invalid initialization of non-const reference of type 'CTime&' from an rvalue of
Alright....how do I declare these functions?
CTime CProgramStation::getStartTime()
  CTime time(0, m_nStartHour, m_nStartMinute, 0);
  return time;
CTime CTime::operator =(CTime timeOther)
  m_nDOY = timeOther.m_nDOY;
  m_nHours = timeOther.m_nHours;
  m_nMinutes = timeOther.m_nMinutes;
  m_nSeconds = timeOther.m_nSeconds;
  return *this;
So that I can use them like this:
m_time = m_arrayStations[nStation - 1].getStartTime();
/* CProgramStation m_arrayStations[MAX_STATIONS]*/
Without getting this compile error
I am sure this sort of thing is a great deal easier in MS Visual C++.
You can do things like this without any hassle
return CString("CCCCCC");
You'd be wrong. The resulting code in the IDE and Microslop's tool is standard C++ code.
Why would lop off the most important parts of the error message?
I'm nearly certain that your code would be far simpler if you were taking/returning pointers to instances rather than objects.
Post ALL of your code.
How can yo possibly expect someone to propose a solution (much less compile it) without at least the full declaration and definition of the class? One would think that after 1200+ post you would have figured that out by now.
gfvalvo:
This is a long way from a trivial project - tens of thousands of lines of code and 30 odd source files.
So I am not sure it is practical to post all my code so that you can compile it.
It is a generic programing problem here - nothing that is specific to my project.
One function returns an object (not a reference to an object) and another function takes an object (not a reference to an object) as a parameter.
I don't understand where the compiler thinks the lvalue is.
boylesg:
Agreed, nobody wants to look through that much clutter. Post an MCVE.
It's clearly on line n, as indicated in the compiler message that you truncated.
