invalid conversation from "int" to "TwoWire"* [-fpermissive] Error HELP!!!!
I'm working on a project and am completely new to the sensors I'm working with so I borrowed some code and over the last three days have gotten really familiar with it... except one line.
#include <Wire.h>
//PWM library
#include <Adafruit_PWMServoDriver.h>
//compass sensor library
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM303_U.h>
//matrix and vector implementation
#include "Matrix.h"
//MPU gyro sensor implementation
#include "Gyro.h"
/************************* variables ****************************/
const int servoCount = 6;
//constants for pulse widths at 12 bit PWM
const int servoPulseMin = 128;
const int servoPulseMax = 640;
const int servoPulseWidth = servoPulseMax - servoPulseMin;
//analog normatization values
int analogMin = 0;
const int analogMax = 1023;
//the from 0 to 0.99999. the higher the smoother the movements but also more delayed
const float attenuation = 0.8;
//reference compass vector
Vector compass0;
//servo ranges [min, max] from 0 to 1. This prevents that the arm hits itself and the servos overheat
float servoRange[servoCount][2] = {
{0.2, 0.9},
{0.35, 0.95},
{0.0, 1},
{0.25, 1},
{0, 0.75},
{0.15, 0.4}};
Vector sensors[4]; //vectors of the sensors
float analog = 0; //last analog reading of the hall effect
float angles[servoCount] = {-1}; //angle values of the joints
float servoValue[servoCount] = {0.5, 0.4, 0.2, 0.25, 0.0, 0.2}; //values the servos will be set to [0; 1]
int reversedRotation[servoCount] = {0, 1, 0, 1, 0, 0}; //needed to reverse rotation for servos that are flipped
float offsetValue[servoCount] = {0.5, 0.4, 0.2, 0.25, 0.0, 0.2}; //offset for the angle 0
//sensor class initializations
Gyro accel1(0, 1, 0x68);
Gyro accel2(0, 1, 0x69);
Adafruit_LSM303_Accel_Unified accel3 = Adafruit_LSM303_Accel_Unified(54321);
Adafruit_LSM303_Mag_Unified mag1 = Adafruit_LSM303_Mag_Unified(12345);
//pwm driver
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
///reads all sensor values and normalizes all except for the magnetometer
void readSensors()
//read the sensor vlaues
accel1.poll();
accel2.poll();
sensors_event_t accel3e;
accel3.getEvent(&accel3e);
sensors_event_t mag1e;
mag1.getEvent(&mag1e);
//set the vectors and normalize
sensors[0] = Vector(accel1.positionA[0], accel1.positionA[1], accel1.positionA[2]);
sensors[0].normalize();
sensors[1] = Vector(accel2.positionA[0], accel2.positionA[1], accel2.positionA[2]);
sensors[1].normalize();
sensors[2] = Vector(accel3e.acceleration.x, accel3e.acceleration.y, accel3e.acceleration.z);
sensors[2].normalize();
sensors[3] = Vector(mag1e.magnetic.x, mag1e.magnetic.y, mag1e.magnetic.z);
//sensors[3].normalize();
//scale the analog reading to [0; 1]
analog = float(analogRead(A0) - analogMin) / (analogMax - analogMin);
///initial calibration, reference values for the gripper and the yaw are read
void calibrate()
//get minimal value when gipper is open
analogMin = analogRead(A0);
//read the sensors
readSensors();
//calculate the absolute compass vector
float a1 = -atan2(-sensors[1][1], -sensors[1][0]);
Matrix r0 = Matrix::rotation(-a1, 0, 1, 0);
float a2 = atan2(sensors[2][1], sensors[2][2]);
Matrix r1 = Matrix::rotation(angles[4], 1, 0, 0);
Vector v = r0 * r1 * sensors[3];
v[2] = 0;
v.normalize();
compass0 = v;
//setup serial
Serial.println("Setup");
//enable gyro sensors
accel1.begin();
accel2.begin();
if(!accel3.begin())
Serial.println("LSM303 accelerometer not detected");
//enable magnetometer
if(!mag1.begin())
Serial.println("LSM303 magnetometer not detected");
//enable pwm board and set the frequency to 50Hz
pwm.begin();
pwm.setPWMFreq(50);
for(int i = 0; i < servoCount; i++)
pwm.setPWM(i, 4096, 0);
//get initial readings
calibrate();
///calculate the servo values form the angles
void setServoAngle(int servo, float angle)
//convert to [0; 1] scale and clip to min max range
float v = max(servoRange[servo][0], min(servoRange[servo][1], angle / float(M_PI) + offsetValue[servo]));
//attenuate if not forst values
if(servoValue[servo] >= 0)
servoValue[servo] = servoValue[servo] * attenuation + v * (1 - attenuation);
servoValue[servo] = v;
///writes the servo values to the servos
void updateServos()
if(servoValue < 0)
  • pwm.setPWM(i, 4096, 0);*
  • else*
    pwm.setPWM(i, 0, int(servoPulseMin + (reversedRotation ? 1 - servoValue: servoValue_) * servoPulseWidth));
    ///turn off a servo
    void disableServo(int servo)
    * servoValue[servo] = -1;
    ///outputs all measured sensor values*
    void printSensors()
    * for(int i = 0; i < 4; i++)
    for(int j = 0; j < 3; j++)
    Serial.print(sensors[j]); Serial.print(' ');
    Serial.print("| ");
    Serial.print(analog);
    Serial.print(" ");
    ///calculates the angles from the sensor values*
    void calculateAngles()
    * //shoulder roll*
    * angles[1] = -atan2(-sensors[0][2], -sensors[0][1]);
    //shoulder pitch*
    * angles[2] = atan2(-sensors[0][0], -sensors[0][1]);
    float elbowPitch = atan2(-sensors[1][0], -sensors[1][1]);
    //setting relative pitch to shoulder*
    * angles[3] = elbowPitch - angles[2];
    //wrist roll*
    * angles[4] = atan2(sensors[2][1], sensors[2][2]);
    //gripper depending on analog value. We take the the square toot to get a linear movement. (point sources attenuate quadratically)
    angles[5] = (sqrt(max(analog, 0.f)) * (servoRange[5][1] - servoRange[5][0])) * M_PI;
    //calculating reverse tansformation for lower arm pitch*
    * float a1 = -atan2(-sensors[1][1], -sensors[1][0]);
    Matrix r0 = Matrix::rotation(-a1, 0, 1, 0);*_
* //calculating reverse transformation of wrist roll*
* float a2 = atan2(sensors[2][1], sensors[2][2]);*
* Matrix r1 = Matrix::rotation(angles[4], 1, 0, 0);*
* //transforming the magnetic field vector back*
_ Vector v = r0 * r1 * sensors[3];
* //switching to flat earth compass*
* v[2] = 0;
v.normalize();
//calculating angle between startup and current compass value*
* Vector a = v.cross(compass0);
angles[0] = -asin(a[2]);
//setting the values*
* setServoAngle(0, angles[0]);
setServoAngle(1, angles[1]);
setServoAngle(2, angles[2]);
setServoAngle(3, angles[3]);
setServoAngle(4, angles[4]);
setServoAngle(5, angles[5]);
void printAngles()
Serial.print(angles); Serial.print(' ');
///main loop*
* static int lastServoUpdate = 0;
//get current time*
* int t = millis();
static int time = 0;
int dt = t - time;
if (time == 0) dt = 0;
time = t;
//read sensors, calculate angles and set servos*
* //servo PWM cant be updated more often than every 20ms*
* if(time - lastServoUpdate > 20)
lastServoUpdate = time;
readSensors();
printSensors();
calculateAngles();
printAngles();
updateServos();
}_
_The problem I'm having is the line I put a lot of dashes over and under. I keep getting this compiling error invalid conversation from "int" to "TwoWire" [-fpermissive] and it happened after I downloaded a new board packet.
Thanks In advanced._
look at the examples, you need to specify 2 parameters or none
I suppose the error comes from the definition of your sensor, as you don't tell the line number of the error. The constructor for the sensor is
Adafruit_PWMServoDriver(TwoWire *I2C = &Wire, uint8_t addr = 0x40);
The examples say
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// you can also call it with a different address and I2C interface
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(&Wire, 0x40);
One parameter is ok, as well as zero or two. So try
Thanks that worked.
Thank You for your help
