Invalid Library
This .Zip file does not contain a sketch, check the file and try again. i'm having this problem while importing the AMS5812 pressure sensor library file what to do plzz help.
That you got from where?
what to do
Use proper punctuation and capital letters where required.
plzz help.
Text-speak not spoken here.
Dargoon:
What problem would that be?
i'm currently working on a project which includes a AMS5812 absolute pressure sensor i'm getting output in milli bars as i want to change the unit using push button using switch case function i'm able to do but the value is not refreshing at every 500msec as i give the delay to refresh the value when ever i switch between the case.
Dargoon:
That probably means something to you.
Please try again.
If you write your code the same way you write posts here, without any CAPITALS or punctuation marks then that's why you're in trouble.
The problem is definitely somewhere in the code (that you haven't shown us) or in the way your circuit (that you haven't shown us) is put together.
Steve
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
We need this information so we know what you are asking AND can provide relevant information.
Thanks.. Tom.. :slight_smile:
How to Read a pc fac Current using Arduino?
Dargoon:
A what?
Dargoon:
Was that supposed to be fan? If so, all you need to do is connect a current sensor to the Arduino, with the PC fan power line going past the current sensor.
This is NOT a programming question.
