Invalid conversion from "byte*" to "unit8_t"
Hello everybody. Here I have a new problem, I changed a computer and when I try to run a code that I finally understand, I’m told : invalid conversion from “byte*” to “unit8_t” for …pinMode(ledPin,OUTPUT); }
Here is the whole code:
// Project 5 - LED Chase Effect
byte ledPin[] = {4, 5, 6, 7, 8, 9, 10, 11, 12, 13}; // Create array for LED pins
int ledDelay(65); // delay between changes
int direction = 1;
int currentLED = 0;
unsigned long changeTime;
for (int x=0; x<10; x++) { // set all pins to output
changeTime = millis();
if ((millis() - changeTime) > ledDelay) { // if it has been ledDelay ms since
//last change
changeLED();
void changeLED() {
for (int x=0; x<10; x++) { // turn off all LED's
digitalWrite(ledPin, LOW);
digitalWrite(ledPin[currentLED], HIGH); // turn on the current LED
currentLED += direction; // increment by the direction value
// change direction if we reach the end
if (currentLED == 9) {direction = -1;}
if (currentLED == 0) {direction = 1;}
How come? Thank you.
I know, I forget the tell OUTPUT to whom, [x].
It sounds like you have it fixed but it may help others reading this thread to clarify that the problem is that the array index was missing from the ledPin variable:
   pinMode(ledPin[x],OUTPUT);
