*Please can help me. I want to scan multiple Nano 33 Ble sense and Nicla Sense Me cards. Then they connect to post the data.*
*Here are the errors they show me on the screen.*
**test__arduino_portenta.ino: In function 'void loop()':
test__arduino_portenta:151:28: error: invalid initialization of reference of type 'SenseMeData&' from expression of type 'BLEDevice'
printData(peripherals[i] ,true );
\test__arduino_portenta.ino:265:6: note: in passing argument 1 of 'void printData(SenseMeData&, bool)'
void printData(SenseMeData& senseMeData, bool printMode)
\test__arduino_portenta.ino: In function 'void connect_to_peripherals(int)':
\test__arduino_portenta:240:68: error: invalid conversion from 'const char*' to 'uint16_t {aka short unsigned int}' [-fpermissive]
auto isArduino = checkCompany(peripherals[i], ArduinoCompanyID);
\test__arduino_portenta.ino:183:6: note: initializing argument 2 of 'bool checkCompany(const BLEDevice&, uint16_t)'
bool checkCompany(const BLEDevice& peripheral, const uint16_t companyId)
\test__arduino_portenta:243:33: error: 'peripheral' was not declared in this scope
auto data = getData(peripheral[i]);
\test__arduino_portenta.ino:243:33: note: suggested alternative: 'peripherals'
peripherals
\test__arduino_portenta:244:28: error: 'class BLEDevice' has no member named 'data'
peripherals[i].data;
\test__arduino_portenta:246:32: error: invalid initialization of reference of type 'SenseMeData&' from expression of type 'BLEDevice'
printData(peripherals[i], true);
exit status 1
//#include
#include <ArduinoBLE.h> // Bluetooth Library
#include <Arduino_DebugUtils.h>
#include <map>
#define ArduinoCompanyID "0x09A3"
// define max number of peripherals we want Scan
#define BLE_MAX_PERIPHERALS 15
// max interval for find peripherals
#define BLE_SCAN_INTERVALL 10000
// array of scaned peripherals
BLEDevice peripherals[BLE_MAX_PERIPHERALS];
// Build with --build-property "build.extra_flags=-DSNS_DBG_LEVEL=DBG_INFO -DSNS_DBG_TIMESTAMP=1"
#if !defined(SNS_DBG_LEVEL)
#define SNS_DBG_LEVEL DBG_INFO
#endif
#if !defined(SNS_DBG_TIMESTAMP)
#define SNS_DBG_TIMESTAMP 1
#endif
#if !defined(SNS_PRINT_CSV)
#define SNS_PRINT_CSV 0
#endif
constexpr auto debugLevel { SNS_DBG_LEVEL };
constexpr bool debugTimestamp { SNS_DBG_TIMESTAMP };
constexpr bool printModeCSV { SNS_PRINT_CSV };
// final number of connected peripherals
int peripheralsConnected = 0;
// array of valid name of peripherals
String validperipheralNames[7] = { "Nano 1 data" ,"Nano 2 data" ,"NiclaSenseME Advertising Data","NANO_3" ,"Nicla" ,"NANO_6" ,"NANO_7" } ;
struct __attribute__((packed)) SenseMeData {
String address;
unsigned long latest;
unsigned long elapsed;
uint16_t company;
float temperature;
int16_t acc_x;
int16_t acc_y;
int16_t acc_z;
int16_t gyro_x;
int16_t gyro_y;
int16_t gyro_z;
// A simple constructor
SenseMeData(const uint8_t* data)
memcpy((void*)&company, data, 2);
memcpy((void*)&temperature, data + 2, sizeof(float));
memcpy((void*)&acc_x, data + 6, sizeof(int16_t));
memcpy((void*)&acc_y, data + 8, sizeof(int16_t));
memcpy((void*)&acc_z, data + 10, sizeof(int16_t));
memcpy((void*)&gyro_x, data + 12, sizeof(int16_t));
memcpy((void*)&gyro_y, data + 14, sizeof(int16_t));
memcpy((void*)&gyro_z, data + 16, sizeof(int16_t));
SenseMeData(const String addr, const unsigned long now, const unsigned long prev, const uint8_t* data)
address = addr;
latest = now;
elapsed = now - prev;
//constexpr uint16_t ArduinoCompanyID { 0x09A3 };
std::map<String, unsigned long> prevMillis {};
constexpr auto changeStatusInterval { 500ul };
auto changeStatusNow { 0ul };
// set of central
Debug.setDebugLevel(debugLevel);
if (debugTimestamp)
Debug.timestampOn();
for (const auto timeout = millis() + 2500; millis() < timeout && !Serial; delay(250))
if (!BLE.begin()) {
Debug.print(DBG_WARNING, "Starting BLE failed!");
while (1);
if (!printModeCSV)
Debug.print(DBG_INFO, "Arduino BLE Manufacturer Data Sensor");
changeStatusNow = millis() + changeStatusInterval;
BLE.begin();
BLE.scanForUuid( ArduinoCompanyID ); // scaning for finding peripherals with the input service UUID
int peripheralCounter = 0; // count founded peripherals
unsigned long startMillis = millis();
// Continue until either the number of repetitions or the number of peripherals reaches its maximum
while ( millis() - startMillis < BLE_SCAN_INTERVALL && peripheralCounter < BLE_MAX_PERIPHERALS )
//Serial.println("wile is started");
BLEDevice peripheral = BLE.available(); // return one BLEDevice( peripherals)
//Serial.println("Serching started");
Serial.println(BLE.available());
if ( peripheral ) { // if peripherals exist
if (isValidPeripheral(peripheral.localName())) // check name of founded peripheral
if( !is_prepheral_repeated( peripheral, peripheralCounter) ){// If device was not found before
peripherals[peripheralCounter] = peripheral; // add peripheral to array of founded peripherals
peripheralCounter++; // increase founded peripherlas number
Serial.println(peripherals[peripheralCounter]);
// Serial.println("wile is End");
BLE.stopScan(); // stop scanning for new peripherals
Serial.println ("Stooop scaaaan") ;
connect_to_peripherals ( peripheralCounter ) ;
Serial.println("connect_to_peripherals");
// print the all data peripherals
for ( int i = 0; i < peripheralsConnected; i++ )
boolean is_prepheral_repeated( BLEDevice peripheral ,int peripheralCounter ) {
Serial.println( peripheral.localName() ) ;
boolean peripheralAlreadyFound = false; //boolean use for detect duplication of peripheral
for ( int i = 0; i < peripheralCounter; i++ ) // Checks this peripheral has already been found or not
if ( peripheral.address() == peripherals[i].address() )
peripheralAlreadyFound = true;
break ;
return peripheralAlreadyFound ;
bool checkManufacturerData(const BLEDevice& peripheral)
// Skip packets w/o Manufacturer Data
if (!peripheral.hasManufacturerData())
return false;
return true;
// Get the raw advertising data
auto manufLen = peripheral.manufacturerDataLength();
uint8_t manufData[manufLen] {};
auto _ret = peripheral.manufacturerData(manufData, manufLen);
SenseMeData senseMeData { manufData };
// Filter by Company ID
if (senseMeData.company != companyId)
return false;
return true;
SenseMeData getData(const BLEDevice& peripheral)
const auto now = millis();
const auto manufLen = peripheral.manufacturerDataLength();
const auto _ret = peripheral.manufacturerData(manufData, manufLen);
const auto hexData = toHexString(manufData, manufLen);
Debug.print(DBG_DEBUG, "Manufacturer Data: %s", hexData.c_str());
const auto prev = prevMillis[peripheral.address()];
prevMillis[peripheral.address()] = now;
const SenseMeData senseMeData { peripheral.address(), now, prev, manufData };
return senseMeData;
String toHexString(const uint8_t data[], const size_t len)
String hexString;
hexString.reserve(len * 2 + 1);
for (auto i = 0u; i < len; i++) {
if (data[i] < 0x10)
hexString += "0";
hexString += String(data[i], HEX);
return hexString;
void connect_to_peripherals (int peripheralCounter ) {
for ( int i = 0; i < peripheralCounter; i++ ) // for each founded peripherals
Serial.println(peripherals[i].localName()) ;
peripherals[i].connect() ; // connect to peripheral
peripherals[i].discoverAttributes();
Debug.print(DBG_DEBUG, "CHECK_COMPANY: %s", isArduino ? "OK" : "KO");
if (isArduino) {
// Do something with data
Serial.println("no character..."); // if characteristic not exist print this
peripheralsConnected = peripheralCounter;
// check input name is valid peripherals name
boolean isValidPeripheral( String fullname ) {
for( int i= 0 ; i < 7 ; i++){
if( fullname == validperipheralNames[i]) {
return true ;
return false ;
if (printMode == 0) {
Debug.print(DBG_INFO, "=== === === === === === ===");
Debug.print(DBG_INFO, "Address: %s", senseMeData.address.c_str());
Debug.print(DBG_INFO, "Temperature: %.2f", senseMeData.temperature);
Debug.timestampOff();
Debug.print(DBG_INFO, "%d,%d,%s,%.2f,%d,%d,%d,%d,%d,%d", senseMeData.latest, senseMeData.elapsed, senseMeData.address.c_str(), senseMeData.temperature, senseMeData.acc_x, senseMeData.acc_y, senseMeData.acc_z, senseMeData.gyro_x, senseMeData.gyro_y, senseMeData.gyro_z);
