Hey,
i'm building a weather station which includes:
windspeed (interrupt counting)
winddirection (Analog input voltage measurement)
temp and humidity (dht11)
All of the data is written to my thingspeak channel to plot it.
The general setup is working fine but i noticed that the winddirection measurements are jumping up and down, so i included smoothing (12 measurements in a minute) for the analog input. To get this to work i had to change all my delays to millis() to get an analog reading every 5 seconds and to update all the other readings every minute to the thingspeak channel. Now the function to count my interrupts is not working anymore. I can't count any interrupts. I tried to get information from several older threads in this forum bit i couldn't work out a solution for my problem and i don't understand why using interrupts and millis seems to be a problem.
Maybe someone can explain what my problem is and how to fix it, thanks in advance.
#include "DHT.h"
#include "ThingSpeak.h"
#include <WiFiNINA.h>
#define WIFI_SSID "XXXXXX"
#define WIFI_PASSWORD "XXXXXX"
WiFiClient client;
unsigned long aufnahmeStartMillis;
unsigned long fahneStartMillis;
unsigned long currentMillis;
const unsigned long aufnahmePeriod = 60000;
const unsigned long fahneAveragePeriod = 5000;
const int numReadings = 12;
int readings[numReadings];
int readIndex = 0;
int total = 0;
int average = 0;
int windDirectionVoltage = 0;
int inputPin = A0;
unsigned long seconds = 1000L;
unsigned long minutes = seconds * 60;
unsigned long aufnahmezeit = minutes;
const byte interruptPin = 2;
int InterruptCounter;
float WindSpeed;
char* windDirection;
float humid;
float temp;
char thingSpeakAddress = "api.thingspeak.com";
unsigned long myChannelNumber = "XXXXX";
const char * myWriteAPIKey = "XXXXXXXXX";
#define DHTPIN 4
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
String myStatus = "";
int number = 0;
int windDegrees = 0;
dht.begin();
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("connecting...");
Serial.print(".");
Serial.print("connected: ");
ThingSpeak.begin(client);
aufnahmeStartMillis = millis();
fahneStartMillis = millis();
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
currentMillis = millis();
messung();
windrichtung();
void windrichtung() {
if (currentMillis - fahneStartMillis >= fahneAveragePeriod)
total = total - readings[readIndex];
readings[readIndex] = analogRead(inputPin);
total = total + readings[readIndex];
readIndex = readIndex + 1;
if (readIndex >= numReadings) {
readIndex = 0;
windDirectionVoltage = total / numReadings;
Serial.print("WindDirectionVoltage: ");
Serial.println(windDirectionVoltage);
fahneStartMillis = currentMillis;
void messung() {
InterruptCounter = 0;
attachInterrupt(digitalPinToInterrupt(interruptPin), count, RISING);
if (currentMillis - aufnahmeStartMillis >= aufnahmePeriod) {
detachInterrupt(digitalPinToInterrupt(interruptPin));
if (windDirectionVoltage >= 212 && windDirectionVoltage < 273) {
windDirection = "N";
else if (windDirectionVoltage >= 577 && windDirectionVoltage < 665) {
windDirection = "NNE";
else if (windDirectionVoltage >= 483 && windDirectionVoltage < 577) {
windDirection = "NE";
else if (windDirectionVoltage >= 929 && windDirectionVoltage < 943) {
windDirection = "ENE";
else if (windDirectionVoltage >= 906 && windDirectionVoltage < 929) {
windDirection = "E";
else if (windDirectionVoltage >= 943 && windDirectionVoltage < 1023) {
windDirection = "ESE";
else if (windDirectionVoltage >= 795 && windDirectionVoltage < 858) {
windDirection = "SE";
else if (windDirectionVoltage >= 858 && windDirectionVoltage < 906) {
windDirection = "SSE";
else if (windDirectionVoltage >= 665 && windDirectionVoltage < 748) {
windDirection = "S";
else if (windDirectionVoltage >= 748 && windDirectionVoltage < 795) {
windDirection = "SSW";
else if (windDirectionVoltage >= 348 && windDirectionVoltage < 399) {
windDirection = "SW";
else if (windDirectionVoltage >= 399 && windDirectionVoltage < 483) {
windDirection = "WSW";
else if (windDirectionVoltage >= 0 && windDirectionVoltage < 106) {
windDirection = "W";
else if (windDirectionVoltage >= 163 && windDirectionVoltage < 212) {
windDirection = "WNW";
else if (windDirectionVoltage >= 106 && windDirectionVoltage < 163) {
windDirection = "NW";
else if (windDirectionVoltage >= 273 && windDirectionVoltage < 348) {
windDirection = "NNW";
if (windDirection == "N") {
windDegrees = 360;
else if (windDirection == "NNE") {
windDegrees = 22;
else if (windDirection == "NE") {
windDegrees = 45;
else if (windDirection == "ENE") {
windDegrees = 68;
else if (windDirection == "E") {
windDegrees = 90;
else if (windDirection == "ESE") {
windDegrees = 112;
else if (windDirection == "SE") {
windDegrees = 135;
else if (windDirection == "SSE") {
windDegrees = 158;
else if (windDirection == "S") {
windDegrees = 180;
else if (windDirection == "SSW") {
windDegrees = 202;
else if (windDirection == "SW") {
windDegrees = 225;
else if (windDirection == "WSW") {
windDegrees = 248;
else if (windDirection == "W") {
windDegrees = 270;
else if (windDirection == "WNW") {
windDegrees = 292;
else if (windDirection == "NW") {
windDegrees = 315;
else if (windDirection == "NNW") {
windDegrees = 338;
humid = dht.readHumidity();
temp = dht.readTemperature();
WindSpeed = (float(InterruptCounter) / (float(60)) * 2.4);
Serial.print("Umdrehungen: ");
Serial.println(InterruptCounter);
Serial.print("WindSpeed: ");
Serial.print(WindSpeed);
Serial.print("km/h / ");
Serial.print(WindSpeed / 3.6);
Serial.println("m/s" );
Serial.print("Windrichtung: ");
Serial.println(windDirection);
Serial.print("Humidity: ");
Serial.println(humid);
Serial.print("Temperature: ");
Serial.println(temp);
// set the fields with the values
ThingSpeak.setField(1, WindSpeed);
ThingSpeak.setField(2, windDirection);
ThingSpeak.setField(3, humid);
ThingSpeak.setField(4, temp);
ThingSpeak.setField(5, windDegrees);
// set the status
ThingSpeak.setStatus(myStatus);
// write to the ThingSpeak channel
int x = ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
if (x == 200) {
Serial.println("Channel update successful.");
else {
Serial.println("Problem updating channel. HTTP error code " + String(x));
aufnahmeStartMillis = currentMillis;
void count() {
InterruptCounter++;
