invalid conversion from 'char' to 'const char*' [-fpermissive]
While receiving all data from a BLE device until a '\n' character is received, I get the following error:
My Code:
String dataBLE;
 if (Serial.available() > 0)
        dataBLE = Serial1.readString(); //read Serial1 input and move to String dataBLE
        if (dataBLE == '\n')
          if (dataBLE == -1) //continue reading all of user input
            continue;
        //    DEBUG
        Serial.print(dataBLE);
If you'd both to post the full error message, we would know what line the compiler is complaining about. Post the full code too.
I have a custom PCB 3.3V @ 12MHz with a ATMEGA328PB
I am using the MCUdude/MiniCore Boards File
Full Error message:
D:\GP Technology\Firmware-2019\T-Trax-12-FINAL-27092019\T-Trax-12-FINAL-27092019.ino: In function 'void ReadBeaconBLE()':
T-Trax-12-FINAL-27092019:180:24: error: invalid conversion from 'char' to 'const char*' [-fpermissive]
In file included from C:\Users\Robert\Documents\Arduino\hardware\MiniCore-master\avr\cores\MCUdude_corefiles/Arduino.h:287:0,
                 from C:\Users\Robert\AppData\Local\Temp\arduino_build_922042\sketch\T-Trax-12-FINAL-27092019.ino.cpp:1:
C:\Users\Robert\Documents\Arduino\hardware\MiniCore-master\avr\cores\MCUdude_corefiles/WString.h:143:17: note:   initializing argument 1 of 'unsigned char String::operator==(const char*) const'
   unsigned char operator == (const char *cstr) const {return equals(cstr);}
T-Trax-12-FINAL-27092019:182:27: error: invalid conversion from 'int' to 'const char*' [-fpermissive]
Using library Wire at version 1.0 in folder: C:\Users\Robert\Documents\Arduino\hardware\MiniCore-master\avr\libraries\Wire
Using library AltSoftSerial-master at version 1.4 in folder: C:\Users\Robert\Documents\Arduino\libraries\AltSoftSerial-master
Using library Adafruit_GPS_Library at version 1.1.1 in folder: C:\Users\Robert\Documents\Arduino\libraries\Adafruit_GPS_Library
Using library SoftwareSerial at version 1.1 in folder: C:\Users\Robert\Documents\Arduino\hardware\MiniCore-master\avr\libraries\SoftwareSerial
Using library Arduino_Vcc-master in folder: C:\Users\Robert\Documents\Arduino\libraries\Arduino_Vcc-master (legacy)
exit status 1
Code Attached
Sorry, code attached
Code-Friday.txt (12.3 KB)
if (dataBLE == -1)
What's that supposed to be?
Your "if(serial.available" statement has opening and closing { }.
Why wouldn't you use { } for the other two if statements?
Single quotes (') are used for character literals, double quotes (") are used for string literals.
You cannot compare a string to a single character, try this:
if (dataBLE == "\n")
Your code doesn't make much sense to me. How can dataBLE equal both "\n" and -1 at the same time?
Pieter
PieterP:
Pieter
Sorry, this code was written by a third party.
I'm not a prolific programmer - how should it be done?
Hard to say. Most people on here won't download txt or ino files. Post your full code between code tags (button on the post form looks like </>) and you'll most likely get a lot more help.
Code exceeds the permissible allowed number of characters
The common cure for that is to split it into 2 posts.
