oops, sorry ... Ill post it now ...
* TinyIRReceiver.cpp.h
* Receives IR protocol data of NEC protocol using pin change interrupts.
* NEC is the protocol of most cheap remote controls for Arduino.
* No parity check is done!
* On a completely received IR command, the user function handleReceivedIRData(uint16_t aAddress, uint8_t aCommand, bool isRepetition)
* is called in Interrupt context but with interrupts being enabled to enable use of delay() etc.
* Functions called in interrupt context should be running as short as possible,
* so if you require longer action, save the data (address + command) and handle them in the main loop.
* Copyright (C) 2021 Armin Joachimsmeyer
* armin.joachimsmeyer@gmail.com
* This file is part of IRMP https://github.com/ukw100/IRMP.
* This file is part of Arduino-IRremote https://github.com/Arduino-IRremote/Arduino-IRremote.
* TinyIRReceiver is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/gpl.html>.
#ifndef TINY_IR_RECEIVER_CPP_H
#define TINY_IR_RECEIVER_CPP_H
#include <Arduino.h>
#include "TinyIRReceiver.h"
#include "digitalWriteFast.h"
//#define IR_MEASURE_TIMING
//#define IR_TIMING_TEST_PIN 7
//#define DO_NOT_USE_FEEDBACK_LED
/** \addtogroup TinyReceiver Minimal receiver for NEC protocol
//#define TRACE
TinyIRReceiverStruct TinyIRReceiverControl;
* Declaration of the callback function provided by the user application.
* It is called every time a complete IR command or repeat was received.
#if defined(ESP8266)
ICACHE_RAM_ATTR
#elif defined(ESP32)
IRAM_ATTR
#endif
void handleReceivedIRData(uint16_t aAddress, uint8_t aCommand, bool isRepetition);
* The ISR of TinyIRRreceiver.
* It handles the NEC protocol decoding and calls the user callback function on complete.
* 5 us + 3 us for push + pop for a 16MHz ATmega
ICACHE_RAM_ATTR
IRAM_ATTR
#endif
void IRPinChangeInterruptHandler(void) {
#if defined(IR_MEASURE_TIMING) && defined(IR_TIMING_TEST_PIN)
digitalWriteFast(IR_TIMING_TEST_PIN, HIGH); // 2 clock cycles
#endif
* Save IR input level
* Negative logic, true / HIGH means inactive / IR space, LOW / false means IR mark.
uint_fast8_t tIRLevel = digitalReadFast(IR_INPUT_PIN);
#if !defined(DO_NOT_USE_FEEDBACK_LED) && defined(IR_FEEDBACK_LED_PIN)
digitalWriteFast(IR_FEEDBACK_LED_PIN, !tIRLevel);
#endif
* 1. compute microseconds after last change
uint32_t tCurrentMicros = micros();
uint16_t tMicrosOfMarkOrSpace = tCurrentMicros - TinyIRReceiverControl.LastChangeMicros;
TinyIRReceiverControl.LastChangeMicros = tCurrentMicros;
uint8_t tState = TinyIRReceiverControl.IRReceiverState;
#ifdef TRACE
Serial.print(tState);
Serial.print(' ');
// Serial.print(F(" I="));
// Serial.print(tIRLevel);
// Serial.print(F(" D="));
// Serial.print(tDeltaMicros);
// Serial.println();
#endif
if (tIRLevel == LOW) {
* We have a mark here
if (tMicrosOfMarkOrSpace > 2 * NEC_HEADER_MARK) {
// timeout -> must reset state machine
tState = IR_RECEIVER_STATE_WAITING_FOR_START_MARK;
if (tState == IR_RECEIVER_STATE_WAITING_FOR_START_MARK) {
// We are at the beginning of the header mark, check timing at the next transition
tState = IR_RECEIVER_STATE_WAITING_FOR_START_SPACE;
else if (tState == IR_RECEIVER_STATE_WAITING_FOR_FIRST_DATA_MARK) {
if (tMicrosOfMarkOrSpace >= lowerValue25Percent(NEC_HEADER_SPACE)
&& tMicrosOfMarkOrSpace <= upperValue25Percent(NEC_HEADER_SPACE)) {
* We have a valid data header space here -> initialize data
TinyIRReceiverControl.IRRawDataBitCounter = 0;
TinyIRReceiverControl.IRRawData.ULong = 0;
TinyIRReceiverControl.IRRawDataMask = 1;
TinyIRReceiverControl.IRRepeatDetected = false;
tState = IR_RECEIVER_STATE_WAITING_FOR_DATA_SPACE;
} else if (tMicrosOfMarkOrSpace >= lowerValue25Percent(NEC_REPEAT_HEADER_SPACE)
&& tMicrosOfMarkOrSpace <= upperValue25Percent(NEC_REPEAT_HEADER_SPACE)
&& TinyIRReceiverControl.IRRawDataBitCounter >= NEC_BITS) {
* We have a repeat header here and no broken receive before -> set repeat flag
TinyIRReceiverControl.IRRepeatDetected = true;
// This parts are optimized by the compiler into jumps to one code :-)
// Wrong length -> reset state
else if (tState == IR_RECEIVER_STATE_WAITING_FOR_DATA_MARK) {
// Check data space length
if (tMicrosOfMarkOrSpace >= lowerValue(NEC_ZERO_SPACE) && tMicrosOfMarkOrSpace <= upperValue(NEC_ONE_SPACE)) {
// We have a valid bit here
if (tMicrosOfMarkOrSpace >= 2 * NEC_UNIT) {
// we received a 1
TinyIRReceiverControl.IRRawData.ULong |= TinyIRReceiverControl.IRRawDataMask;
// we received a 0 - empty code for documentation
// prepare for next bit
TinyIRReceiverControl.IRRawDataMask = TinyIRReceiverControl.IRRawDataMask << 1;
TinyIRReceiverControl.IRRawDataBitCounter++;
// error wrong state for the received level, e.g. if we missed one change interrupt -> reset state
else {
* We have a space here
if (tState == IR_RECEIVER_STATE_WAITING_FOR_START_SPACE) {
* Check length of header mark here
if (tMicrosOfMarkOrSpace >= lowerValue25Percent(NEC_HEADER_MARK)
&& tMicrosOfMarkOrSpace <= upperValue25Percent(NEC_HEADER_MARK)) {
tState = IR_RECEIVER_STATE_WAITING_FOR_FIRST_DATA_MARK;
// Wrong length of header mark -> reset state
else if (tState == IR_RECEIVER_STATE_WAITING_FOR_DATA_SPACE) {
// Check data mark length
if (tMicrosOfMarkOrSpace >= lowerValue(NEC_BIT_MARK) && tMicrosOfMarkOrSpace <= upperValue(NEC_BIT_MARK)) {
* We have a valid mark here, check for transmission complete
if (TinyIRReceiverControl.IRRawDataBitCounter >= NEC_BITS || TinyIRReceiverControl.IRRepeatDetected) {
* Code complete -> call callback, no parity check!
// Reset state for new start
#if !defined(ARDUINO_ARCH_MBED)
interrupts();
#endif
* Address reduction to 8 bit
if (TinyIRReceiverControl.IRRawData.UByte.LowByte
== (uint8_t) (~TinyIRReceiverControl.IRRawData.UByte.MidLowByte)) {
// standard 8 bit address NEC protocol
TinyIRReceiverControl.IRRawData.UByte.MidLowByte = 0; // Address is the first 8 bit
* Call user provided callback here
handleReceivedTinyIRData(TinyIRReceiverControl.IRRawData.UWord.LowWord,
TinyIRReceiverControl.IRRawData.UByte.MidHighByte, TinyIRReceiverControl.IRRepeatDetected);
// not finished yet
tState = IR_RECEIVER_STATE_WAITING_FOR_DATA_MARK;
TinyIRReceiverControl.IRReceiverState = tState;
#ifdef IR_MEASURE_TIMING
digitalWriteFast(IR_TIMING_TEST_PIN, LOW); // 2 clock cycles
#endif
* Initializes hardware interrupt generation according to IR_INPUT_PIN or use attachInterrupt() function.
void initPCIInterruptForTinyReceiver() {
pinModeFast(IR_TIMING_TEST_PIN, OUTPUT);
#endif
pinModeFast(IR_INPUT_PIN, INPUT_PULLUP);
pinModeFast(IR_FEEDBACK_LED_PIN, OUTPUT);
#endif
#if defined(__AVR_ATtiny1616__) || defined(__AVR_ATtiny3216__) || defined(__AVR_ATtiny3217__)
attachInterrupt(IR_INPUT_PIN, IRPinChangeInterruptHandler, CHANGE); // 2.2 us more than version configured with macros and not compatible
#elif !defined(__AVR__) || defined(TINY_RECEIVER_USE_ARDUINO_ATTACH_INTERRUPT)
// costs 112 bytes FLASH + 4bytes RAM
attachInterrupt(digitalPinToInterrupt(IR_INPUT_PIN), IRPinChangeInterruptHandler, CHANGE);
#else
# if defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
// use PinChangeInterrupt no INT0 for pin PB2
PCMSK = _BV(IR_INPUT_PIN);
// clear interrupt bit
GIFR |= 1 << PCIF;
// enable interrupt on next change
GIMSK |= 1 << PCIE;
# elif defined(__AVR_ATtiny87__) || defined(__AVR_ATtiny167__)
# if defined(ARDUINO_AVR_DIGISPARKPRO)
# if (IR_INPUT_PIN == 3)
// interrupt on any logical change
EICRA |= _BV(ISC00);
EIFR |= 1 << INTF0;
EIMSK |= 1 << INT0;
# elif (IR_INPUT_PIN == 9)
EICRA |= _BV(ISC10);
EIFR |= 1 << INTF1;
EIMSK |= 1 << INT1;
# else
# error "IR_INPUT_PIN must be 9 or 3."
# endif // if (IR_INPUT_PIN == 9)
# else // defined(ARDUINO_AVR_DIGISPARKPRO)
# if (IR_INPUT_PIN == 14)
EIFR |= 1 << INTF0;
EIMSK |= 1 << INT0;
# elif (IR_INPUT_PIN == 3)
EIFR |= 1 << INTF1;
EIMSK |= 1 << INT1;
# else
# error "IR_INPUT_PIN must be 14 or 3."
# endif // if (IR_INPUT_PIN == 14)
# endif
# else // defined(__AVR_ATtiny25__)
* ATmegas + ATtiny88 here
# if (IR_INPUT_PIN == 2)
EIFR |= 1 << INTF0;
EIMSK |= 1 << INT0;
EIFR |= 1 << INTF1;
EIMSK |= 1 << INT1;
# elif IR_INPUT_PIN == 4 || IR_INPUT_PIN == 5 || IR_INPUT_PIN == 6 || IR_INPUT_PIN == 7
//ATmega328 (Uno, Nano ) etc. Enable pin change interrupt 20 to 23 for port PD4 to PD7 (Arduino pin 4 to 7)
PCICR |= _BV(PCIE2);
PCMSK2 = digitalPinToBitMask(IR_INPUT_PIN);
# elif IR_INPUT_PIN == 8 || IR_INPUT_PIN == 9 || IR_INPUT_PIN == 10 || IR_INPUT_PIN == 11 || IR_INPUT_PIN == 12 || IR_INPUT_PIN == 13
//ATmega328 (Uno, Nano ) etc. Enable pin change interrupt 0 to 5 for port PB0 to PB5 (Arduino pin 8 to 13)
PCICR |= _BV(PCIE0);
PCMSK0 = digitalPinToBitMask(IR_INPUT_PIN);
# elif IR_INPUT_PIN == A0 || IR_INPUT_PIN == A1 || IR_INPUT_PIN == A2 || IR_INPUT_PIN == A3 || IR_INPUT_PIN == A4 || IR_INPUT_PIN == A5
//ATmega328 (Uno, Nano ) etc. Enable pin change interrupt 8 to 13 for port PC0 to PC5 (Arduino pin A0 to A5)
PCICR |= _BV(PCIE1);
PCMSK1 = digitalPinToBitMask(IR_INPUT_PIN);
# else
# error "IR_INPUT_PIN not allowed."
# endif // if (IR_INPUT_PIN == 2)
# endif // defined(__AVR_ATtiny25__)
#endif // ! defined(__AVR__) || defined(TINY_RECEIVER_USE_ARDUINO_ATTACH_INTERRUPT)
* Specify the right INT0, INT1 or PCINT0 interrupt vector according to different pins and cores.
* The default value of TINY_RECEIVER_USE_ARDUINO_ATTACH_INTERRUPT is set in TinyIRReceiver.h
#if defined(__AVR__) && !defined(TINY_RECEIVER_USE_ARDUINO_ATTACH_INTERRUPT)
ISR(INT0_vect) // Pin 2 global assignment
ISR(INT0_vect) // Pin 3 / PB6 / INT0 is connected to USB+ on DigisparkPro boards
# else
ISR(INT1_vect) // Pin 3 global assignment
# endif
# elif (IR_INPUT_PIN == 9) && defined(ARDUINO_AVR_DIGISPARKPRO) // Digispark pro
ISR(INT1_vect)
# elif (IR_INPUT_PIN == 14) && (defined(__AVR_ATtiny87__) || defined(__AVR_ATtiny167__))// For AVR_ATtiny167 INT0 is on pin 14 / PB6
ISR(INT0_vect)
# elif (! defined(ISC10)) || ((defined(__AVR_ATtiny87__) || defined(__AVR_ATtiny167__)) && INT1_PIN != 3)
// on ATtinyX5 we do not have a INT1_vect but we can use the PCINT0_vect
ISR(PCINT0_vect)
// PCINT for ATmega328 Arduino pins 4 (PD4) to 7 (PD7) - (PCINT 20 to 23)
ISR(PCINT2_vect)
// PCINT for ATmega328 Arduino pins 8 (PB0) to 13 (PB5) - (PCINT 0 to 5)
ISR(PCINT0_vect)
// PCINT for ATmega328 Arduino pins A1 (PC0) to A5 (PC5) - (PCINT 8 to 13)
ISR(PCINT1_vect)
# endif
IRPinChangeInterruptHandler();
#endif // defined(__AVR__) && ! defined(TINY_RECEIVER_USE_ARDUINO_ATTACH_INTERRUPT)
#endif // TINY_IR_RECEIVER_CPP_H
and also this ...
Optimized digital functions for AVR microcontrollers
by Watterott electronic (www.watterott.com)
based on http://code.google.com/p/digitalwritefast
#ifndef __digitalWriteFast_h_
#define __digitalWriteFast_h_ 1
//#define SANGUINO_PINOUT //define for Sanguino pinout
// general macros/defines
#ifndef BIT_READ
# define BIT_READ(value, bit) ((value) & (1UL << (bit)))
#endif
#ifndef BIT_SET
# define BIT_SET(value, bit) ((value) |= (1UL << (bit)))
#endif
#ifndef BIT_CLEAR
# define BIT_CLEAR(value, bit) ((value) &= ~(1UL << (bit)))
#endif
#ifndef BIT_WRITE
# define BIT_WRITE(value, bit, bitvalue) (bitvalue ? BIT_SET(value, bit) : BIT_CLEAR(value, bit))
#endif
#ifndef SWAP
# define SWAP(x,y) do{ (x)=(x)^(y); (y)=(x)^(y); (x)=(x)^(y); }while(0)
#endif
#ifndef DEC
# define DEC (10)
#endif
#ifndef HEX
# define HEX (16)
#endif
#ifndef OCT
# define OCT (8)
#endif
#ifndef BIN
# define BIN (2)
#endif
// workarounds for ARM microcontrollers
#if (!defined(__AVR__) || \
defined(ARDUINO_ARCH_SAM) || \
defined(ARDUINO_ARCH_SAMD))
#ifndef PROGMEM
# define PROGMEM
#endif
#ifndef PGM_P
# define PGM_P const char *
#endif
#ifndef PSTR
# define PSTR(str) (str)
#endif
#ifndef memcpy_P
# define memcpy_P(dest, src, num) memcpy((dest), (src), (num))
#endif
#ifndef strcpy_P
# define strcpy_P(dst, src) strcpy((dst), (src))
#endif
#ifndef strcat_P
# define strcat_P(dst, src) strcat((dst), (src))
#endif
#ifndef strcmp_P
# define strcmp_P(a, b) strcmp((a), (b))
#endif
#ifndef strcasecmp_P
# define strcasecmp_P(a, b) strcasecmp((a), (b))
#endif
#ifndef strncmp_P
# define strncmp_P(a, b, n) strncmp((a), (b), (n))
#endif
#ifndef strncasecmp_P
# define strncasecmp_P(a, b, n) strncasecmp((a), (b), (n))
#endif
#ifndef strstr_P
# define strstr_P(a, b) strstr((a), (b))
#endif
#ifndef strlen_P
# define strlen_P(a) strlen((a))
#endif
#ifndef sprintf_P
# define sprintf_P(s, f, ...) sprintf((s), (f), __VA_ARGS__)
#endif
#ifndef pgm_read_byte
# define pgm_read_byte(addr) (*(const unsigned char *)(addr))
#endif
#ifndef pgm_read_word
# define pgm_read_word(addr) (*(const unsigned short *)(addr))
#endif
#ifndef pgm_read_dword
# define pgm_read_dword(addr) (*(const unsigned long *)(addr))
#endif
#endif
// digital functions
//#ifndef digitalPinToPortReg
#define SPI_SW_SS_PIN (10) //SS on Uno (for software SPI)
#define SPI_SW_MOSI_PIN (11) //MOSI on Uno (for software SPI)
#define SPI_SW_MISO_PIN (12) //MISO on Uno (for software SPI)
#define SPI_SW_SCK_PIN (13) //SCK on Uno (for software SPI)
// --- Arduino Due and SAM3X8E based boards ---
#if (defined(ARDUINO_SAM_DUE) || \
defined(__SAM3X8E__))
#define UART_RX_PIN (0)
#define UART_TX_PIN (1)
#define I2C_SDA_PIN (20)
#define I2C_SCL_PIN (21)
#define SPI_HW_SS_PIN (78) //SS0:77, SS1:87, SS2:86, SS3:78
#define SPI_HW_MOSI_PIN (75) //75
#define SPI_HW_MISO_PIN (74) //74
#define SPI_HW_SCK_PIN (76) //76
// --- Arduino Zero and SAMD21G18 based boards ---
#elif (defined(ARDUINO_SAMD_ZERO) || \
defined(__SAMD21G18A__))
#define I2C_SDA_PIN (16)
#define I2C_SCL_PIN (17)
#define SPI_HW_SS_PIN (14) //14
#define SPI_HW_MOSI_PIN (21) //21
#define SPI_HW_MISO_PIN (18) //18
#define SPI_HW_SCK_PIN (20) //20
// --- Arduino Mega and ATmega128x/256x based boards ---
#elif (defined(ARDUINO_AVR_MEGA) || \
defined(ARDUINO_AVR_MEGA1280) || \
defined(ARDUINO_AVR_MEGA2560) || \
defined(__AVR_ATmega1280__) || \
defined(__AVR_ATmega1281__) || \
defined(__AVR_ATmega2560__) || \
defined(__AVR_ATmega2561__))
#define UART_RX_PIN (0) //PE0
#define UART_TX_PIN (1) //PE1
#define SPI_HW_SS_PIN (53) //PB0
#define SPI_HW_MOSI_PIN (51) //PB2
#define SPI_HW_MISO_PIN (50) //PB3
#define SPI_HW_SCK_PIN (52) //PB1
#define __digitalPinToPortReg(P) \
(((P) >= 22 && (P) <= 29) ? &PORTA : \
((((P) >= 10 && (P) <= 13) || ((P) >= 50 && (P) <= 53)) ? &PORTB : \
(((P) >= 30 && (P) <= 37) ? &PORTC : \
((((P) >= 18 && (P) <= 21) || (P) == 38) ? &PORTD : \
((((P) >= 0 && (P) <= 3) || (P) == 5) ? &PORTE : \
(((P) >= 54 && (P) <= 61) ? &PORTF : \
((((P) >= 39 && (P) <= 41) || (P) == 4) ? &PORTG : \
((((P) >= 6 && (P) <= 9) || (P) == 16 || (P) == 17) ? &PORTH : \
(((P) == 14 || (P) == 15) ? &PORTJ : \
(((P) >= 62 && (P) <= 69) ? &PORTK : &PORTL))))))))))
#define __digitalPinToDDRReg(P) \
(((P) >= 22 && (P) <= 29) ? &DDRA : \
((((P) >= 10 && (P) <= 13) || ((P) >= 50 && (P) <= 53)) ? &DDRB : \
(((P) >= 30 && (P) <= 37) ? &DDRC : \
((((P) >= 18 && (P) <= 21) || (P) == 38) ? &DDRD : \
((((P) >= 0 && (P) <= 3) || (P) == 5) ? &DDRE : \
(((P) >= 54 && (P) <= 61) ? &DDRF : \
((((P) >= 39 && (P) <= 41) || (P) == 4) ? &DDRG : \
((((P) >= 6 && (P) <= 9) || (P) == 16 || (P) == 17) ? &DDRH : \
(((P) == 14 || (P) == 15) ? &DDRJ : \
(((P) >= 62 && (P) <= 69) ? &DDRK : &DDRL))))))))))
#define __digitalPinToPINReg(P) \
(((P) >= 22 && (P) <= 29) ? &PINA : \
((((P) >= 10 && (P) <= 13) || ((P) >= 50 && (P) <= 53)) ? &PINB : \
(((P) >= 30 && (P) <= 37) ? &PINC : \
((((P) >= 18 && (P) <= 21) || (P) == 38) ? &PIND : \
((((P) >= 0 && (P) <= 3) || (P) == 5) ? &PINE : \
(((P) >= 54 && (P) <= 61) ? &PINF : \
((((P) >= 39 && (P) <= 41) || (P) == 4) ? &PING : \
((((P) >= 6 && (P) <= 9) || (P) == 16 || (P) == 17) ? &PINH : \
(((P) == 14 || (P) == 15) ? &PINJ : \
(((P) >= 62 && (P) <= 69) ? &PINK : &PINL))))))))))
#define __digitalPinToBit(P) \
(((P) >= 7 && (P) <= 9) ? (P) - 3 : \
(((P) >= 10 && (P) <= 13) ? (P) - 6 : \
(((P) >= 22 && (P) <= 29) ? (P) - 22 : \
(((P) >= 30 && (P) <= 37) ? 37 - (P) : \
(((P) >= 39 && (P) <= 41) ? 41 - (P) : \
(((P) >= 42 && (P) <= 49) ? 49 - (P) : \
(((P) >= 50 && (P) <= 53) ? 53 - (P) : \
(((P) >= 54 && (P) <= 61) ? (P) - 54 : \
(((P) >= 62 && (P) <= 69) ? (P) - 62 : \
(((P) == 0 || (P) == 15 || (P) == 17 || (P) == 21) ? 0 : \
(((P) == 1 || (P) == 14 || (P) == 16 || (P) == 20) ? 1 : \
(((P) == 19) ? 2 : \
(((P) == 5 || (P) == 6 || (P) == 18) ? 3 : \
(((P) == 2) ? 4 : \
(((P) == 3 || (P) == 4) ? 5 : 7)))))))))))))))
// --- Arduino MightyCore standard pinout ---
#elif (defined(__AVR_ATmega1284P__) || \
defined(__AVR_ATmega1284__) || \
defined(__AVR_ATmega644P__) || \
defined(__AVR_ATmega644A__) || \
defined(__AVR_ATmega644__) || \
defined(__AVR_ATmega324PB__) || \
defined(__AVR_ATmega324PA__) || \
defined(__AVR_ATmega324P__) || \
defined(__AVR_ATmega324A__) || \
defined(__AVR_ATmega164P__) || \
defined(__AVR_ATmega164A__) || \
defined(__AVR_ATmega32__) || \
defined(__AVR_ATmega16__) || \
defined(__AVR_ATmega8535__)) && \
!defined(BOBUINO_PINOUT)
#define UART_RX_PIN (8) //PD0
#define UART_TX_PIN (9) //PD1
#define I2C_SDA_PIN (17) //PC1
#define I2C_SCL_PIN (16) //PC0
#define SPI_HW_SS_PIN (4) //PB4
#define SPI_HW_MOSI_PIN (5) //PB5
#define SPI_HW_MISO_PIN (6) //PB6
#define SPI_HW_SCK_PIN (7) //PB7
#if defined(__AVR_ATmega324PB__)
(((P) >= 0 && (P) <= 7) ? &PORTB : (((P) >= 8 && (P) <= 15) ? &PORTD : (((P) >= 16 && (P) <= 23) ? &PORTC : (((P) >= 24 && (P) <= 31) ? &PORTA : &PORTE))))
(((P) >= 0 && (P) <= 7) ? &DDRB : (((P) >= 8 && (P) <= 15) ? &DDRD : (((P) >= 16 && (P) <= 23) ? &DDRC : (((P) >= 24 && (P) <= 31) ? &DDRA : &DDRE))))
(((P) >= 0 && (P) <= 7) ? &PINB : (((P) >= 8 && (P) <= 15) ? &PIND : (((P) >= 16 && (P) <= 23) ? &PINC : (((P) >= 24 && (P) <= 31) ? &PINA : &PINE))))
# if defined(SANGUINO_PINOUT)
(((P) >= 0 && (P) <= 7) ? (P) : (((P) >= 8 && (P) <= 15) ? (P) - 8 : (((P) >= 16 && (P) <= 23) ? (P) - 16 : (((P) >= 16 && (P) <= 23) ? (7 - ((P) - 24)) : (P) - 32))))
# else //MightyCore Pinout
(((P) >= 0 && (P) <= 7) ? (P) : (((P) >= 8 && (P) <= 15) ? (P) - 8 : (((P) >= 16 && (P) <= 23) ? (P) - 16 : (((P) >= 16 && (P) <= 23) ? (P) - 24 : (P) - 32))))
# endif
#else
(((P) >= 0 && (P) <= 7) ? &PORTB : (((P) >= 8 && (P) <= 15) ? &PORTD : (((P) >= 16 && (P) <= 23) ? &PORTC : &PORTA)))
(((P) >= 0 && (P) <= 7) ? &DDRB : (((P) >= 8 && (P) <= 15) ? &DDRD : (((P) >= 16 && (P) <= 23) ? &DDRC : &DDRA)))
(((P) >= 0 && (P) <= 7) ? &PINB : (((P) >= 8 && (P) <= 15) ? &PIND : (((P) >= 16 && (P) <= 23) ? &PINC : &PINA)))
(((P) >= 0 && (P) <= 7) ? (P) : (((P) >= 8 && (P) <= 15) ? (P) - 8 : (((P) >= 16 && (P) <= 23) ? (P) - 16 : (7 - ((P) - 24)))))
(((P) >= 0 && (P) <= 7) ? (P) : (((P) >= 8 && (P) <= 15) ? (P) - 8 : (((P) >= 16 && (P) <= 23) ? (P) - 16 : (P) - 24)))
# endif
#endif
// --- Arduino Leonardo and ATmega16U4/32U4 based boards ---
#elif (defined(ARDUINO_AVR_LEONARDO) || \
defined(__AVR_ATmega16U4__) || \
defined(__AVR_ATmega32U4__))
#define UART_RX_PIN (0) //PD2
#define UART_TX_PIN (1) //PD3
#define I2C_SDA_PIN (2) //PD1
#define I2C_SCL_PIN (3) //PD0
#define SPI_HW_SS_PIN (17) //PB0
#define SPI_HW_MOSI_PIN (16) //PB2
#define SPI_HW_MISO_PIN (14) //PB3
#define SPI_HW_SCK_PIN (15) //PB1
((((P) >= 0 && (P) <= 4) || (P) == 6 || (P) == 12 || (P) == 24 || (P) == 25 || (P) == 29) ? &PORTD : (((P) == 5 || (P) == 13) ? &PORTC : (((P) >= 18 && (P) <= 23)) ? &PORTF : (((P) == 7) ? &PORTE : &PORTB)))
((((P) >= 0 && (P) <= 4) || (P) == 6 || (P) == 12 || (P) == 24 || (P) == 25 || (P) == 29) ? &DDRD : (((P) == 5 || (P) == 13) ? &DDRC : (((P) >= 18 && (P) <= 23)) ? &DDRF : (((P) == 7) ? &DDRE : &DDRB)))
((((P) >= 0 && (P) <= 4) || (P) == 6 || (P) == 12 || (P) == 24 || (P) == 25 || (P) == 29) ? &PIND : (((P) == 5 || (P) == 13) ? &PINC : (((P) >= 18 && (P) <= 23)) ? &PINF : (((P) == 7) ? &PINE : &PINB)))
(((P) >= 8 && (P) <= 11) ? (P) - 4 : (((P) >= 18 && (P) <= 21) ? 25 - (P) : (((P) == 0) ? 2 : (((P) == 1) ? 3 : (((P) == 2) ? 1 : (((P) == 3) ? 0 : (((P) == 4) ? 4 : (((P) == 6) ? 7 : (((P) == 13) ? 7 : (((P) == 14) ? 3 : (((P) == 15) ? 1 : (((P) == 16) ? 2 : (((P) == 17) ? 0 : (((P) == 22) ? 1 : (((P) == 23) ? 0 : (((P) == 24) ? 4 : (((P) == 25) ? 7 : (((P) == 26) ? 4 : (((P) == 27) ? 5 : 6 )))))))))))))))))))
// --- Arduino Uno and ATmega168/328 based boards ---
#elif (defined(ARDUINO_AVR_UNO) || \
defined(ARDUINO_AVR_DUEMILANOVE) || \
defined(__AVR_ATmega8__) || \
defined(__AVR_ATmega48__) || \
defined(__AVR_ATmega48P__) || \
defined(__AVR_ATmega48PB__) || \
defined(__AVR_ATmega88P__) || \
defined(__AVR_ATmega88PB__) || \
defined(__AVR_ATmega168__) || \
defined(__AVR_ATmega168PA__) || \
defined(__AVR_ATmega168PB__) || \
defined(__AVR_ATmega328__) || \
defined(__AVR_ATmega328P__) || \
defined(__AVR_ATmega328PB__))
#define UART_RX_PIN (0) //PD0
#define UART_TX_PIN (1) //PD1
#define I2C_SDA_PIN (18) //A4
#define I2C_SCL_PIN (19) //A5
#define SPI_HW_SS_PIN (10) //PB0
#define SPI_HW_MOSI_PIN (11) //PB2
#define SPI_HW_MISO_PIN (12) //PB3
#define SPI_HW_SCK_PIN (13) //PB1
#if defined(__AVR_ATmega48PB__) || defined(__AVR_ATmega88PB__) || defined(__AVR_ATmega168PB__) || defined(__AVR_ATmega328PB__)
(((P) >= 0 && (P) <= 7) ? &PORTD : (((P) >= 8 && (P) <= 13) ? &PORTB : (((P) >= 14 && (P) <= 19) ? &PORTC : &PORTE)))
(((P) >= 0 && (P) <= 7) ? &DDRD : (((P) >= 8 && (P) <= 13) ? &DDRB : (((P) >= 14 && (P) <= 19) ? &DDRC : &DDRE)))
(((P) >= 0 && (P) <= 7) ? &PIND : (((P) >= 8 && (P) <= 13) ? &PINB : (((P) >= 14 && (P) <= 19) ? &PINC : &PINE)))
(((P) >= 0 && (P) <= 7) ? (P) : (((P) >= 8 && (P) <= 13) ? (P) - 8 : (((P) >= 14 && (P) <= 19) ? (P) - 14 : (((P) >= 20 && (P) <= 21) ? (P) - 18 : (P) - 22))))
#else
(((P) >= 0 && (P) <= 7) ? &PORTD : (((P) >= 8 && (P) <= 13) ? &PORTB : &PORTC))
(((P) >= 0 && (P) <= 7) ? &DDRD : (((P) >= 8 && (P) <= 13) ? &DDRB : &DDRC))
(((P) >= 0 && (P) <= 7) ? &PIND : (((P) >= 8 && (P) <= 13) ? &PINB : &PINC))
(((P) >= 0 && (P) <= 7) ? (P) : (((P) >= 8 && (P) <= 13) ? (P) - 8 : (P) - 14))
#endif
// --- Arduino Uno WiFi Rev 2, Nano Every ---
#elif defined(__AVR_ATmega4809__)
#define UART_RX_PIN (0) //PB0
#define UART_TX_PIN (1) //PB1
#define I2C_SDA_PIN (22) //PA2
#define I2C_SCL_PIN (23) //PA3
#define SPI_HW_SS_PIN (8) //PE3
#define SPI_HW_MOSI_PIN (11) //PE0
#define SPI_HW_MISO_PIN (12) //PE1
#define SPI_HW_SCK_PIN (13) //PE2
(((P) == 2 || (P) == 7 ) ? &VPORTA.OUT : ((P) == 5 || (P) == 9 || (P) == 10) ? &VPORTB.OUT : ((P) == 4) ? &VPORTC.OUT : (((P) >= 14 && (P) <= 17) || (P) == 20 || (P) == 21) ? &VPORTD.OUT : ((P) == 8 || (P) == 11 || (P) == 12 || (P) == 13) ? &VPORTE.OUT : &VPORTF.OUT)
(((P) == 2 || (P) == 7 ) ? &VPORTA.DIR : ((P) == 5 || (P) == 9 || (P) == 10) ? &VPORTB.DIR : ((P) == 4) ? &VPORTC.DIR : (((P) >= 14 && (P) <= 17) || (P) == 20 || (P) == 21) ? &VPORTD.DIR : ((P) == 8 || (P) == 11 || (P) == 12 || (P) == 13) ? &VPORTE.DIR : &VPORTF.DIR)
(((P) == 2 || (P) == 7 ) ? &VPORTA.IN : ((P) == 5 || (P) == 9 || (P) == 10) ? &VPORTB.IN : ((P) == 4) ? &VPORTC.IN : (((P) >= 14 && (P) <= 17) || (P) == 20 || (P) == 21) ? &VPORTD.IN : ((P) == 8 || (P) == 11 || (P) == 12 || (P) == 13) ? &VPORTE.IN : &VPORTF.IN)
(((P) == 2 || (P) == 9 || (P) == 11 || (P) == 17) ? 0 : ((P) == 7 || (P) == 10 || (P) == 12 || (P) == 16) ? 1 : ((P) == 5 || (P) == 13 || (P) == 15 || (P) == 18) ? 2 : ((P) == 9 || (P) == 14 || (P) == 19) ? 3 : ((P) == 6 || (P) == 20) ? 4 : ((P) == 3 || (P) == 21) ? 5 : 6 )
// TinyCore
// https://raw.githubusercontent.com/xukangmin/TinyCore/master/avr/package/package_tinycore_index.json
// https://docs.tinycore.dev/en/latest/
#elif defined(__AVR_ATtiny1616__) || defined(__AVR_ATtiny3216__) || defined(__AVR_ATtiny3217__)
#define __digitalPinToPortReg(P) ((P) <= 5 ? &VPORTB.OUT : ((P) <= 9 ? &VPORTC.OUT : ((P) <= 16 ? &VPORTA.OUT : ((P) <= 18 ? &VPORTB.OUT : &VPORTC.OUT))))
#define __digitalPinToDDRReg(P) ((P) <= 5 ? &VPORTB.DIR : ((P) <= 9 ? &VPORTC.DIR : ((P) <= 16 ? &VPORTA.DIR : ((P) <= 18 ? &VPORTB.DIR : &VPORTC.DIR))))
#define __digitalPinToPINReg(P) ((P) <= 5 ? &VPORTB.IN : ((P) <= 9 ? &VPORTC.IN : ((P) <= 16 ? &VPORTA.IN : ((P) <= 18 ? &VPORTB.IN : &VPORTC.IN))))
#define __digitalPinToBit(P) ( (P) <= 3 ? (3 - P) : ((P) <= 5 ? (P) : ((P) <= 9 ? (P - 6) : ((P) <= 16 ? ((P) - 9) : ((P) <= 18 ? ((P) - 11) : ((P) - 15))))) )
// --- ATtinyX5 ---
#elif defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
// we have only PORTB
#define __digitalPinToPortReg(P) (&PORTB)
#define __digitalPinToDDRReg(P) (&DDRB)
#define __digitalPinToPINReg(P) (&PINB)
#define __digitalPinToBit(P) (((P) <= 7) ? (P) : (((P) >= 8 && (P) <= 13) ? (P) - 8 : (P) - 14))
// --- ATtiny88 ---
#elif defined(__AVR_ATtiny88__)
#define __digitalPinToPortReg(P) ((P) <= 7 ? &PORTD : ((P) <= 14 ? &PORTB : ((P) <= 18 ? &PORTA : &PORTC)))
#define __digitalPinToDDRReg(P) ((P) <= 7 ? &DDRD : ((P) <= 14 ? &DDRB : ((P) <= 18 ? &DDRA : &DDRC)))
#define __digitalPinToPINReg(P) ((P) <= 7 ? &PIND : ((P) <= 14 ? &PINB : ((P) <= 18 ? &PINA : &PINC)))
#define __digitalPinToBit(P) ( (P) <= 7 ? (P) : ((P) <= 13 ? ((P) - 8) : ((P) == 14 ? 7 : ((P) <= 16 ? ((P) - 14) : ((P) <= 18 ? ((P) - 17) : ((P) == 25 ? 7 : ((P) - 19)))))) )
# else
#define __digitalPinToPortReg(P) ((P) <= 7 ? &PORTD : ((P) <= 15 ? &PORTB : ((P) <= 22 ? &PORTC : ((P) <= 26 ? &PORTA : &PORTC))))
#define __digitalPinToDDRReg(P) ((P) <= 7 ? &DDRD : ((P) <= 15 ? &DDRB : ((P) <= 22 ? &DDRC : ((P) <= 26 ? &DDRA : &DDRC))))
#define __digitalPinToPINReg(P) ((P) <= 7 ? &PIND : ((P) <= 15 ? &PINB : ((P) <= 22 ? &PINC : ((P) <= 26 ? &PINA : &PINC))))
#define __digitalPinToBit(P) ((P) <= 15 ? ((P) & 0x7) : ((P) == 16 ? (7) : ((P) <= 22 ? ((P) - 17) : ((P) == 27 ? (6) : ((P) - 23)))))
# endif
// --- ATtinyX4 + ATtinyX7 ---
#elif defined(__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__) || defined(__AVR_ATtiny87__) || defined(__AVR_ATtiny167__)
// Strange enumeration of pins on Digispark board and core library
#define __digitalPinToPortReg(P) (((P) <= 4) ? &PORTB : &PORTA)
#define __digitalPinToDDRReg(P) (((P) <= 4) ? &DDRB : &DDRA)
#define __digitalPinToPINReg(P) (((P) <= 4) ? &PINB : &PINA)
#define __digitalPinToBit(P) (((P) <= 2) ? (P) : (((P) == 3) ? 6 : (((P) == 4) ? 3 : (((P) == 5) ? 7 : (P) - 6 ))))
# else
// ATtinyX4: PORTA for 0 to 7, PORTB for 8 to 11
// ATtinyX7: PORTA for 0 to 7, PORTB for 8 to 15
#define __digitalPinToPortReg(P) (((P) <= 7) ? &PORTA : &PORTB)
#define __digitalPinToDDRReg(P) (((P) <= 7) ? &DDRA : &DDRB)
#define __digitalPinToPINReg(P) (((P) <= 7) ? &PINA : &PINB)
#define __digitalPinToBit(P) (((P) <= 7) ? (P) : (P) - 8 )
# endif
// --- Other ---
#else
#define I2C_SDA_PIN SDA
#define I2C_SCL_PIN SCL
#define SPI_HW_SS_PIN SS
#define SPI_HW_MOSI_PIN MOSI
#define SPI_HW_MISO_PIN MISO
#define SPI_HW_SCK_PIN SCK
#endif
//#endif //#ifndef digitalPinToPortReg
#ifndef digitalWriteFast
#if (defined(__AVR__) || defined(ARDUINO_ARCH_AVR))
#define digitalWriteFast(P, V) \
if (__builtin_constant_p(P)) { \
BIT_WRITE(*__digitalPinToPortReg(P), __digitalPinToBit(P), (V)); \
} else { \
digitalWrite((P), (V)); \
#else
#define digitalWriteFast digitalWrite
#endif
#endif
#ifndef pinModeFast
#define pinModeFast(P, V) \
if (__builtin_constant_p(P) && __builtin_constant_p(V)) { \
if (V == INPUT_PULLUP) {\
BIT_CLEAR(*__digitalPinToDDRReg(P), __digitalPinToBit(P)); \
BIT_SET(*__digitalPinToPortReg(P), __digitalPinToBit(P)); \
} else { \
BIT_WRITE(*__digitalPinToDDRReg(P), __digitalPinToBit(P), (V)); \
} else { \
pinMode((P), (V)); \
#else
#define pinModeFast pinMode
#endif
#endif
#ifndef digitalReadFast
#define digitalReadFast(P) ( (int) __digitalReadFast((P)) )
#define __digitalReadFast(P ) \
(__builtin_constant_p(P) ) ? \
(( BIT_READ(*__digitalPinToPINReg(P), __digitalPinToBit(P))) ? HIGH:LOW ) : \
digitalRead((P))
#else
#define digitalReadFast digitalRead
#endif
#endif
#ifndef digitalToggleFast
#define digitalToggleFast(P) \
BIT_SET(*__digitalPinToPINReg(P), __digitalPinToBit(P)); \
} else { \
digitalWrite(P, ! digitalRead(P)); \
#else
#define digitalToggleFast(P) digitalWrite(P, ! digitalRead(P))
#endif
#endif
#endif //__digitalWriteFast_h_
