I have a program where i am calling an external interrupt upon the falling edge.
within the interrupt I have a switch block that determines what is done during interrupt.
For some reason it seems to ignore the switch block and run both conditions regardless whenever I trigger it. The condition variable is cal_state and it is initialized to 0 at the beginning of the program
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void)
#asm("cli");
PORTB.3 = 1; //set LED light on showing when programing
avg_height = 0;
for(i=0;i<10;i++){
avg_height = avg_height + height_value[i];
switch(cal_state){
case 0:
analog_value = read_adc(0x02);
eeprom_var = ((analog_value - 100.12) / 2.2802);
cal_state = 1;
case 1:
cal_state++;
case 2:
KNEEL_1 = avg_height/10;
cal_state = 4;
case 4:
cal_state++;
case 5:
HIGHBUOY_1 = avg_height/10;
cal_state = 6;
case 6:
cal_state =0;
//for(i=0; i<32000;i++){ for(analog_value=0;analog_value <15;analog_value++){}}
for(i=0;i<32000;i++){
analog_value =0;
while(analog_value <20){analog_value++;}
startup();
state = 0;
PORTB.3 = 0; //set LED light off showing programming done
Thats my current code. I noticed it wasn't ignoring the conditions, but infact it was triggering twice for no reason. What I did didn't solve the problem, but it avoids it.
Here is my code for start up. (all it's doing is taking certain values which are in eeprom ((eeprom_var, HIGHBUOY_1, KNEEL_!)) and putting them into global variables.
readadc is a stardard ADC from a sensor. It works fine, but here is the code regardless.
unsigned int read_adc(unsigned char adc_input)
ADMUX=(adc_input & 0x0f) | ADC_VREF_TYPE;
// Delay needed for the stabilization of the ADC input voltage
for(i=0;i<1000;i++){}
//delay_us(10);
// Start the AD conversion
ADCSRA|=0x40;
// Wait for the AD conversion to complete
while ((ADCSRA & 0x10)==0);
ADCSRA|=0x10;
return ADCW;
I believe the issue is a bouncing issue. That being said i'm not sure which is the best way to go about avoiding it. I could poll the pin that the interrupt is on, and if X amount of time has passed where it is still high, do the code that i have in the interrupt.
I think thats likely the best way to avoid the double triggering.
