Invalid Use Of custom library class function
Hello everyone! I'm working on making my first library. It's called TimerON, and it mimics the behavior of a Rockwell PLC TON instruction. Anyways, here's the source files:
Header File
#ifndef TimerON_h
#define TimerON_h
#include "Arduino.h"
class TimerON
public:
 TimerON(unsigned long preset_millisecond, unsigned long inputcurrentMillis);
 bool EnableIn = 0;
 unsigned long Accumulated = 0;
 bool Done = 0;
 bool Timing = 0;
 void Reset();
private:
 bool EnableInMemory = 0;
 unsigned long enableStartMillis = 0;
#endif
CPP File
#include "TimerON.h"
TimerON::TimerON(unsigned long preset_millisecond, unsigned long inputcurrentMillis)
  // If the timer is not enabled, clear the Done bit
  if(!EnableIn) {
    Done = 0;
  // If the timer is being enabled for the first time now, set the starting Millis
  if(EnableInMemory == 0 && EnableIn == 1) {
    enableStartMillis = inputcurrentMillis;
  // Remember previous scan's EnableIn value
  EnableInMemory = EnableIn;
  // If the timer is enabled, and not done, calculate the accumulated millis and set the Timing bit
  if(EnableIn && !Done) {
    Accumulated = inputcurrentMillis - enableStartMillis;
    Timing = 1;
  if(Accumulated >= preset_millisecond) {
    Done = 1;
    Timing = 0;
void TimerON::Reset()
	Done = 0;
	Timing = 0;
	EnableInMemory = 0;
My Program
#include <TimerON.h>
unsigned long currentMillis = 0;
TimerON DelayStart(0,0);
  DelayStart.EnableIn = 1;
  currentMillis = millis();
  DelayStart.TimerON(3000,currentMillis);
My Error Message
Arduino: 1.8.9 (Windows 7), Board: "Adafruit Feather M0, Arduino, Off"
C:\Users\nbutler\Documents\Arduino\CB\CB.ino: In function 'void loop()':
CB:12:14: error: invalid use of 'TimerON::TimerON'
exit status 1
I have no idea why this isn't working. Any help is really appreciated.
Thanks!
What is DelayStart ?
I cannot see an object of that name.
What did I miss ?
TimerOn() is a constructor. Constructor is called when the object is created.
Either set your variables when you create the object or create a new public method to set those variables.
DelayStart is an instance of TimerON, created before setup(). I was foolishly trying to have my constructor function also be the function that does work and requires inputs. So, I was trying to define DelayStart like this:
I separated those two things so there's now an instance of TimerON that is created first, and then a function defined within that instance called Run() that takes those two millisecond time inputs and executes the timer logic.
Header File
#ifndef TimerON_h
#define TimerON_h
class TimerON
public:
 TimerON();
 void Run(unsigned long preset_millisecond, unsigned long inputcurrentMillis);
 bool EnableIn = 0;
 bool Done = 0;
 bool Timing = 0;
 void Reset();
private:
#endif
CPP File
TimerON::TimerON()
 Done = 0;
 Timing = 0;
 EnableInMemory = 0;
void TimerON::Run(unsigned long preset_millisecond, unsigned long inputcurrentMillis) {
  if(!EnableIn) {
    Done = 0;
    Timing = 1;
    Done = 1;
    Timing = 0;
My Program
TimerON DelayStart;
  DelayStart.Run(3000,currentMillis);
This compiles just fine, though I can't test it right now. Does this look ok?
