Hi im just trying out arduino as a beginner and i've been using examples provided in arduino which is Blink.
Im currently using esp8266 ESP-12E
This is the error messages:
Arduino: 1.8.13 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, All Flash Contents, 115200"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\irfan\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\irfan\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\irfan\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=legacy,ssl=all,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=all,baud=115200 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\irfan\AppData\Local\Temp\arduino_build_728102 -warnings=none -build-cache C:\Users\irfan\AppData\Local\Temp\arduino_cache_662244 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs-2.5.0-4-b40a506.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-4-b40a506.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506 -prefs=runtime.tools.python3.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\2.5.0-4-fe5bb56 -prefs=runtime.tools.mklittlefs-2.5.0-4-fe5bb56.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\2.5.0-4-fe5bb56 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\irfan\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\irfan\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\irfan\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=legacy,ssl=all,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=all,baud=115200 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\irfan\AppData\Local\Temp\arduino_build_728102 -warnings=none -build-cache C:\Users\irfan\AppData\Local\Temp\arduino_cache_662244 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-4-b40a506 -prefs=runtime.tools.mkspiffs-2.5.0-4-b40a506.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-4-b40a506.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506 -prefs=runtime.tools.python3.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mklittlefs.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\2.5.0-4-fe5bb56 -prefs=runtime.tools.mklittlefs-2.5.0-4-fe5bb56.path=C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\2.5.0-4-fe5bb56 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4
Using core 'esp8266' from platform in folder: C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4
Detecting libraries used...
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include" "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include" "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\irfan\AppData\Local\Temp\arduino_build_728102/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_NODEMCU"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266" "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\variants\nodemcu" "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102\sketch\Blink.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include" "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include" "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\irfan\AppData\Local\Temp\arduino_build_728102/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_NODEMCU"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266" "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\variants\nodemcu" "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102\sketch\Blink.ino.cpp" -o "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/signing.py" --mode header --publickey "C:\Program Files (x86)\Arduino\examples\01.Basics\Blink/public.key" --out "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/core/Updater_Signing.h"
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/include" "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lwip2/include" "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\irfan\AppData\Local\Temp\arduino_build_728102/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_NODEMCU"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266" "-IC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\variants\nodemcu" "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102\sketch\Blink.ino.cpp" -o "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\irfan\AppData\Local\Temp\arduino_cache_662244\core\core_df50309798498f3a6d3dd2f576100659.a
Linking everything together...
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/local.eagle.app.v6.common.ld"
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-gcc" -fno-exceptions -Wl,-Map "-Wl,C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.map" -g -w -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lib" "-LC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/lib/NONOSDK22x_190703" "-LC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/ld" "-LC:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/lib" -Teagle.flash.4m2m.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.elf" -Wl,--start-group "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102\sketch\Blink.ino.cpp.o" "C:\Users\irfan\AppData\Local\Temp\arduino_cache_662244\core\core_df50309798498f3a6d3dd2f576100659.a" -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -laxtls -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group "-LC:\Users\irfan\AppData\Local\Temp\arduino_build_728102"
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/elf2bin.py" --eboot "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/bootloaders/eboot/eboot.elf" --app "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.elf" --flash_mode dio --flash_freq 40 --flash_size 4M --path "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin" --out "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.bin"
Creating BIN file "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.bin" using "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/bootloaders/eboot/eboot.elf" and "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.elf"
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/signing.py" --mode sign --privatekey "C:\Program Files (x86)\Arduino\examples\01.Basics\Blink/private.key" --bin "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.bin" --out "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.bin.signed" --legacy "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.bin.legacy_sig"
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sizes.py" --elf "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.elf" --path "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin"
Executable segment sizes:
IROM : 228624 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26756 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1248 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 688 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24880 ) - zeroed variables (global, static) in RAM/HEAP
"C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506/bin/xtensa-lx106-elf-size" -A "C:\Users\irfan\AppData\Local\Temp\arduino_build_728102/Blink.ino.elf"
Sketch uses 257316 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26816 bytes (32%) of dynamic memory, leaving 55104 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM4
Connecting......
Traceback (most recent call last):
File "C:\Users\irfan\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py", line 65, in
esptool.main(cmdline)
File "C:/Users/irfan/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2900, in main
print("Chip is %s" % (esp.get_chip_description()))
File "C:/Users/irfan/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 1034, in get_chip_description
efuses = self.get_efuses()
File "C:/Users/irfan/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 1030, in get_efuses
self.read_reg(0x3ff00054) << 32 |
File "C:/Users/irfan/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 490, in read_reg
val, data = self.command(self.ESP_READ_REG, struct.pack('<I', addr))
File "C:/Users/irfan/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 347, in command
p = self.read()
File "C:/Users/irfan/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 292, in read
return next(self._slip_reader)
File "C:/Users/irfan/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2057, in slip_reader
raise FatalError('Invalid head of packet (0x%s)' % hexify(b))
esptool.FatalError: Invalid head of packet (0xC2)
