i have an error
but i dont understand and i have no skill in electronics and i have an arduino uno r3 from creation crate(not sure if that changes anything)my project is a memory game and here in my code so far. thanks!
const int button1=2;
const int button2=3;
const int button3=4;
const int button4=5;
const int led1=7;
const int led2=8;
const int led3=9;
const int led4=10;
const int buzzer=12;
const int tones[]={1900,1600,1300,1000,3200};
int buttonState[]={0,0,0,0};
int lastButtonState[]={0,0,0,0};
int buttonCounter[]={0,0,0,0};
int game0n=0;
int wait=0;
int currentLevel=1;
int dlay=500;
int ledTime=500;
int n_levels=10;
int pinAndTone=0;
int correct=0;
int speedFactor=5;
int ledDelay=200;
Please read the post at the start of any forum , entitled "How to use this Forum".
OR http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
/tmp/961973469/build/../../core/core_Intel_arc32_arduino_101_ce7885b3d89440f4810c5db77fdcac10.a(main.cpp.o): In function main': /home/builder/.arduino15/packages/Intel/hardware/arc32/2.0.4/cores/arduino/main.cpp:43: undefined reference to setup'
/home/builder/.arduino15/packages/Intel/hardware/arc32/2.0.4/cores/arduino/main.cpp:47: undefined reference to `loop'
collect2: error: ld returned 1 exit status
exit status 1
bobskelebone:
okay now i get the following error message
exit status 1
so what does it mean?
Your sketch does not contain the setup() and loop() functions.
I suggest that you start with some example sketches and see if you can figure out what is common between all of them. You don't even have to compile them.
sterretje:
OR http://forum.arduino.cc/index.php/topic,148850.0.html. Then look down to item #7 about how to post your code.
