invalid suffix "D" on integer constant
Hello All , have this problem, sw compiles then at the end shows this error ?
Any Had this before ?
This was written for ver 0022 , just upgrade client to ethernet client same with server.
tried running this in ver 0022 still same “D” Problem ?
Help still learning.
#include <SPI.h>
#include <Ethernet.h>
byte mac = { 1A-2B-3C-4D-5E-6F };
byte ip = { 10 ,1 ,1 ,9 };
byte gateway = { 198 ,168 ,1 ,1 };
byte subnet = { 255 ,255 ,255 ,0 };
EthernetServer server(80);
String readString = String(30);
void setup(){
Ethernet.begin(mac, ip, gateway, subnet);
pinMode(5, OUTPUT);
digitalWrite(5, LOW);
void loop(){
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (readString.length() < 30)
readString = readString + c;
if (c == ‘\n’) {
Serial.print(readString);
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println();
if(readString.startsWith(“GET /?out=5&status=1”))
{Serial.print("\n 5 HIGH LOW \n");
digitalWrite(5, HIGH);
delay(100);
client.print("{“status” : “1” , “out” : “”);
client.print(5);
client.print(""}");
if(readString.startsWith(“GET /?out=all”))
Serial.print("\n OUT ALL\n");
client.print("{“ip” : “10.1.1.9”, “);
client.print(”“devices” : “);
client.print(”[{ “type” : “door”, “name” : “OPENING ROOF”, “out” : “”);
client.print(“5”);
client.print(""}");
client.print("]}");
readString="";
client.stop();
I would think it is something to to with this line...
byte mac[] = { 1A-2B-3C-4D-5E-6F };
The reference page for the ethernet begin() call shows this...
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
dxw00d: I would think it is something to to with this line...
Thank you, as well al know the problem can be looking you right in the face sometimes. that you for your assistance.
