invalid conversion from void to int
i have wrote this code for a object advoidance robot but cannot get it to compile the error code is for invalid conversion from void(*) to int the code is as followes
#include <Servo.h>
int motor_reset = 2; //digital pin 2 assigned to motor reset
Servo scanServo; // create servo object to control the scanning servo
int pos = 0; // variable to store the servo position
int aDelay = 250; // Delay for the servo and let the IR to return results
int readDistance1 ; // Variable to keep IR right scan value
int readDistance2 ; // Variable to keep IR forward scan value
int readDistance3 ; // Variable to keep IR left scan value
int minDistanceLimit = 4 ; // Distance to set as Obstacle
int pingPin = 8;
  pinMode(motor_reset, OUTPUT);
  scanServo.attach(11); // attaches the servo on pin 11 to the servo object
  digitalWrite(motor_reset, LOW);
  delay(10);
  digitalWrite(motor_reset, HIGH);
  delay(10);
void cm(){
  long duration, cm;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  cm = microsecondsToCentimeters(duration);
//  long duration, cm;
//  pinMode(pingPin, OUTPUT);
//  digitalWrite(pingPin, LOW);
//  delayMicroseconds(2);
//  digitalWrite(pingPin, HIGH);
//  delayMicroseconds(5);
//  pinMode(pingPin, INPUT);
//  duration = pulseIn(pingPin, HIGH);
//  cm = microsecondsToCentimeters(duration);
  for (pos = 35; pos <= 89; pos ++) //scan IR sensor from 35 to 165 degs from left to right
    scanServo.write (pos); //writes the position to scanning servo
    delay(3); //give it time to get there
  readDistance1 = cm; //take an IR reading at 89 - ahead
  if (readDistance1 > minDistanceLimit){
    reverse; // if obstacle distance is closer than threshold go in opposite direction
    forward(); //continue going forward
    for (pos = 90; pos <= 165; pos ++) //scan IR sensor from 35 to 165 degs from left to right
  readDistance2 = cm; //take an IR reading at 165 - rightside
  if (readDistance2 > minDistanceLimit){  // if obstacle distance is closer than threshold go in opposite direction
    rotateLeft;
    for (pos = 165; pos >=90; pos --) //scans right to left
    delay (3);
  readDistance1 = cm;
    reverse;
    forward();
  for (pos = 89; pos >= 35; pos --) //scan IR sensor from 35 to 165 degs from left to right
  readDistance3 = cm; //take an IR reading at 35 - leftside
  if (readDistance3 > minDistanceLimit){
    rotateRight; // if obstacle distance is closer than threshold go in opposite direction
long microsecondsToCentimeters(long microseconds)
  return microseconds / 29 / 2;
void moveMotor (unsigned char motor, unsigned char speed)
  //left motor
  unsigned char buff3[6];
  buff3[0]=0x80;
  buff3[1]=0x00;
  buff3[2]=0x00;
  buff3[3]=0x00;
  for(int i=0; i<4; i++) {
    Serial.print(buff3[i], BYTE);
  //right motor
  unsigned char buff4[6];
  buff4[0]=0x80;
  buff4[1]=0x00;
  buff4[2]=0x02;
  buff4[3]=0x00;
    Serial.print(buff4[i], BYTE);
void forward()
  moveMotor (1, 0x7A);//right motor
  moveMotor (3, 0x7A);//left motor
void rotateRight()
  moveMotor (1, 0x50);
  moveMotor (2, 0x40);
void rotateLeft()
  moveMotor (0, 0x40);
  moveMotor (3, 0x50);
void reverse()
  moveMotor (0, 0x45);
  moveMotor (2, 0x45);
void leftTurn()
  moveMotor (1, 0x20);
  moveMotor (3, 0x20);
void rightTurn()
  moveMotor (1, 0x30);
  moveMotor (3, 0x30);
the error occurs on this line and others like it: readDistance1 = cm; //take an IR reading at 89 - ahead
please help me learn what im doing wrong
In the function cm() the variable 'cm' is local so it does not exist outside the function. If you want to use the value in another function you must make it global (declared outside any function).
Perhaps you would be better served by returning a value from the cm() function.
long cm(){
  long duration;
  return microsecondsToCentimeters(duration);
Then you can use "readDistance1 = cm();", etc.
At the scope where you are trying to assign a vairable to the contents of "cm", the symbol "cm" refers to the function "cm()" which is declared "long".
This "cm" is the pointer (void *) to the function.
(void *) is not (int).
To call the function and return a value you must suffix it with () to indicate that you are wanting to call the function, and not manipulate the address of the function.
