I am investigating the timing of the DHT (11,21,22) sensor.
One aspect is the delay between reads. Documentation mentions 2000 milliseconds between reads but my tests indicate that 360-370 millis is approx the limit (UNO, DHT22 10 cm wires). In practice 500 (1000) might work quite well.
If you have a DHT sensor and some time to spare, please run this test and post a part of the output where it alternates
The sketch below searches this value automatically
// FILE: dht22_test.ino
// AUTHOR: Rob Tillaart
// VERSION: 0.1.01
// PURPOSE: DHT library test sketch for DHT22 && Arduino
// URL:
// Released to the public domain
#include <dht.h>
dht DHT;
#define DHT22_PIN 5
Serial.println("DHT TEST PROGRAM ");
Serial.print("LIBRARY VERSION: ");
Serial.println(DHT_LIB_VERSION);
Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)\tTime (us)");
int del = 500;
// READ DATA
Serial.print("DHT22, \t");
uint32_t start = micros();
int chk = DHT.read22(DHT22_PIN);
uint32_t stop = micros();
switch (chk)
case DHTLIB_OK:
Serial.print("OK,\t");
del -= 10;
case DHTLIB_ERROR_CHECKSUM:
Serial.print("Checksum error,\t");
case DHTLIB_ERROR_TIMEOUT:
Serial.print("Time out error,\t");
del += 10;
default:
Serial.print("Unknown error,\t");
// DISPLAY DATA
Serial.print(DHT.humidity, 1);
Serial.print(",\t");
Serial.print(DHT.temperature, 1);
Serial.print(stop - start);
Serial.print(del);
delay(del);
// END OF FILE
some output lines
DHT22, OK, 44.0, 20.0, 4792, 360
DHT22, Time out error, -999.0, -999.0, 51392, 370
DHT22, OK, 44.0, 20.0, 4800, 360
DHT22, Time out error, -999.0, -999.0, 51388, 370
