Doing CAN bus test, the error : invalid operands of types ‘int’ and ‘void’ to binary ‘operator==’
turn out on line: if(CAN_OK == CAN.begin(CAN_500KBPS))
need help. Thanks
#include "mcp_can.h"
INT32U canId = 0x000;
#include <CAN.h>
#include <SPI.h>
#include <Canbus.h>
#include <defaults.h>
#include <global.h>
#include <mcp2515.h>
#include <mcp2515_defs.h>
//2024 4 65 12 18 248 185 147
unsigned char len = 0;
unsigned char buf[8];
char str[20];
String BuildMessage="";
int MSGIdentifier=0;
Serial.begin(38400);
START_INIT:
Serial.println("CAN BUS Shield init ok!");
Serial.println("CAN BUS Shield init fail");
Serial.println("Init CAN BUS Shield again");
delay(100);
goto START_INIT;
char rndCoolantTemp=random(1,200);
char rndRPM=random(1,55);
char rndSpeed=random(0,255);
char rndIAT=random(0,255);
char rndMAF=random(0,255);
char rndAmbientAirTemp=random(0,200);
char rndCAT1Temp=random(1,55);
//GENERAL ROUTINE
unsigned char SupportedPID[8] = {1,2,3,4,5,6,7,8};
unsigned char MilCleared[7] = {4, 65, 63, 34, 224, 185, 147};
//SENSORS
unsigned char CoolantTemp[7] = {4, 65, 5, rndCoolantTemp, 0, 185, 147};
unsigned char rpm[7] = {4, 65, 12, rndRPM, 224, 185, 147};
unsigned char vspeed[7] = {4, 65, 13, rndSpeed, 224, 185, 147};
unsigned char IATSensor[7] = {4, 65, 15, rndIAT, 0, 185, 147};
unsigned char MAFSensor[7] = {4, 65, 16, rndMAF, 0, 185, 147};
unsigned char AmbientAirTemp[7] = {4, 65, 70, rndAmbientAirTemp, 0, 185, 147};
unsigned char CAT1Temp[7] = {4, 65, 60, rndCAT1Temp, 224, 185, 147};
unsigned char CAT2Temp[7] = {4, 65, 61, rndCAT1Temp, 224, 185, 147};
unsigned char CAT3Temp[7] = {4, 65, 62, rndCAT1Temp, 224, 185, 147};
unsigned char CAT4Temp[7] = {4, 65, 63, rndCAT1Temp, 224, 185, 147};
if(CAN_MSGAVAIL == CAN.checkReceive())
CAN.readMsgBuf(&len, buf);
canId = CAN.getCanId();
Serial.print("<");Serial.print(canId);Serial.print(",");
for(int i = 0; i
BuildMessage="";
sketch_oct28a:34:36: error: invalid operands of types ‘int’ and ‘void’ to binary ‘operator==’
C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_oct28a\sketch_oct28a.ino: In function ‘void loop()’:
sketch_oct28a:74:29: error: ‘class CAN_MCP2515’ has no member named ‘checkReceive’
sketch_oct28a:77:11: error: ‘class CAN_MCP2515’ has no member named ‘readMsgBuf’
sketch_oct28a:78:21: error: ‘class CAN_MCP2515’ has no member named ‘getCanId’
sketch_oct28a:82:9: error: expected ‘;’ before ‘BuildMessage’
BuildMessage="";
sketch_oct28a:82:24: error: expected ‘)’ before ‘;’ token
Multiple libraries were found for “mcp_can.h”
BuildMessage="";
Used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\MCP_CAN_lib-master
Not used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\MCP2515_lib-master
Not used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\CAN_BUS_Shield-1.0.0
Multiple libraries were found for “SPI.h”
Used: C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11\libraries\SPI
Not used: C:\Program Files (x86)\Arduino\libraries\SPI-master
Using library MCP_CAN_lib-master in folder: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\MCP_CAN_lib-master (legacy)
Using library SPI at version 1.0 in folder: C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11\libraries\SPI
Using library CAN_Library-master at version 1.6.0 in folder: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\CAN_Library-master
Using library SparkFun_CAN-Bus_Arduino_Library-master at version 5.1.0 in folder: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\SparkFun_CAN-Bus_Arduino_Library-master
exit status 1
