invalid use of member (did you forget the '&'?)
For the life of me I can't figure out why this sketch will not compile.
I'm sure the problem is in these lines.
int time();
or
time = ((now.hour * 60) + now.second);
When verifying sketch I get the error, "invalid use of member (did youforget the '&'?)
Any help would be great. Thanks!
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
int time();
void setup () {
    Wire.begin();
    RTC.begin();
  //if (! RTC.isrunning())
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    RTC.adjust(DateTime(__DATE__, __TIME__));
void loop () {
    DateTime now = RTC.now();
    if(now.hour = 0){                              //0th hour
      if((3450 <= time < 3549)||(0 <= time < 150)){
        Serial.println("TWELVE O'CLOCK");
      if(150 <= time < 450){
        Serial.println("FIVE PAST TWELVE");
      if(450 <= time < 750){
        Serial.println("TEN PAST TWELVE");
      if(750 <= time < 1050){
        Serial.println("QUARTER PAST TWELVE");
      if(1050 <= time < 1350){
        Serial.println("TWENTY PAST TWELVE");
      if(1350 <= time < 1650){
        Serial.println("TWENTY FIVE PAST TWELVE");
      if(1650 <= time < 1950){
        Serial.println("HALF PAST TWELVE");
      if(1950 <= time < 2250){
        Serial.println("TWENTY FIVE 'TILL TWELVE");
      if(2250 <= time < 2550){
        Serial.println("TWENTY 'TILL TWELVE");
      if(2550 <= time < 2850){
        Serial.println("QUARTER 'TILL TWELVE")
      if(2850 <= time < 3150){
        Serial.println("TEN 'TILL TWELVE");
      if(3150 <= time < 3450){
        Serial.println("FIVE 'TILL TWELVE");
Is time supposed to be a number? If so, lose the parentheses in the
int time();
line
The parentheses mean that time is a function, which I don't think you want.
EDIT:
also, this line (and similar) won't do what you want
You need to be explicit and say
if (150 <= time && time < 450) {
You're right.
time is supposed to be a number. I made the changes you suggested, however, I am still getting the same error on the line
Thanks again.
the hour and second method of DateTime are functions, so you need parentheses there.
time = ((now.hour() * 60) + now.second());
The primary syntactical difference between a function and a variable is the argument list (which is empty here)
