Introducing delay using timers in arduino
I’m doing register level programming in arduino.The goal is to write my own delay logic using timers.Here is the code
#include<avr/io.h>
int main()
  DDRB=(1<<PORTB5);
  TCCR1B=(1<<CS12);
  while(1)
    if(TCNT1>=31250)
      PORTB^=(1<<PORTB5);
      TCNT1=0;
  return 0;
The above program is for arduino to introduce delay without using delay function and its working alright.But have a look at the code below.
#include<avr/io.h>
   DDRB=(1<<PORTB5);
   TCCR1B=(1<<CS12);
   if(TCNT1>=31250)
      PORTB^=(1<<PORTB5);
      TCNT1=0;
When I write it this way,the program is getting compiled but there is no blinking in arduino. What might be the problem?
Could it be that the PWM output code (analogWrite()) is configuring Timer1? Perhaps you have to initialize more than one of the Timer1 registers.
You may also want to try:
      PINB = (1<<PORTB5);
That toggles the pin without needing the XOR operator. The PINx register will toggle any bits written as 1.
The arduino's main function calls "init()" before setup(). init() is defined in your arduino directory under: {arduino}/hardware/arduino/cores/arduino/wiring.c
See if it is messing with any of the same registers that you are.
