know how to write codes, but is fun,, with out to know the slitest think i am in a good way
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
#include <Encoder.h>
Encoder browserEnc(A2, A3);
long positionBrowser = -10;
Serial.begin(115200); //31250
MIDI.begin(MIDI_CHANNEL_OMNI);
void readBrowserEnc() {
int newpositionBrowser = browserEnc.read();
int BrowserVal = map(newpositionBrowser, -1023, 1023, -255, 255);
int BrowserValue;
if (BrowserVal != positionBrowser) {
if ((BrowserVal - positionBrowser) > 0) {
BrowserValue = 127;
else {
BrowserValue = 1;
//Serial.println(newPosition);
MIDI.sendControlChange(15, BrowserValue, 1);
positionBrowser = BrowserVal;
MIDI.read();
// readButtons();
readBrowserEnc();
// readLoopLEnc();
// readLoopREnc();
// readPots();
/* Traktorino
The Traktorino is a low-cost DIY MIDI controller for DJs, based in the Arduino platform.
It can control any software that accepts MIDI, like Traktor, Serato, or even Ableton Live.
The Traktorino is completely open-source, which means you can download the code and all the schematics, so you can make one yourself!
And if you want to build this controller, you can buy the kit from us, this way, you will be helping more projects like this to happen!
http://www.musiconerd.com/shop >> buy a Traktorino kit
http://www.musiconerd.com/traktorino >> learn more about the Traktorino
http://github.com/silveirago/traktorino >> Download the traktorino files
gustavosilveira@musiconerd.com >> Send me a message if you have any doubt
// PWM bit shifter
// You can choose the latch pin yourself.
const int ShiftPWM_latchPin = 8;
// ** uncomment this part to NOT use the SPI port and change the pin numbers. This is 2.5x slower **
#define SHIFTPWM_NOSPI
const int ShiftPWM_dataPin = 11;
const int ShiftPWM_clockPin = 12;
// If your LED's turn on if the pin is low, set this to true, otherwise set it to false.
const bool ShiftPWM_invertOutputs = false;
// You can enable the option below to shift the PWM phase of each shift register by 8 compared to the previous.
// This will slightly increase the interrupt load, but will prevent all PWM signals from becoming high at the same time.
// This will be a bit easier on your power supply, because the current peaks are distributed.
const bool ShiftPWM_balanceLoad = false;
// LIBRARIES
#include <ShiftPWM.h> // Bit shifter library >> https://github.com/elcojacobs/ShiftPWM - include ShiftPWM.h after setting the pins!
// If using with ATmega328 - Uno, Mega, Nano...
#include <MIDI.h> // MIDI library (by Forty Seven Effects) >> https://github.com/FortySevenEffects/arduino_midi_library/releases/tag/4.3.1
#include <Multiplexer4067.h> // Multiplexer CD4067 library >> https://github.com/sumotoy/Multiplexer4067
#include <Thread.h> // Threads library (by Ivan seidel) >> https://github.com/ivanseidel/ArduinoThread
#include <ThreadController.h>
#include <Encoder.h> // Encoder library >> https://github.com/PaulStoffregen/Encoder
// buttons
const byte muxNButtons = 13; // *coloque aqui o numero de entradas digitais utilizadas no multiplexer
const byte NButtons = 1; // *coloque aqui o numero de entradas digitais utilizadas
const byte totalButtons = muxNButtons + NButtons;
const byte muxButtonPin[muxNButtons] = {0, 1, 2, 3, 4, 5, 9, 10, 11, 12, 13, 14, 15}; // *neste array coloque na ordem desejada os pinos das portas digitais utilizadas
const byte buttonPin[NButtons] = {9}; // *neste array coloque na ordem desejada os pinos das portas digitais utilizadas
int buttonCState[totalButtons] = {0}; // estado atual da porta digital
int buttonPState[totalButtons] = {0}; // estado previo da porta digital
// debounce
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 5; // the debounce time; increase if the output flickers
// potentiometers
const byte NPots = 14; // *coloque aqui o numero de entradas analogicas utilizadas
const byte muxPotPin[NPots] = {0, 1,}; // *neste array coloque na ordem desejada os pinos das portas analogicas, ou mux channel, utilizadas
int potCState[NPots] = {0}; // estado atual da porta analogica
int potPState[NPots] = {0}; // estado previo da porta analogica
int potVar = 0; // variacao entre o valor do estado previo e o atual da porta analogica
int lastCcValue[NPots] = {0};
// pot reading
int TIMEOUT = 50; //quantidade de tempo em que o potenciometro sera lido apos ultrapassar o varThreshold
byte varThreshold = 8; //threshold para a variacao no sinal do potenciometro
boolean potMoving = true; // se o potenciometro esta se movendo
unsigned long pTime[NPots] = {0}; // tempo armazenado anteriormente
unsigned long timer[NPots] = {0}; // armazena o tempo que passou desde que o timer foi zerado
// encoder
Encoder myEnc(3, 2);
long oldPosition = -10;
long positionBrowser = -999;
// midi
byte midiCh = 1; // *Canal midi a ser utilizado
byte note = 36; // *Nota mais grave que sera utilizada
byte cc = 1; // *CC mais baixo que sera utilizado
int ccLastValue = 0;
// Leds
const byte ledNum = 24; // total number of leds used
unsigned char maxBrightness = 255;
unsigned char pwmFrequency = 75;
unsigned int numRegisters = 3;
unsigned int numOutputs = numRegisters * 8;
unsigned int numRGBLeds = numRegisters * 8 / 3;
unsigned int fadingMode = 0; //start with all LED's off.
unsigned int VuL[7] = {1, 2, 3, 4, 5, 6, 7}; // VU left pins
unsigned int VuR[7] = {15, 14, 13, 12, 11, 10, 9}; // VU righ pins
unsigned int buttonsLedL[5] = {20, 19, 18, 17, 16};
unsigned int buttonsLedR[5] = {8, 0, 23, 22, 21};
unsigned int red = 180;
unsigned int green = 255;
unsigned int blue = 10;
unsigned int yellow = 100;
byte ledOnOffPin = 10; //On Off pin
// Multiplexer
Multiplexer4067 mplexPots = Multiplexer4067(4, 5, 6, 7, A0);
Multiplexer4067 mplexButtons = Multiplexer4067(4, 5, 6, 7, A1);
// threads - programa cada atividade do Arduino para acontecer em um determinado tempo
ThreadController cpu; //thread master, onde as outras vao ser adicionadas
Thread threadReadPots; // thread para controlar os pots
Thread threadReadButtons; // thread para controlar os botoes
Serial.begin(115200); // 115200 for hairless - 31250 for MOCO lufa
MIDI.turnThruOff();
//MIDI.begin(MIDI_CHANNEL_OMNI);
// Midi in
MIDI.setHandleControlChange(handleControlChange);
MIDI.setHandleNoteOn(handleNoteOn);
MIDI.setHandleNoteOff(handleNoteOff);
// Multiplexers
mplexPots.begin(); // inicializa o multiplexer
mplexButtons.begin(); // inicializa o multiplexer
pinMode(A1, INPUT_PULLUP); // Buttons need input pull up
// buttons on Arduino Digital pins
for (int i = 0; i < NButtons; i++) { // buttons on Digital pin
pinMode(buttonPin[i], INPUT_PULLUP);
// Leds
// leds.setBitCount(ledNum); // Mux Leds
// leds.setPins(clockPin, dataPin, latchPin);
pinMode(ledOnOffPin, OUTPUT);
// Sets the number of 8-bit registers that are used.
ShiftPWM.SetAmountOfRegisters(numRegisters);
ShiftPWM.SetAll(0);
// SetPinGrouping allows flexibility in LED setup.
// If your LED's are connected like this: RRRRGGGGBBBBRRRRGGGGBBBB, use SetPinGrouping(4).
ShiftPWM.SetPinGrouping(1); //This is the default, but I added here to demonstrate how to use the funtion
ShiftPWM.Start(pwmFrequency, maxBrightness);
// threads
// pots
threadReadPots.setInterval(10);
threadReadPots.onRun(readPots);
cpu.add(&threadReadPots);
// buttons
threadReadButtons.setInterval(20);
threadReadButtons.onRun(readButtons);
cpu.add(&threadReadButtons);
//leds
analogWrite(ledOnOffPin, 255); // on/off led
// for (int i = 0; i < ledNum; i++) { // writeBit works just like digitalWrite
// ShiftPWM.SetOne(i, LOW);
cpu.run();
MIDI.read();
readEncoder();
readBrowserEnc();
// read buttons
void readButtons() {
for (int i = 0; i < muxNButtons; i++) { //reads buttons on mux
int buttonReading = mplexButtons.readChannel(muxButtonPin[i]);
//buttonCState[i] = map(mplex.readChannel(muxButtonPin[i]), 22, 1023, 0, 2); // stores on buttonCState
if (buttonReading > 100) {
buttonCState[i] = HIGH;
else {
buttonCState[i] = LOW;
//Serial.print(buttonCState[i]); Serial.print(" ");
//Serial.println();
for (int i = 0; i < NButtons; i++) { //read buttons on Arduino
buttonCState[i + muxNButtons] = digitalRead(buttonPin[i]); // stores in the rest of buttonCState
for (int i = 0; i < totalButtons; i++) {
if ((millis() - lastDebounceTime) > debounceDelay) {
if (buttonCState[i] != buttonPState[i]) {
lastDebounceTime = millis();
if (buttonCState[i] == LOW) {
// noteOn(potMidiCh(), note + i, 127); // Channel 0, middle C, normal velocity
// MidiUSB.flush();
MIDI.sendNoteOn(note + i, 127, midiCh); // envia NoteOn(nota, velocity, canal midi)
//Serial.print("Note: "); Serial.print(note + i); Serial.println(" On");
buttonPState[i] = buttonCState[i];
else {
// noteOn(potMidiCh(), note + i, 0); // Channel 0, middle C, normal velocity
// MidiUSB.flush();
MIDI.sendNoteOn(note + i, 0, midiCh);
//Serial.print("Note: "); Serial.print(note + i); Serial.println(" Off");
//read potentiometers
void readPots() {
for (int i = 0; i < NPots; i++) { // le todas entradas analogicas utilizadas, menos a dedicada a troca do canal midi
potCState[i] = mplexPots.readChannel(muxPotPin[i]);
potVar = abs(potCState[i] - potPState[i]); // calcula a variacao da porta analogica
if (potVar >= varThreshold) { //sets a threshold for the variance in the pot state, if it varies more than x it sends the cc message
pTime[i] = millis(); // armazena o tempo previo
timer[i] = millis() - pTime[i]; // reseta o timer
if (timer[i] < TIMEOUT) { // se o timer for menor que o tempo maximo permitido significa que o potenciometro ainda esta se movendo
potMoving = true;
else {
potMoving = false;
if (potMoving == true) { // se o potenciometro ainda esta se movendo, mande o control change
int ccValue = map(potCState[i], 0, 1023, 0, 127);
if (lastCcValue[i] != ccValue) {
// controlChange(11, cc + i, ccValue); // manda control change (channel, CC, value)
// MidiUSB.flush();
MIDI.sendControlChange(cc + i, map(potCState[i], 0, 1023, 0, 127), 11); // envia Control Change (numero do CC, valor do CC, canal midi)
//Serial.print("CC: "); Serial.print(cc + i); Serial.print(" value:"); Serial.println(map(potCState[i], 0, 1023, 0, 127));
potPState[i] = potCState[i]; // armazena a leitura atual do potenciometro para comparar com a proxima
lastCcValue[i] = ccValue;
//// read encoder
void readEncoder () {
int newPosition = myEnc.read();
int encoderVal = map(newPosition, -1024, 1024, -256, 256);
int encoderValue;
if (encoderVal != oldPosition) {
if ((encoderVal - oldPosition) > 0) {
encoderValue = 127;
else {
encoderValue = 1;
MIDI.sendControlChange(14, encoderValue, 1);
oldPosition = encoderVal;
int BrowserValue;
BrowserValue = 127;
else {
BrowserValue = 1;
delay(10);
// led feedback
void handleControlChange(byte channel, byte number, byte value) {
//handleControlChange
//int value_ = round(map(value, 0, 127, 0, 7));
int value_ = value;
if (value_ != ccLastValue) {
// Left VU
if (number == 12) {
switch (value_) {
case 0:
for (int i = 0; i < 7; i++) {
ShiftPWM.SetOne(VuL[i], LOW);
case 1:
for (int i = 1; i < 7; i++) {
ShiftPWM.SetOne(VuL[0], green);
case 2:
for (int i = 2; i < 7; i++) {
for (int i = 0; i < 2; i++) {
ShiftPWM.SetOne(VuL[i], green);
case 3:
for (int i = 3; i < 7; i++) {
for (int i = 0; i < 3; i++) {
case 4:
for (int i = 4; i < 7; i++) {
for (int i = 0; i < 4; i++) {
case 5:
for (int i = 5; i < 7; i++) {
for (int i = 0; i < 5; i++) {
case 6:
for (int i = 6; i < 7; i++) {
ShiftPWM.SetOne(VuL[5], yellow);
case 7:
ShiftPWM.SetOne(VuL[6], red);
// Right VU
if (number == 13) {
switch (value_) {
case 0:
ShiftPWM.SetOne(VuR[i], LOW);
case 1:
ShiftPWM.SetOne(VuR[0], green);
case 2:
ShiftPWM.SetOne(VuR[i], green);
case 3:
case 4:
case 5:
case 6:
ShiftPWM.SetOne(VuR[5], yellow);
case 7:
ShiftPWM.SetOne(VuR[6], red);
ccLastValue = value;
void handleNoteOn(byte channel, byte number, byte value)
switch (number) {
// Left buttons
case 40: //sync
ShiftPWM.SetOne(buttonsLedL[0], blue);
case 39: //cue
ShiftPWM.SetOne(buttonsLedL[1], blue);
case 38: //play
ShiftPWM.SetOne(buttonsLedL[2], blue);
case 37: //phones
ShiftPWM.SetOne(buttonsLedL[3], blue);
case 36: //filter on
ShiftPWM.SetOne(buttonsLedL[4], blue);
// Righ buttons
case 44: //sync
ShiftPWM.SetOne(buttonsLedR[0], blue);
case 45: //cue
ShiftPWM.SetOne(buttonsLedR[1], blue);
case 46: //play
ShiftPWM.SetOne(buttonsLedR[2], blue);
case 47: //phones
ShiftPWM.SetOne(buttonsLedR[3], blue);
case 48: //filter on
ShiftPWM.SetOne(buttonsLedR[4], blue);
void handleNoteOff(byte channel, byte number, byte value) {
switch (number) {
// Left buttons
case 40: //sync
ShiftPWM.SetOne(buttonsLedL[0], LOW);
case 39: //cue
ShiftPWM.SetOne(buttonsLedL[1], LOW);
case 38: //play
ShiftPWM.SetOne(buttonsLedL[2], LOW);
case 37: //phones
ShiftPWM.SetOne(buttonsLedL[3], LOW);
ShiftPWM.SetOne(buttonsLedL[4], LOW);
// Righ buttons
case 44: //sync
ShiftPWM.SetOne(buttonsLedR[0], LOW);
case 45: //cue
ShiftPWM.SetOne(buttonsLedR[1], LOW);
case 46: //play
ShiftPWM.SetOne(buttonsLedR[2], LOW);
case 47: //phones
ShiftPWM.SetOne(buttonsLedR[3], LOW);
ShiftPWM.SetOne(buttonsLedR[4], LOW);
buttons midi order
40 44 - sync
39 45 - cue
38 46 - play
37 47 - phones
36 48 - filter
VU order
7 9
6 10
5 11
4 12
3 13
2 14
1 15
