invalid defice signature
I bought blank ATmega238P chips. I uploaded on all chips bootloader using arduino mega as isp and they worked. Then, I uploaded to two of chips sketch(upload using programmer) to control 7-segment display, so the chip is using all digital pins as output. Then, I found a misteake in the sketch, so I wanted to change it, but when I select "upload using programmer", i got the invalid device signature error. I tried to burn new bootloader, but i got the same error. I tried to disconnect this chip from breadboard and I putted there chip with blink (It is connect same as chip before) and burning and uploading works. So I out back the chip with 7-segment display sketch and i again get device signature failure, even if it is connected same as working chip with blink. What should I do to get chip working again?
Copy and paste the entire error message so we can see se signature, maybe it's a variant of Atmega328.
I'm not sure how you're uploading your sketch with the programmer, but if you're using ISCP, make sure ping 11-13 are not used by anything else.
ariejan:
Yes, i using all available pins on chip (D0-D13) have setted pinmode to output, and all analog pins are used as input (the chip is used to control 2-digits 7-segments display)
mart256:
^what he just said^
Without the error message, it's all just guessing
C-F-K:
mart256:
^what he just said^
It write just:
Yeks, invalid devoce signature. Double check connections or use -F to override
parmanik:
C-F-K:
mart256:
^what he just said^
It write just:
It should say something like:
Read device signature
Expected device signature
Just copy the entire avrdude window.
C-F-K:
parmanik:
C-F-K:
mart256:
^what he just said^
It write just:
It says only:
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Turn on the verbose if using Arduino IDE, to check which is the signature.
mart256:
I enabled it, click burn bootloader and i got this in error window:
C:\Program Files (x86)\Arduino\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM6 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xde:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM6
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [ff]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.06s
avrdude: Device signature = 0xffffff
         this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
A signature of 0xFFFFFFFF (constant high) or 0x00000000 (constant low) either indicate a wire failure or a broken MCU.
C-F-K:
Fu*k. i only uploaded sketch on it, I haven't used the chip in a circuit
parmanik:
C-F-K:
First check the wires and other components. It's possible you have 2 wires crossed or one of the components is unconnected.
A MCU can go bad very easy if you don't handle it correct. I broke a few not to long ago because our new soldering iron wasn't grounded properly (floating tip).
