Intruder alarm send Email
Hi
I want My alarm to send an email.
It´s works, but it keep sending mail, until the alarm is reset (pin2 stay HIGH).
It must send 1 email every time pin2 goes HIGH.
some suggestions?
#include <SPI.h>
#include <Ethernet.h>
// Set the panic button pin
byte panicButton2 = 2;
boolean statusCheck = false;
// this must be unique
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
// change network settings to yours
IPAddress ip( XXX, XXX, XXX, XXX );
IPAddress gateway( XXX, XXX, XXX, XXX );
IPAddress subnet( 255, 255, 255, 0 );
// change server to your email server ip or domain
// IPAddress server( 1, 2, 3, 4 );
char server[] = "XXX.XXX.XXX.XXX";
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin2 = 2;     // the number of the pushbutton pin
const int ledPin =  13;         // the number of the LED pin
EthernetClient client;
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  delay(2000);
  Serial.println(F("Ready."));
  pinMode(panicButton2, INPUT);
  if (digitalRead(panicButton2) == HIGH && statusCheck == false)
    if (sendEmail_2()) Serial.println(F("Email sent"));
    else Serial.println(F("Email failed"));
byte sendEmail_2()
  byte thisByte = 0;
  byte respCode;
  if (client.connect(server, 25) == 1) {
    Serial.println(F("connected"));
    Serial.println(F("connection failed"));
    return 0;
  if (!eRcv()) return 0;
  Serial.println(F("Sending helo"));
  // change to your public ip
  client.println(F("helo 1.2.3.4"));
  Serial.println(F("Sending From"));
  // change to your email address (sender)
  client.println(F("MAIL From: <MY@MAIL.COM>"));
  // change to recipient address
  Serial.println(F("Sending To"));
  client.println(F("RCPT To: <YOU@MAIL.COM>"));
  Serial.println(F("Sending DATA"));
  client.println(F("DATA"));
  Serial.println(F("Sending email"));
  client.println(F("To: YOU@MAIL.COM <YOU@MAIL.COM>"));
  // change to your address
  client.println(F("From: ALARM2 <>"));
  client.println(F("Subject: 2 email test buttom\r\n"));
  client.println(F("This is from my Arduino!"));
  client.println(F("."));
  Serial.println(F("Sending QUIT"));
  client.println(F("QUIT"));
  client.stop();
  Serial.println(F("disconnected"));
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  int loopCount = 0;
  while (!client.available()) {
    delay(1);
    loopCount++;
    // if nothing received for 10 seconds, timeout
    if (loopCount > 10000) {
      client.stop();
      Serial.println(F("\r\nTimeout"));
      return 0;
  respCode = client.peek();
  while (client.available())
    thisByte = client.read();
    Serial.write(thisByte);
  if (respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  int loopCount = 0;
    delay(1);
    loopCount++;
      client.stop();
      return;
  client.stop();
Auduino Uno
/Michael
(deleted)
Could also add another variable such as emailSent
if(emailSent == 0 && digitalRead(panicButton2) == HIGH){
   sendemail();
   emailSent = 1;
Then reset emailSent to 0 when the alarm is reset. But as Spycatcher2k mentioned, state change might be the way to go. I've not had a need for state change yet. So, not 100% on how it works.
It is my first project.
I have looked at the State change detection example, but i can not se any solution.
Other suggestions?
