Hello,
I am trying to compile the sketch presented here but I ran into this error for this line
if (analogRead(PIN_LDR_SENSOR) < 200) {
invalid conversion from 'int' to 'analog_pin_t' [-fpermissive]
Any idea what I could be missing?
Thanks !
Hello,
Thanks !
Yes.
The posting of the sketch in code tags.
try change this line to
Sure ![]()
#include <avr/sleep.h>
#include <avr/wdt.h>
#define PIN_LED PB0
#define PIN_LDR_POWER PB4
#define PIN_LDR_SENSOR PB3
#define FADE_SPEED 4 // in ms
#define GLOW_TIME 1500 // in ms
#define WAIT_CYCLES 10 // multiplier of watchdog
volatile byte cycles = 0;
ISR(WDT_vect)
cycles++;
pinMode(PIN_LDR_SENSOR, INPUT);
pinMode(PIN_LDR_POWER, OUTPUT);
pinMode(PIN_LED, OUTPUT);
// intro sequence
for(byte i=0; i<5; i++) {
digitalWrite(PIN_LED, HIGH);
delay(40);
digitalWrite(PIN_LED, LOW);
delay(40);
// setup of the WDT
cli();
wdt_reset(); // reset watchdog timer
MCUSR &= ~(1 << WDRF); // remove reset flag
WDTCR = (1 << WDCE); // set WDCE, access prescaler
WDTCR = 1 << WDP0 | 1 << WDP3; // set prescaler bits to to 8s
WDTCR |= (1 << WDTIE); // access WDT interrupt
sei();
digitalWrite(PIN_LDR_POWER, HIGH);
if (cycles >= WAIT_CYCLES) {
glowEyes();
cycles = 0;
digitalWrite(PIN_LDR_POWER, LOW);
enterSleepMode();
void glowEyes()
for (byte i = 0; i < 255; i++) {
analogWrite(PIN_LED, i);
delay(FADE_SPEED);
delay(GLOW_TIME);
for (byte i = 255; i > 0; i--) {
delay(FADE_SPEED);
// be sure the LEDs are turned off!
pinMode(PIN_LED, INPUT);
void enterSleepMode()
byte adcsra;
adcsra = ADCSRA; // save ADC control and status register A
ADCSRA &= ~(1 << ADEN); // disable ADC
MCUCR |= (1 << SM1) & ~(1 << SM0); // Sleep-Modus = Power Down
MCUCR |= (1 << SE); // set sleep enable
sleep_cpu(); // sleep
MCUCR &= ~(1 << SE); // reset sleep enable
ADCSRA = adcsra; // restore ADC control and status register A
Many thanks! That did it.
the proper solution would be to use the expected type and representation
possibly changing
into
const analog_pin_t PIN_LDR_POWER = A2;
const analog_pin_t PIN_LDR_SENSOR = A3;
would be more appropriate than hacking the type?
sheesh. Since when are pin numbers not integers?
If they were going to have their own types, they might as well be objects!
it's an enum
Thank you all for your help !
