Bonjour à tous,
Je suis en train de galérer sur une conversion invalide et je n'arrive pas à m'en sortir.
Je suis ce tuto :
Je vois bien que le problème se situe au niveau de le fonction "void OnDataRecv(const uint8_t * mac_addr, const uint8_t *incomingData, int len)"
Mais je n'arrive pas à trouver ce qui cloche.
Voici mon code :
// Import required libraries
//#include <Arduino.h>
#include <ESP8266WiFi.h>
//#include <Hash.h>
//#include <ESPAsyncTCP.h>
#include <ESPAsyncWebServer.h>
//#include <Adafruit_Sensor.h>
//#include <time.h>
//#include <Wire.h>
#include <espnow.h>// https://github.com/esp8266/Arduino/blob/master/tools/sdk/include/espnow.h
uint8_t broadcastAddress[] = {0x80, 0x7d, 0x3a, 0x44, 0x5a, 0xb6};//80:7d:3a:44:5a:b6
// Replace with your network credentials
const char* ssid = "********";
const char* password = "********";
IPAddress ip(192, 168, 0, 39);
AsyncWebServer server(1039);
// current temperature & humidity, updated in loop()
float t1 = 0.0; // temperature exterieur
float h1 = 0.0; // temperature interieur
float newT1 = 0;
float newH1 = 0;
// Structure example to receive data
// Must match the sender structure
typedef struct struct_message {
int id; // Numéro de la carte emettrice
float t1;
float h1;
} struct_message;
struct_message myData;
// Create a structure to hold the readings from each board
struct_message board1;
struct_message board2;
struct_message board3;
// Create an array with all the structures
struct_message boardsStruct[3] = {board1, board2, board3};
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
<style>
html
font-family: Arial;
display: inline-block;
margin: 0px auto;
text-align: center;
h2 { font-size: 2.5rem; }
p { font-size: 2.5rem; }
.units { font-size: 1.2rem; }
.dht-labels
font-size: 1.5rem;
vertical-align:middle;
padding-bottom: 5px;
</style>
</head>
<body>
<h2>Capteur serre</h2>
<p>
<i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
<span class="dht-labels">Temperature Exterieur</span>
<br>
<span id="temperature1">%TEMPERATURE1%</span>
<sup class="units">°C</sup>
</p>
<p>
<i class="fas fa-tint" style="color:#00add6;"></i>
<span class="dht-labels">Humidity Exterieur</span>
<br>
<span id="humidity1">%HUMIDITY1%</span>
<sup class="units">%%</sup>
</p>
</body>
<script>
setInterval(function ( )
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function()
if (this.readyState == 4 && this.status == 200)
document.getElementById("temperature1").innerHTML = this.responseText;
xhttp.open("GET", "/temperature1", true);
xhttp.send();
}, 10000 ) ;
document.getElementById("humidity1").innerHTML = this.responseText;
xhttp.open("GET", "/humidity1", true);
xhttp.send();
}, 10000 ) ;
</script>
</html>)rawliteral";
// Replaces placeholder with DHT values
String processor(const String& var)
//Serial.println(var);
if(var == "TEMPERATURE INTERIEUR")
return String(t1);
else if(var == "HUMIDITE INTERIEUR")
return String(h1);
return String();
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac_addr, const uint8_t *incomingData, int len) {
char macStr[18];
Serial.print("Packet received from: ");
snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x", mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
Serial.println(macStr);
memcpy(&myData, incomingData, sizeof(myData));
Serial.printf("Board ID %u: %u bytes\n", myData.id, len);
// Update the structures with the new incoming data
boardsStruct[myData.id-1].t1 = myData.t1;
boardsStruct[myData.id-1].h1 = myData.h1;
Serial.printf("temp value: %d \n", boardsStruct[myData.id-1].t1);
Serial.printf("hum value: %d \n", boardsStruct[myData.id-1].h1);
void setup(){
// Serial port for debugging purposes
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_AP_STA);
// Init ESP-NOW
if (esp_now_init() != 0)
Serial.println("Error initializing ESP-NOW");
return;
Serial.print(F("\nReciever initialized : "));
Serial.println(WiFi.macAddress());
// Define receive function
esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
esp_now_register_recv_cb(OnDataRecv);
//dateCourante2=millis();
//pinMode(ledpin, OUTPUT);
IPAddress dnServer(89, 2, 0, 1);
IPAddress gateway(192, 168, 0, 1);
IPAddress subnet(255, 255, 255, 0);
WiFi.config(ip, dnServer, gateway, subnet);
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi");
while (WiFi.status() != WL_CONNECTED)
Serial.println(".");
// Print ESP8266 Local IP Address
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request)
request->send_P(200, "text/html", index_html, processor);
server.on("/temperature1", HTTP_GET, [](AsyncWebServerRequest *request)
request->send_P(200, "text/plain", String(t1).c_str());
server.on("/humidity1", HTTP_GET, [](AsyncWebServerRequest *request)
request->send_P(200, "text/plain", String(h1).c_str());
// Start server
server.begin();
void loop(){
if (newT1 != board1t1 || newH1 != board1h1)
// Read Temp
newT1 = board1t1;
// si la lecture de la température a échoué, ne pas modifier la valeur t1
if (isnan(newT1))
Serial.println("Failed to read from DHT sensor!");
t1 = newT1;
Serial.print("temp : ");
Serial.println(t1);
// Read Humidity
newH1 = board1h1;
// si la lecture de l'humidité a échoué, ne pas modifier la valeur h1
if (isnan(newH1))
h1 = newH1;
Serial.print("hum : ");
Serial.println(h1);
Voici l'erreur :
Compilation error: invalid conversion from 'void (*)(const uint8_t*, const uint8_t*, int)' {aka 'void (*)(const unsigned char*, const unsigned char*, int)'} to 'esp_now_recv_cb_t' {aka 'void (*)(unsigned char*, unsigned char*, unsigned char)'} [-fpermissive]
J'ai essayé de faire d'autres conversions, changer le snprintf en sprintf ou printf, mais tout ce que j'ai essayé n'a pas fonctionné.
Auriez vous un idée d'ou j'ai merdé ?
