inverse trig functions
Is there a short hand way in C to return the inverse sine and cosine values for an input variable? i have found how to use the EEFROM library to display averaged values for the time derivative of data collected by sensors but im thinking if i need to do something similar to get a taylor series approximation to the inverse trig i would feel more comfortable with more than 512 slots. does the ether-mega have more than 512? ive lost the papers it came with.
void setup( void )
void loop( void )
  asin( 0.0 );
  acos( 0.0 );
void setup ()
  Serial.begin (115200);
  Serial.println (asin (1), 6);
  }  // end of setup
void loop () { }
Output:
  1.570796
Thanks very much appreciated guys!!
Storing values in EEPROM could cause problems if you do it too often because there is a limit as to how many times you can reliably write to an EEPROM location. How frequently are the values stored and over what period ?
