Using SPWM and components below, can someone tell me the max power my 3phase inverter can handle?
The mosfets i want use says max 8A current, but i think means Iavg. And i trying find the max HP motor my inverter will handle..
You are using MOSFETs, not IGBTs - that's really going to be an issue at those voltages
as MOSFETs are more fragile. If you haven't built power bridges before expect to
blow things up a lot.
The IRF840 is an n-MOSFET, not a p-MOSFET - did you mean "power MOSFET"?
You are using old devices with a whopping great 800 milliohm on resistance,
look for something better, 100milliohms is findable at that voltage rating.
Losses may be dominated by switching time, you haven't said anything about
your driver circuits.
You will need at least 800V devices for a 230Vac input.
DC bus voltage = 230 * 1.414 = 325Vdc
When you develop the 3phase you will need more than twice that Vds.
In practice 800V is a minimum for 230Vac
Usually it is 1000V and an IGBT bridge package as Lafred has posted.
I just cant calculate max power can handle.
The 8A on datasheet are AVG not Rms.
IGBTs usually come in 600V breakdown and 1200V breakdown. The 600V breakdown
ones are good for normal mains (single and 3-phase), 1200V used for higher
voltage industrial use. You'd never expose a 600V device to anything like 600V
in normal operation BTW.
As I said with high voltages IGBTs are much more robust than MOSFETs and
that's why you never see MOSFETs being used at high voltages any more
commercially, even though they perform better. The fixed forward voltage
of IGBTs and the slower siwtching means they have higher losses, but ruggedness
is more important in the real world.
( with 16 MHz Oscilator that the only frequency i can have >20kHz... cause i need
3 PWM signals on Phase Correct mode and with mega32 i have many limits..)
Something last, since i can have V/F control by software. I could still run the cheap motor
but with lower torque/speed right (that fackin 1phase input for inverter is realy confusing me,
but thats the only voltage i can have on home);
SPecs:
Power : 0,25 hp
RPM : 1500 rpm/min
Volt : 380 V 3-phase
Going with MOSFET's you'll need to learn about ways to protect against dV/dt and dI/dt
failure modes, and in general be spending more of your design on protection circuitry.
Power is Vrms x Irms, times 3 for 3 phases. With MOSFETs normally the limit is the
device dissipation. IGBT's have a harder upper limit for current I believe.
