invalid use of void expression when trying to use timer library
Hi there Arduino Forumites!
I’m trying to get my first Arduino project together, itś a defusable fake bomb to use on my local airsoft field, and naturaly I need some sorts of timers for a bunch of things, so Iḿ using the timer library by Simon Monk, but I can quite get it to work, so some helt would be much apreciated!
I have managed to get a led to blink when the bomb is armed, but I can’t figure out how to use after to set a countdown to detonation.
I have created a function called detonate that is supposed to be called after X (entered by user) time has passed, but Iḿ doing something wrong when Iḿ calling the function (I think) since I get the invalid use of void expression message when compiling for this line:
t.after(detonationMilli, detonation());
and this is the function:
void detonation(){
digitalWrite(buzzer,HIGH);
delay(10000);
digitalWrite(buzzer,LOW);
(I know I shouldn’t use delay in the same sketch as timer, but I was using pulse, and thought that might be the problem, so I changed it to a delay, but with the same results.
Sketch is attached below!
KeypadAndLCDTest.ino (4.86 KB)
Don’t try to use the value a void function doesn’t return.
Could you elaborate?
This calls detonation() first, then tries to pass the value it returns (which is void, i.e. no value) to t.after().
This will pass the function to t.after():
 t.after(detonationMilli, detonation);
Thanks you for your reply!
I tried that before though and got the following message as a result:
KeypadAndLCDTest.ino: In function ‘void setup()’:
KeypadAndLCDTest.ino:127:36: error: no matching function for call to ‘Timer::after(long int&, void (&)())’
In file included from KeypadAndLCDTest.ino:2:0:
/home/pi/sketchbook/libraries/timer2_1/Timer.h:42:10: note: candidate: int8_t Timer::after(long unsigned int, void ()(void), void*)
int8_t after(unsigned long duration, void (callback)(void), void* context);
/home/pi/sketchbook/libraries/timer2_1/Timer.h:42:10: note: candidate expects 3 arguments, 2 provided
That looks pretty clear.
If only I could see your code. {sigh}
Well, Iḿ a beginner at this and programming in general, so for me itś not clear at all, so I would be very greatful if you could explain it to me!
I attached the code in the original post but I’ll paste it here to:
#include <Event.h>
#include <Timer.h>
#include <Keypad.h>
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR 0x27
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
String password=("");
String number;
String detonationTime=("");
long detonationMilli;
Timer t;
long PERIOD1 = 100;
#define ledpin 13
int buzzer=2;
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
{‘1’,‘2’,‘3’},
{‘4’,‘5’,‘6’},
{‘7’,‘8’,‘9’},
{’*’,‘0’,’#’}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };
// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 12, 11, 10 };
// Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
pinMode(ledpin,OUTPUT);
t.oscillate(ledpin, PERIOD1, HIGH);
digitalWrite(ledpin, HIGH);
lcd.begin (16,2);
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.clear (); // go home
// Menu
lcd.print(“Enter new code:”);
while (number.length() < 10)
lcd.setCursor (0,1);
char key = kpd.getKey();
if(key) // Check for a valid key.
switch (key)
case ‘*’:
digitalWrite(ledpin, LOW);
case ‘#’:
default:
number=number+key;
lcd.print(number);
lcd.clear();
lcd.print(“New code set:”);
lcd.print(number);
delay(5000);
lcd.clear();
lcd.print(“Detonation time:”);
bool myBool=true;
while (myBool)
switch (key)
case '’:
detonationMilli = detonationTime.toInt();
detonationMilli = detonationMilli
1000;
myBool=false;
case ‘#’:
detonationMilli = detonationMilli*1000;
myBool=false;
default:
detonationTime=detonationTime+key;
lcd.print(detonationTime);
password=("");
lcd.clear();
lcd.setCursor (1, 0);
lcd.print(“Enter code to”);
lcd.setCursor (1, 1);
lcd.print(“detonate bomb”);
while (password != number)
switch (key)
case ‘*’:
case ‘#’:
default:
Serial.println(key);
password=password+key;
lcd.clear();
lcd.print(password);
if (password.length() > 9 && password != number)
password=("");
lcd.clear();
lcd.setCursor(1, 0);
lcd.print(“Incorrect code”);
delay(3000);
lcd.clear();
continue;
if(password == number)
detonationTimer.update();
password=("");
lcd.clear();
lcd.print(“Detonation in:”);
lcd.setCursor(0, 1);
lcd.print(detonationMilli);
t.update();
switch (key)
case ‘*’:
case ‘#’:
default:
lcd.clear();
password=("");
lcd.clear();
delay(3000);
lcd.clear();
continue;
if (password == number)
lcd.clear();
lcd.setCursor (4, 0);
lcd.print(“Bomb has”);
lcd.setCursor (2, 1);
lcd.print(“been defused”);
delay(10000);
void detonation(){
delay(10000);
The library comes with examples, I assume.
Play "spot-the-difference" with examples' callbacks and yours.
And please, remember to use code tags when posting code.
I went trough all the examples backwards and forward and googled my ass off for 2 days before posting here, but I just managed to solve it by adding NULL when I call the function, and (void* context) to the function. Don't know why is works but it does.
Because this 42:10: note:  candidate expects 3 arguments, 2 provided
