attach the file libraryfolders.txt on your desktop to a post here.
This will create a printout of your all files in your library folder which will allow me to see what changes need to be made to the folder structure of those libraries to make them valid.
I was able to fix the time folder problem. It had a duplicate "time" folder.
However, the vtserial directory has only vtserial.ino in it.
I'll send the file you asked for.
Ok, Thanks. That took care of that problem. And, I learned something!
Now, I get com errors and after uploading, the IDE hangs and doesn't ack the finished upload.
Here's the errors I get. I have never had this happen before. It also keeps the com port busy. use of the IDE terminal is refused. The only way to reset this situation is to unplug the USB cable.
Sketch uses 24,506 bytes (9%) of program storage space. Maximum is 253,952 bytes.
Global variables use 4,549 bytes (55%) of dynamic memory, leaving 3,643 bytes for local variables. Maximum is 8,192 bytes.
