My bad here is the full code:
#include <AFMotor.h> // AFMotor Library https://learn.adafruit.com/adafruit-motor-shield/library-install
#include <NewPing.h> // NewPing Library https://github.com/livetronic/Arduino-NewPing
#include <Servo.h>// Servo Library https://github.com/arduino-libraries/Servo.git
#include "pitches.h"
#define TRIG_PIN A0
#define ECHO_PIN A1
#define MAX_DISTANCE 200
#define MAX_SPEED 150
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
Servo myservo;
boolean goesForward = false;
int distance = 100;
int speedSet = 0;
int melody[] = {NOTE_C4, NOTE_G3, NOTE_A3, NOTE_G3, 0 , NOTE_B3, NOTE_C4};
int noteDurations[] = {4, 8, 8, 4, 4, 4, 4, 4};
int pirSensor = 2;
myservo.attach(10);
myservo.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
pinMode(pirSensor, INPUT);
int distanceR = 0;
int distanceL = 0;
int pirState = digitalRead(pirSensor);
delay(40);
if (distance <= 15)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
else if (pirState == 1) {
for (int thisNote = 0; thisNote < 13; thisNote++) {
int noteDuration = 1000 / noteDuration [thisNote];
tone(13, melody [thisNote], noteDuration);
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
noTone(13);
if (distanceR >= distanceL)
turnRight();
moveStop();
} else
turnLeft();
moveStop();
moveForward();
int lookRight()
myservo.write(50);
int distance = readPing();
delay(100);
myservo.write(115);
return distance;
int lookLeft()
myservo.write(170);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if (cm == 0)
cm = 250;
return cm;
void moveStop() {
motor1.run(RELEASE);
motor2.run(RELEASE);
void moveForward() {
if (!goesForward)
goesForward = true;
motor1.run(FORWARD);
motor2.run(FORWARD);
for (speedSet = 0; speedSet < MAX_SPEED; speedSet += 2)
motor1.setSpeed(speedSet);
motor2.setSpeed(speedSet);
delay(5);
void moveBackward() {
motor1.run(BACKWARD);
motor2.run(BACKWARD);
delay(5);
void turnRight() {
delay(450);
void turnLeft() {
delay(450);
