Interrupts & Servos
I'm trying to create a program to when I push a button it interrupts and changes which servo is receiving the distance sensor value. I need to use a interrupt because I'm wanting the servos to receive a "live" feed from the distance sensor.
Here is Jeremy Blum's Code (Tutorial 10 for Arduino: Interrupts + Debouncing – JeremyBlum.com):
//Program by Jeremy Blum
//www.jeremyblum.com
//Use hardware Debounced Switch to Control Interrupt
//Setup the Button
int buttonInt = 0; //AKA digital pin 2
//Setup the LEDs
int yellowLED = 11;
int redLED = 10;
int greenLED = 9;
int nullLED = 6;
volatile int selectedLED = greenLED;
//Setup the Distance Sensor
int distPin = 0;
  pinMode (redLED, OUTPUT);
  pinMode (greenLED, OUTPUT);
  pinMode (yellowLED, OUTPUT);
  pinMode (nullLED, OUTPUT);
  attachInterrupt(buttonInt, swap, RISING);
void swap()
  if (selectedLED == greenLED)
    selectedLED = redLED;
  else if (selectedLED == redLED)
    selectedLED = yellowLED;
  else if (selectedLED == yellowLED)
    selectedLED = nullLED;
  //Read Distance Sensor
  int dist = analogRead(distPin);
  int brightness = map(dist, 0, 1023, 0, 255);
  //Control LED Brightness
  analogWrite(selectedLED, brightness);
I was thinking of changing the led's to servos:
void swap()
  if (selectedServo == servoPin)
    selectedServo = servoExample;
  else (selectedServo == servoExample)
    selectedServo = servoPin;
Except this does not work.
How can I achieve this?
void swap()
Sort out your swap function. As it stands it makes no sense at all.
Mark
Doesn't seem very likely.
holmes4:
void swap()
Mark
I disagree - this bit
void swap()
makes sense.
Yes but the rest does not. OP needs to learn to read the code ne has writen.
Mark
holmes4:
Mark
Oh! The irony :wink:
Among other things, you misspelled stolen.
