"invalid header file"
My first Arduino project, I am creating an alarm system for machine processing.
This is my code:
#include <Wire.h>
// Pin definitions
const int relayRed = 8;     // Relay for red light
const int relayYellow = 9;  // Relay for yellow light
const int relayGreen = 10;  // Relay for green light
const int relaySiren = 11;  // Relay for siren
const int buttonPin = 2;    // Button to control the system
const unsigned long loadCycleTime = 60000; // Load cycle time in milliseconds (e.g., 60 seconds)
// Adjust the address and dimensions if your LCD is different
LiquidCrystal_I2C lcd(0x27, 16, 2); // Initialize the LCD, adjust the address if needed
unsigned long startTime;
bool cycleRunning = false;
bool buttonPressed = false;
bool lastButtonState = HIGH; // Initial state of the button
  pinMode(relayRed, OUTPUT);
  pinMode(relayYellow, OUTPUT);
  pinMode(relayGreen, OUTPUT);
  pinMode(relaySiren, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  digitalWrite(relayRed, HIGH);   // Red light on initially (relay off)
  digitalWrite(relayYellow, LOW); // Yellow light off
  digitalWrite(relayGreen, LOW);  // Green light off
  digitalWrite(relaySiren, LOW);  // Siren off
  // Initialize the LCD with its dimensions and I2C address
  lcd.begin(); // No parameters needed here, defaults to 16x2 and 0x27 address
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("Time Left:");
  bool currentButtonState = digitalRead(buttonPin);
  if (currentButtonState == LOW && lastButtonState == HIGH && !buttonPressed) {
    delay(50); // Debounce delay
    buttonPressed = true;
    lastButtonState = LOW;
    if (!cycleRunning) {
      startTime = millis();
      cycleRunning = true;
      digitalWrite(relayRed, LOW);    // Turn off red light
      digitalWrite(relayYellow, HIGH); // Turn on yellow light
      resetSystem(); // Reset system when button is pressed during siren
  } else if (currentButtonState == HIGH) {
  if (cycleRunning) {
    unsigned long elapsedTime = millis() - startTime;
    if (elapsedTime < loadCycleTime) {
      unsigned long remainingTime = (loadCycleTime - elapsedTime) / 1000;
      lcd.setCursor(10, 0);
      lcd.print(remainingTime);
      lcd.print(" s  ");
      digitalWrite(relayYellow, LOW); // Turn off yellow light
      digitalWrite(relayGreen, HIGH); // Turn on green light
      digitalWrite(relaySiren, HIGH); // Turn on siren
      cycleRunning = false; // Stop the cycle
void resetSystem() {
  digitalWrite(relayRed, HIGH);   // Turn on red light
  digitalWrite(relayGreen, LOW);  // Turn off green light
  digitalWrite(relaySiren, LOW);  // Turn off siren
  lcd.print("       ");
Any help would be appreciated
And where is your question?
great job posting your code using code tags.
Next up - post your complete error message using those same code tags and it will let folks to help.
Which exact LiquidCrystal_I2C library are you using?
