My project is a FingerPrint Lock Coin Counter like a secured piggbank
Hope someone can help im almost to finish but getting this error I dont know why.
#include <Adafruit_Fingerprint.h> //Libraries needed
#include <SoftwareSerial.h>
#include <LCD.h>
#include <Wire.h>
#include <EEPROM.h>
#define I2C_ADDR 0x27 //LCD i2c stuff
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
#define coinSlot 6
int coinValue = 0;
int coinCount = 0;
int coinSlotSignal;
int requiredCoins = 1;
boolean coinInserted = false;
int in2 = 4;
int But1=8; // In order to add a push button I got the 5v from the pin 8 instead of "5v" arduino pin
int But2=9;
String Names[] = { "RAVEN", "Surtr", "Tech",}; //Those are the names affected to the fingertemplates IDs
//The first on which is Names[0] : Yassine has the ID 1 in the fingerprint sensor
SoftwareSerial mySerial(2, 3); //Fingerprint sensor wiring RX 3, TX 2
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin); //LCD declaring
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial); //Fingerprint sensor declaring
pinMode(in2, OUTPUT);
digitalWrite(in2, HIGH);
digitalWrite(But1,LOW);
pinMode(coinSlot, INPUT_PULLUP);
finger.begin(57600);
lcd.begin (16,2);
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.home();
lcd.write(EEPROM.read(5));
finger.getTemplateCount(); //Counts the number of templates stored in the sensor flash memory
delay(2000);
introScreen();
int result = getFingerprintIDez(); //This function keeps looping and waiting for a fingerprint to be put on the sensor
//delay(50);
//If the button is pressed it opens the doorlock as the button is meant to be inside
OpenDoor();
introScreen();
while(!coinInserted){
coinSlotSignal = digitalRead(coinSlot);
if(coinSlotSignal < 1) {
coinCount += 1;
coinInserted = true;
EEPROM.write(0,coinCount);
Serial.println(EEPROM.read(0));
lcd.setCursor(0,0);
lcd.print("TOTAL:");
lcd.setCursor(0,1);
lcd.print(coinCount);
while(coinInserted) {
if(coinSlotSignal >0) {
if(coinCount >= requiredCoins) {
delay(1500);
void introScreen()
lcd.clear();
lcd.print("Place finger");
//Main function taken from the "fingerprint" example and modified
//Only the modifications are commented
int getFingerprintIDez() {
uint8_t p = finger.getImage(); //Image scanning
if (p != FINGERPRINT_OK) return -1;
p = finger.image2Tz(); //Converting
lcd.clear(); //And here we write a message or take an action for the denied template
p = finger.fingerFastSearch(); //Looking for matches in the internal memory
if (p != FINGERPRINT_OK){ //if the searching fails it means that the template isn't registered
lcd.print("Access denied");
delay(2000);
introScreen();
return -1;
//If we found a match we proceed in the function
lcd.print("Welcome"); //Printing a message for the recognized template
lcd.setCursor(2,1);
lcd.print(Names[finger.fingerID-1]); //Then print the name we gave it and the -1 is to remove the shift as the ID starts from "1" but the array from "0"
return finger.fingerID;
/*The two following functions depends on your locking system
*mine has a DC motor that should turn in both ways for opening and closing
*that's why I'm using H bridge, you could have a solenoid with a transistor
*then you'll need only opening sequence but controlling the transistor
*as the closing is spring loaded...
void OpenDoor(){
digitalWrite(in2, LOW); // turn on motor
delay(5000);
digitalWrite(in2, HIGH); // turn off motor
