Inverse kinematics -matlab to arduino
i have inverse kinematics equations in matlab code for a robot arm , how could i send them to arduino , is it even possible? 1
Via Serial.
Not sure what good it would do you.
What are you trying to achieve?
That would depend a lot on how the Arduino controls the robot arm.
control the robot arm with the arduino board
by entering a certain position in xyz space to arduino
then arduino should solve the required angles for this position
And have you written a MATLAB translator for Arduino?
If not, what efforts have you made to translate the MATLAB equations to C++?
I have no idea about MATLAB translator but it's not hard to translate the MATLAB code to c++
If I did so what is the next step
Then you don't need a computer running Matlab.
Yep
Arduino is programmed in C/C++, which you can have Matlab produce. It is available as an add-on.
so , if i have a c/c++ code , could i enter it for arduino ? how
In the Arduino IDE, chose menu option file>new and enter your code in the bodies of the setup() and loop() functions.
The IDE comes with a bunch of examples for you to study.
i didn't mean that
my question is how could i write arduino code in pure c/c++
Arduino code IS pure C/C++.
sure?
Yep.
ok thank you man
