Invalid signature during burning bootloader ATmega1284P
Hello,
After I bricked my 3d printer trying to install marlin software, I need to burn a bootloader into it.
So, i'm using and arduino board (uno and mega) as isp for that purpose.
I have all the wires attatched (checked about 20 times) and still have invalid signature error when burn.
Here is the completed error:
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega1284P
         Chip Erase delay              : 55000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10   128    0 no       4096    8      0  9000  9000 0xff 0xff
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0xff 0xff
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x000000 (retrying)
Error quemando bootloader
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Not always it gives 0x000000, sometimes it's 0xFF0000 with the FF in other places and it gives me this error:
avrdude: Expected signature for ATmega1284P is 1E 97 05
I've checked all and don't know what to do.
I Hope someone can help me.
Thanks in advance
You have no connection to ATmega if all zero response.
Which board or how you have connected 1284P?
Budvar10:
Sorry for not answering, I was trying things, the problem its solved.
For any one with same problem:
First of all check your connections, most of times the problem is there.
Then check the isp you loaded on arduino, in my case I had to define use_old_connections or something like that for programming via normal arduino pins, if you dont that you'll have to change it to icsp pins in your board. Hope I can help anyone
