i have writen a code in tinkercard and i am getting a invalid geader file error. please help.
// C++ code
#include <Adafruit_LiquidCrystal.h>
#include <IRremote.h>
int Passkey = 0;
Adafruit_LiquidCrystal lcd_1(0);
// Map the IR code to the corresponding remote button.
// The buttons are in this order on the remote:
// 0 1 2
// 4 5 6
// 8 9 10
// 12 13 14
// 16 17 18
// 20 21 22
// 24 25 26
// Return -1, if supplied code does not map to a key.
int mapCodeToButton(unsigned long code) {
// For the remote used in the Tinkercad simulator,
// the buttons are encoded such that the hex code
// received is of the format: 0xiivvBF00
// Where the vv is the button value, and ii is
// the bit-inverse of vv.
// For example, the power button is 0xFF00BF000
// Check for codes from this specific remote
if ((code & 0x0000FFFF) == 0x0000BF00) {
// No longer need the lower 16 bits. Shift the code by 16
// to make the rest easier.
code >>= 16;
// Check that the value and inverse bytes are complementary.
if (((code >> 8) ^ (code & 0x00FF)) == 0x00FF) {
return code & 0xFF;
return -1;
int readInfrared() {
int result = -1;
// Check if we've received a new code
if (IrReceiver.decode()) {
// Get the infrared code
unsigned long code = IrReceiver.decodedIRData.decodedRawData;
// Map it to a specific button on the remote
result = mapCodeToButton(code);
// Enable receiving of the next value
IrReceiver.resume();
return result;
lcd_1.begin(16, 2);
IrReceiver.begin(5);
Serial.println("system initalizing");
lcd_1.setBacklight(1);
lcd_1.display();
lcd_1.clear();
Serial.println("welcome screen displayed");
lcd_1.setCursor(4, 0);
lcd_1.print("welocme!");
delay(3000); // Wait for 3000 millisecond(s)
lcd_1.clear();
lcd_1.setCursor(0, 0);
lcd_1.print("lets get set up!");
Serial.println("printed lets get set up to lcd");
lcd_1.clear();
lcd_1.print("please hit a key");
lcd_1.setCursor(1, 1);
lcd_1.print("it will be your ");
Serial.println("please hit a key was printed to lcd");
lcd_1.clear();
lcd_1.print("code key. this ");
lcd_1.print("key will disarm");
Serial.println("this key will disarm was printed to lcd");
lcd_1.clear();
lcd_1.print("your system");
Serial.println("your system was printed to lcd");
if (1 > -1) {
Passkey = readInfrared();
