invalid conversion from 'unsigned int' to 'Efc*'
Hello,
This code grabs the unique ID on the arduino DUE, but I noticed it throws an error on later versions of the IDE like 1.6.9. It does compile on IDE 1.6.5, but NOT if you include the ethernet library.
The error is: error: invalid conversion from ‘unsigned int’ to ‘Efc*’ [-fpermissive]
I can’t figure out what Efc* is…any help would be great, thank you.
//START due unique ID stuff
#define EFC_ACCESS_MODE_128    0
#define FLASH_ACCESS_MODE_128    EFC_ACCESS_MODE_128
#define EFC0       (0x400E0A00U)
#define EFC       EFC0
uint32_t ul_rc;
   uint32_t unique_id[4];
typedef enum flash_rc {
   FLASH_RC_OK = 0,        //!< Operation OK
   FLASH_RC_YES = 1,       //!< Yes
   FLASH_RC_NO = 0,        //!< No
   FLASH_RC_ERROR = 0x10,  //!< General error
   FLASH_RC_INVALID,       //!< Invalid argument input
   FLASH_RC_NOT_SUPPORT = 0xFFFFFFFF    //!< Operation is not supported
} flash_rc_t;
typedef unsigned long UL;
//END due serial
ul_rc = efc_init(EFC, FLASH_ACCESS_MODE_128, 4);
if (ul_rc != 0) {
Serial.println(" FOUT" );
Serial.println(F("SAM3X8E 128bit Unique ID (dwords in HEX)"));
ul_rc = flash_read_unique_id(unique_id, 4);
Serial.print(F("ID = " ));
for (uint8_t i=0; i<4;i++) {
  Serial.print((UL)unique_id[i],HEX);
  if (i<3) {Serial.print("-");}
}//end setup
uint32_t flash_read_unique_id(uint32_t *pul_data, uint32_t ul_size)
   uint32_t uid_buf[4];
   uint32_t ul_idx;
   if (FLASH_RC_OK != efc_perform_read_sequence(EFC, EFC_FCMD_STUI,
         EFC_FCMD_SPUI, uid_buf, 4)) {
      return FLASH_RC_ERROR;
   if (ul_size > 4) {
      /* Only 4 dword to store unique ID */
      ul_size = 4;
   for (ul_idx = 0; ul_idx < ul_size; ul_idx++) {
      pul_data[ul_idx] = uid_buf[ul_idx];
   return FLASH_RC_OK;
}//end main loop
I guess the error arises here
EFC is just a number, defined here:
#define EFC       EFC0
If the magic number is correct
#define EFC ((Efc*)EFC0)
should satisfy the more picky new compiler settings.
Is "EFC0" supposed to be hexadecimal number? If so, make that 0xEFC0 ...
kind regards,
Jos
EFC0 is a name for the number 0x400E0A00 which is in reality an address.
michael_x: If the magic number is correct
Thanks for the assistance, however i'm still getting the following error with that change...
'Efc' was not declared in this scope
any ideas?
#define EFC       EFC0
Remove the EFC0 definition, it is already defined in the header files.
Hey,
by using your sketch, I get the following error.
efc_init' was not declared in this scope
Can you help me ?
