Introduce a scale to compare 2 AnalogRead
Hi guys, i have a code in which i want to instroduce a scale. For example, if my ldr1 read 80 and ldr2 read 85, my solar panel won't move. (or if ldr1 = 20 and ldr2 = 15, for example)
But i realy don't know how to do that. My code :
int ldr_right = A1;
int ldr_left = A2;
int left_read;
int right_read;
int MotorPin = 7;                 // Moteur connecté au pin 7
pinMode(MotorPin, OUTPUT);      // met la broche numérique du moteur en sortie
int left_read = analogRead(A2);
int right_read = analogRead(A1);
if(right_read > left_read)          // Si la LDR droite capte plus de luminosité que celle de gauche 'luminosité vers la droite)
 digitalWrite(MotorPin, HIGH);   //
 delay(1000);                   // attend une seconde
else if(left_read > right_read)      // si la luminosité est vers la gauche
  digitalWrite(MotorPin, LOW);
delay(60000);        // attend une minute
Thank's for help !
Alazarus: Hi guys, i have a code in which i want to instroduce a scale. For example, if my ldr1 read 80 and ldr2 read 85, my solar panel won't move. (or if ldr1 = 20 and ldr2 = 15, for example)
Do you mean you want it to move if they more than 5 apart, so 85,70 will move, 85,83 won't?
Yes, it is :) If i don't do that, my solar tracker will always move :roll_eyes:
if(abs(right_read - left_read) > 5)
   // Get a move on
It's all about mathematics and i was searching a special code... damn ! Thank's :)
Can i write this ?
else if ((abs(right_read - left_read) > 5) && (abs(left_read - right_read) >5))
delay(600000)
Edit : no it's stupid, i should have the two conditions in two loop!
How are the two conditions different?
left_read - right_read is not the same as right_read - left_read, but abs(left_read - right_read) is the same as abs(right_read - left_read).
