invalid conversion from 'char (*)[50]' to 'char'
Hello all! Sorry about my english.
I'm trying to do a sketch that definetly receive a string with some protocol and convert diferent values for doing anything.
The protocol is, start: "[" end:"[". So I can send [V180] and refresh my vertical servo angle, or [H100] and refresh my horizontal servo angle too. But not at the same time. You should send one and after the another.
This is the code (working):
#define baudRate 9600
#define VERDADEIRO 1
#define FALSO 0
char Texto[50];
char *Ponteiro_Texto;
char ucInicial = 0;
void setup(){
  Serial.begin(baudRate);
void loop(){
    while (Serial.available() > 0){
      unsigned char ucRecebe;
     ucRecebe = Serial.read();         // Read data
     if (ucRecebe == '['){             // verify start
         ucInicial = VERDADEIRO;       // Protocol stars here....
         Ponteiro_Texto = Texto;      // restart pointer
     }else if (ucInicial == VERDADEIRO){        // start receive?
         *Ponteiro_Texto = ucRecebe;   // accept data
         Ponteiro_Texto++;             // pointer ++
     if (ucRecebe == ']'){              // verify end
        decodificaSerial();             // execute decodificaSerial
        ucInicial = FALSO;              // Wait for new starter
void decodificaSerial(){
  int posicaoVertical;
  int posicaoHorizontal;
  switch (Texto[0])
    case 'V':
    posicaoVertical = atoi(Texto + 1);
    Serial.print("Angulo servo Vertical: ")  ;Serial.println(posicaoVertical);
    posicaoVertical = 0;
    case 'H':
    posicaoHorizontal = atoi(Texto + 1);
    Serial.print("Angulo servo Horizontal: ");Serial.println(posicaoHorizontal);
    posicaoHorizontal = 0;
    Serial.flush();                      //Limpa buffer Serial para novo tratamento
But the original in a MICROCHIP PIC18F i use this line: Ponteiro_Texto = &Texto; If i tried to use this with Arduino, returns the error:
tratamento_serial.cpp: In function 'void loop()':
tratamento_serial:22: error: invalid conversion from 'char (*)[50]' to 'char'
The code should be:
#define FALSO 0
char Texto[50];
char ucInicial = 0;
void setup(){
void loop(){
         [color=#ff0000]Ponteiro_Texto = &Texto;      // restart pointer[/color]
  switch (Texto[0])
    case 'V':
    case 'H':
Anyone for this error?
Thx in advance and soooo sorry about the english!! hahahaha ;D
You don't really need Ponteiro_Texto. Just create a index variable:
byte index = 0;
Then, where you have:
put:
Texto[0] = '\0';
index = 0;
And where you have:
       Ponteiro_Texto++;
use:
Texto[index] = ucRecebe;
index++;
Texto[index] = '\0';
Get rid of this code:
If some serial data arrived on the port while you were parsing the previous data, you'd throw it away. That's not a good thing to do.
Once you know what the first letter is, change that letter to a '0'.
Texto[0] = '0';
Then, call atoi with Text0.
posicaoHorizontal = atoi(Texto);
