invalid conversion from 'byte*' to 'char*'
Hey i try to do an ambilight to my pc, i use Arduino nano 3.0 and arduino IDE 1.0.6.
This is my code:
#include "FastLED.h"
#define NUM_LEDS 38
#define LED_DATA_PIN 3
#define NUM_BYTES 114 // 3 colors
#define BRIGHTNESS 100
#define UPDATES_PER_SECOND 100
#define TIMEOUT 3000
#define MODE_ANIMATION 0
#define MODE_AMBILIGHT 1
uint8_t mode = MODE_ANIMATION;
byte MESSAGE_PREAMBLE[] = {
 0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09 };
uint8_t PREAMBLE_LENGTH = 10;
uint8_t current_preamble_position = 0;
unsigned long last_serial_available = -1L;
uint8_t led_counter = 0;
uint8_t byte_counter = 0;
CRGB leds[NUM_LEDS];
byte buffer[NUM_BYTES];
// Filler animation attributes
CRGBPalette16 currentPalette = RainbowColors_p;
TBlendType    currentBlending = LINEARBLEND;
uint8_t startIndex = 0;
 FastLED.clear(true);
 FastLED.addLeds<WS2811, LED_DATA_PIN, GRB>(leds, NUM_LEDS);
 FastLED.setBrightness(BRIGHTNESS);
 switch (mode) {
 case MODE_ANIMATION:
   fillLEDsFromPaletteColors();
 case MODE_AMBILIGHT:
   processIncomingData();
void processIncomingData()
 if (waitForPreamble(TIMEOUT))
   Serial.readBytes(buffer, NUM_BYTES);
   /* DEBUG
    for (int i = 0; i < NUM_BYTES; i++)
    Serial.write((char)buffer[i]);
   while (byte_counter < NUM_BYTES)
     byte green = buffer[byte_counter++];
     byte blue = buffer[byte_counter++];
     byte red = buffer[byte_counter++];
     leds[led_counter++] = CRGB(red, green, blue);
   FastLED.show();
   byte_counter = 0;
   led_counter = 0;
bool waitForPreamble(int timeout)
 last_serial_available = millis();
 while (current_preamble_position < PREAMBLE_LENGTH)
   if (Serial.available() > 0)
     if (Serial.read() == MESSAGE_PREAMBLE[current_preamble_position])
       current_preamble_position++;
   if (millis() - last_serial_available > timeout)
     return false;
 return true;
void fillLEDsFromPaletteColors()
 startIndex++; // speed
 uint8_t colorIndex = startIndex;
 for( int i = 0; i < NUM_LEDS; i++) {
   leds[i] = ColorFromPalette(currentPalette, colorIndex, BRIGHTNESS, currentBlending);
   colorIndex += 3;
 FastLED.delay(1000 / UPDATES_PER_SECOND);
   mode = MODE_AMBILIGHT;
and Errors
FRZOIE2IOLP17GI.ino: In function ‘void processIncomingData()’:
FRZOIE2IOLP17GI:61: error: invalid conversion from ‘byte*’ to ‘char*’
FRZOIE2IOLP17GI:61: error: initializing argument 1 of ‘size_t Stream::readBytes(char*, size_t)’
What should i do?
Were do you think it might be?
Now, read the error message again, carefully.
When I compile it, it clearly shows me the error is on this line:
This fix allowed it to compile but I didn't try to run it:
  Serial.readBytes((char*)buffer, NUM_BYTES);
