Hello everyone,
I'm having a problem trying to call a void fuction by using a button and I think the problem is that I'm not using attachinterrupt function correctly. I'm using arduino UNO and as i saw pins 2 and 3 are used for interrupts. The problem is that when i have 2,3 on pinmode function i can't call _doTare and _doCount. If i put 2 and 3 to the attachInterrupt function i get on the serial monitor COUNT... and TARE... but when i press the buttons still nothing happens.
Here is the code:
#include "HX711.h" //library of scale
//library of rfid
#include <LiquidCrystal.h> //library of lcd
const int resolution=1400;
const int MaxChars=15;
int val = 0;
String commandChars="~CWL";
char strValue[MaxChars+1];
char serialInputType=' ';
float itemWeight=0.00;
int index=0;
long total=0;
long average = 0;
long tareWeight=0;
String LCDLine1,LCDLine2;
String itemLabel;
bool doTare=false;
bool doCount=false;
HX711 scale(A4,A3);
LiquidCrystal lcd(7,6,5,4,3,2);
const int BackLight = 8;
void updateLCD () {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(LCDLine1);
Serial.print("A");
Serial.println(LCDLine1);
lcd.setCursor(0,1);
lcd.print(LCDLine2);
Serial.print("B");
Serial.println(LCDLine2);
long readingAverage(int samples=25,long t=0) {
total=0;
for (int i=0; i<samples;i++) {
total=total+((scale.read()/resolution)-t);
delay(10);
return (total / samples);
void _doTare() {
doTare=true;
void setTare() {
doTare=false;
LCDLine1="TARE ...";
LCDLine2="";
updateLCD();
digitalWrite(13, !digitalRead(13)); // Toggle LED on pin 13
tareWeight=readingAverage(25,0);
void _doCount() {
doCount=true;
void getItemWeight(float c=25.00)
doCount=false;
LCDLine1="COUNT ...";
LCDLine2="";
updateLCD();
itemWeight=readingAverage(25,tareWeight) / c;
Serial.print('I');
Serial.println(int(itemWeight*100));
Serial.println("Counting Scale - Version 0.9");
pinMode(13, OUTPUT);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(7), _doTare, CHANGE);
attachInterrupt(digitalPinToInterrupt(5), _doCount, CHANGE);
lcd.begin(16,2);
pinMode(BackLight, OUTPUT);
digitalWrite(BackLight, HIGH);
LCDLine1="Initializing ...";
LCDLine2="";
updateLCD();
void setLabel(char ch) {
if(index < MaxChars && (isDigit(ch) or isAlpha(ch) or isWhitespace(ch))) {
strValue[index++] = ch;
itemLabel=strValue;
index = 0;
// strValue[0]=(char)0;
memset(strValue, 0, sizeof strValue);
void setItemWeight(char ch) {
int tempWeight;
if(index < MaxChars && isDigit(ch)) {
tempWeight =atoi(strValue);
if(tempWeight > 0){
itemWeight=tempWeight/100.00;
lcd.print(itemWeight);
index = 0;
void readCommand(char ch) {
switch (ch) {
case '2' : // Count 25
getItemWeight(25);
case '5' : // Count 50
getItemWeight(50);
case '7' : // Count 75
getItemWeight(75);
case '1' : // Count 100
getItemWeight(100);
case 'T' : // Tare
setTare();
void serialEvent()
while(Serial.available())
char ch = Serial.read();
switch (serialInputType) {
case 'W' :
setItemWeight(ch);
case 'L' :
setLabel(ch);
case 'C' :
readCommand(ch);
case 'V' :
case ' ' :
if (commandChars.indexOf(ch)>0) {
serialInputType=ch;
if (doTare) {
setTare();
if (doCount) {
getItemWeight(25);
average=readingAverage(25,tareWeight);
Serial.println(average);
LCDLine1=String(average*0.715)+"g";
// if item weight has been set, calculate and show quantity
if (itemWeight>0) {
// Do not want to show quantity as negative
if (average>0) {
LCDLine2=String(average / itemWeight,0);
else {
LCDLine2="0";
// if there is an associated label, show it. Otherwise show pcs
if (itemLabel!="") {
LCDLine2=LCDLine2+" "+itemLabel;
else {
LCDLine2=LCDLine2+" Pcs";
updateLCD();
