nightcrawler218:
I have modified the code & hardware too. digital pin 5(relay control, OUTPUT PIN) & digital pin2 (door lock monitor, INPUT) will be shorted so that if the relay is ON the door lock monitor is also on. Now the problem arises I have added the door monitor logic into the void loop() function. Two functio will be in the loop() function.
if pin2 is HIGH> check for the status of door sensor> if door sensor detects any change, switch on the buzzer/led
check for new sms> process sms> actuate the relays
#include <SoftwareSerial.h>
// EN: String buffer for the GPRS shield message
String msg = String("");
// EN: Set to 1 when the next GPRS shield message will contains the SMS message
int SmsContentFlag = 0;
//control pins of relay.
int relay_a=4;
int relay_b=5;
int relay_c=6;
int relay_d=7;
int dlm=2; // door lock monitor
int door_sensor=3; // door sensor
int led=13;
// EN: Code PIN of the SIM card (if applied)
//String SIM_PIN_CODE = String( "XXXX" );
Serial.begin(19200); // the GPRS baud rate
// Initialize PINs
pinMode( 4, OUTPUT );
pinMode( 5, OUTPUT );
pinMode( 6, OUTPUT );
pinMode( 7, OUTPUT );
pinMode( 2, INPUT );
pinMode( 3,INPUT );
pinMode( 13, OUTPUT );
digitalWrite( 4, LOW );
digitalWrite( 5, LOW );
digitalWrite( 6, LOW );
digitalWrite( 7, LOW );
Serial.println( "AT+CMGF=1" );
delay(200);
if (digitalRead(2,HIGH))
if (digitalRead(3,HIGH)
(digitalWrite(13,HIGH)
else{
char SerialInByte;
if(Serial.available())
SerialInByte = (unsigned char)Serial.read();
delay(5);
// EN: Program also listen to the GPRS shield message.
// EN: If the message ends with then process the message
if( SerialInByte == 13 ){
// EN: Store the char into the message buffer
ProcessGprsMsg();
if( SerialInByte == 10 ){
// EN: Skip Line feed
else {
// EN: store the current character in the message string buffer
msg += String(SerialInByte);
// EN: Make action based on the content of the SMS.
// Notice than SMS content is the result of the processing of several GPRS shield messages.
void ProcessSms( String sms ){
if( sms.indexOf("ona") >= 0 ){
digitalWrite( relay_a, HIGH );
if( sms.indexOf("onb") >= 0 ){
digitalWrite( relay_b, HIGH );
if( sms.indexOf("onc") >= 0 ){
digitalWrite( relay_c, HIGH );
if( sms.indexOf("ond") >= 0 ){
digitalWrite( relay_d, HIGH );
if( sms.indexOf("offa") >= 0 ){
digitalWrite( relay_a, LOW );
if( sms.indexOf("offb") >= 0 ){
digitalWrite( relay_b, LOW );
if( sms.indexOf("offc") >= 0 ){
digitalWrite( relay_c, LOW );
if( sms.indexOf("offd") >= 0 ){
digitalWrite( relay_d, LOW );
// EN: Request Text Mode for SMS messaging
void GprsTextModeSMS(){
void GprsReadSmsStore( String SmsStorePos ){
Serial.print( "AT+CMGR=" );
Serial.println( SmsStorePos );
// EN: Clear the GPRS shield message buffer
void ClearGprsMsg(){
msg = "";
// EN: interpret the GPRS shield message and act appropiately
void ProcessGprsMsg() {
if( msg.indexOf( "Call Ready" ) >= 0 ){
// Serial.println( "*** GPRS Shield registered on Mobile Network " );
GprsTextModeSMS();
// EN: unsolicited message received when getting a SMS message
if( msg.indexOf( "+CMTI" ) >= 0 ){
// Serial.println( " SMS Received " );
// EN: Look for the coma in the full message (+CMTI: "SM",6)
// In the sample, the SMS is stored at position 6
int iPos = msg.indexOf( "," );
String SmsStorePos = msg.substring( iPos+1 );
// Serial.print( "SMS stored at " );
// Serial.println( SmsStorePos );
// EN: Ask to read the SMS store
GprsReadSmsStore( SmsStorePos );
// EN: SMS store readed through UART (result of GprsReadSmsStore request)
if( msg.indexOf( "+CMGR:" ) >= 0 ){
// EN: Next message will contains the BODY of SMS
SmsContentFlag = 1;
// EN: Following lines are essentiel to not clear the flag!
ClearGprsMsg();
return;
// EN: +CMGR message just before indicate that the following GRPS Shield message
// (this message) will contains the SMS body
if( SmsContentFlag == 1 ){
// Serial.println( " SMS MESSAGE CONTENT " );
// Serial.println( msg );
// Serial.println( " END OF SMS MESSAGE ***" );
ProcessSms( msg );
ClearGprsMsg();
// EN: Always clear the flag
SmsContentFlag = 0;
In this code the void loop shows error.
C:\Users\User\Desktop\arduino-1.5.2\hardware\arduino\avr\cores\arduino/Arduino.h: In function 'void loop()':
C:\Users\User\Desktop\arduino-1.5.2\hardware\arduino\avr\cores\arduino/Arduino.h:102: error: too many arguments to function 'int digitalRead(uint8_t)'
Using_SMS_to_Control_Relay_Hardware_Serial:41: error: at this point in file
Using_SMS_to_Control_Relay_Hardware_Serial:43: error: at this point in file
Using_SMS_to_Control_Relay_Hardware_Serial:44: error: expected )' before '{' token Using_SMS_to_Control_Relay_Hardware_Serial:47: error: expected primary-expression before '}' token Using_SMS_to_Control_Relay_Hardware_Serial:47: error: expected
;' before '}' token
Actually I want yo attach an interrupt function that can ONLY be activated when the door lock monitor (pin 2) is high & the door sensor detects a change (preferably Falling trigger).
From what I can see you want to add increasing complexity to get around your shortcomings in understanding code. It is like spinning the wheels in mud, you only get stuck deeper.
Read about if-else and switch-case and practice on simple examples. Then find a clear explanation on finite state machines. Proper tools and the understanding of how to use them will give you a clear view of far easier ways.
You do not need interrupts for something so slow as button press. If your code does not prevent itself from being responsive, 1 millisecond to Arduino is like whole minutes to you.
