invalid conversion from 'char*' to 'unsigned char*'
Hi !
I don't seem to get pass these errors:
jotain.cpp: In function 'void loop()':
jotain:14: error: invalid conversion from 'char*' to 'unsigned char*'
jotain:14: error: initializing argument 3 of 'void LCD12864R::DisplayStringnew(int, int, unsigned char*)'
This is my code
#include <LCD12864R.h>
char lcdbuffer[10]; // declare buffer
int tulos = 0;
  LCDB.Initialise(); // INIT SCREEN
  delay(500); // Some delay
void loop(){
  tulos = 22; // defying a number for the integer
 sprintf(lcdbuffer, "RPM: %02d%", tulos); //This should do the magic?
 LCDB.DisplayStringnew(0,0,lcdbuffer);;//This should print RPM:22%
while(1);
I'm using two libraries in my project, and they are pretty similar. I was not able to copy the string function from the other library, so I changed all LCDA's to LCDB in that library. This way I can have both libraries in same program.
This is the part from the library that the code is using:
void LCD12864R::DisplayStringnew(int X,int Y,uchar *ptr)
  int i;
  switch(X)
     case 0:  Y|=0x80;break;
     case 1:  Y|=0x90;break;
     case 2:  Y|=0x88;break;
     case 3:  Y|=0x98;break;
     default: break;
  WriteCommand(Y);
   while(*ptr)
      WriteData(ptr++);
 LCDB.DisplayStringnew(0,0,(uchar*)lcdbuffer);;//This should print RPM:22%
jotain:15: error: 'uchar' was not declared in this scope
jotain:15: error: expected primary-expression before ')' token
Do I need to define unchar*?
LCDB.DisplayStringnew(0,0,(unsigned char*)lcdbuffer);//This should print RPM:22%
C:\arduino-0022\libraries\LCD12864R\LCD12864R.cpp: In member function 'void LCD12864R::DisplayStringnew(int, int, unsigned char*)':
C:\arduino-0022\libraries\LCD12864R\LCD12864R.cpp:163: error: invalid conversion from 'unsigned char*' to 'int'
C:\arduino-0022\libraries\LCD12864R\LCD12864R.cpp:163: error: initializing argument 1 of 'void LCD12864R::WriteData(int)'
Here's the library:
LCD12864R
www.DFRobot.com
#include "LCD12864R.h"
//#include "LCDSprite.h"
extern "C"
#include <wiring.h>
#include <inttypes.h>
#include <stdio.h>  //not needed yet
#include <string.h> //needed for strlen()
#include <avr/pgmspace.h>
LCD12864R::LCD12864R()
this->DEFAULTTIME = 300; // 80 ms default time
this->delaytime = DEFAULTTIME;
void LCD12864R::setPins(uint8_t tRS, uint8_t tRW, uint8_t tD7, uint8_t tD6, uint8_t tD5, uint8_t tD4, uint8_t tD3, uint8_t tD2, uint8_t tD1, uint8_t tD0)
  digitalWrite(EN,1);
  delayns();
  digitalWrite(RS, tRS);
  digitalWrite(RW, tRW);
  digitalWrite(D7, tD7);
  digitalWrite(D6, tD6);
  digitalWrite(D5, tD5);
  digitalWrite(D4, tD4);
  digitalWrite(D3, tD3);
  digitalWrite(D2, tD2);
  digitalWrite(D1, tD1);
  digitalWrite(D0, tD0);
  delayns();
  digitalWrite(EN, 0);
  delayns();
//*********************ÑÓʱº¯Êý************************//
void LCD12864R::delayns(void)
delayMicroseconds(delaytime);
void LCD12864R::VectorConverter(int vector)
int result = vector;
for (int i = 7; i >= 0; i--)
this->temp[i] = result % 2;
result = result/2;
void LCD12864R::WriteCommand(int CMD)
   delayns();
   delayns();
   VectorConverter(CMD); // lets get the binary from the dec
   setPins(0,0,this->temp[0],this->temp[1],this->temp[2],this->temp[3],this->temp[4],this->temp[5],this->temp[6],this->temp[7]); //WriteCommand
void LCD12864R::WriteData(int CMD)
   delayns();
   delayns();
   setPins(1,0,this->temp[0],this->temp[1],this->temp[2],this->temp[3],this->temp[4],this->temp[5],this->temp[6],this->temp[7]); //WriteData
void LCD12864R::Initialise(void)
   pinMode(RS, OUTPUT);
   pinMode(RW, OUTPUT);
   pinMode(EN, OUTPUT);
   pinMode(D0, OUTPUT);
   pinMode(D1, OUTPUT);
   pinMode(D2, OUTPUT);
   pinMode(D3, OUTPUT);
   pinMode(D4, OUTPUT);
   pinMode(D5, OUTPUT);
   pinMode(D6, OUTPUT);
   pinMode(D7, OUTPUT);
   delayns();
   WriteCommand(0x30);        //¹¦ÄÜÉ趨¿ØÖÆ×Ö
   WriteCommand(0x0c);        //ÏÔʾ¿ª¹Ø¿ØÖÆ×Ö
//   WriteCommand(0x01);        //Çå³ýÆÁÄ»¿ØÖÆ×Ö
   WriteCommand(0x06);        //½øÈëÉ趨µã¿ØÖÆ×Ö
void LCD12864R::CLEAR(void)
    WriteCommand(0x30);//
    WriteCommand(0x01);//Çå³ýÏÔʾ
void LCD12864R::DisplayString(int X,int Y,uchar *ptr,int dat)
  int i;
  switch(X)
     default: break;
  WriteCommand(Y); // ¶¨Î»ÏÔʾÆðʼµØÖ·
  for(i=0;i<dat;i++)
      WriteData(ptr[i]);//ÏÔʾºº×ÖʱעÒâÂëÖµ£¬Á¬ÐøÁ½¸öÂë±íʾһ¸öºº×Ö
  int i;
  switch(X)
     default: break;
  WriteCommand(Y);
   while(*ptr)
      WriteData(ptr++);
void LCD12864R::DisplaySig(int M,int N,int sig)
  switch(M)
     case 0:  N|=0x80;break;
     case 1:  N|=0x90;break;
     case 2:  N|=0x88;break;
     case 3:  N|=0x98;break;
     default: break;
  WriteCommand(N); // ¶¨Î»ÏÔʾÆðʼµØÖ·
  WriteData(sig); //Êä³öµ¥¸ö×Ö·û
void LCD12864R::DrawFullScreen(uchar *p)
      int ygroup,x,y,i;
      int temp;
      int tmp;
      for(ygroup=0;ygroup<64;ygroup++)           //дÈëÒº¾§ÉϰëͼÏ󲿷Ö
        {                           //дÈë×ø±ê
           if(ygroup<32)
             x=0x80;
             y=ygroup+0x80;
              x=0x88;
              y=ygroup-32+0x80;
           WriteCommand(0x34);        //дÈëÀ©³äÖ¸ÁîÃüÁî
           WriteCommand(y);           //дÈëyÖá×ø±ê
           WriteCommand(x);           //дÈëxÖá×ø±ê
           WriteCommand(0x30);        //дÈë»ù±¾Ö¸ÁîÃüÁî
           tmp=ygroup*16;
           for(i=0;i<16;i++)
		    temp=p[tmp++];
		    WriteData(temp);
        WriteCommand(0x36);        //ÏÔʾͼÏó
LCD12864R LCDB = LCD12864R();
WriteData(ptr++);
Right there.
Did you mean WriteData(*ptr++); ?
The compiler errors are sometimes a bit cryptic, but here, I think they're pretty spot-on.
Thank you wery much!!!
This was the last obstacle with my project (knokking wood).
