inverter with due arduino board
I want to use the DUE board to drive a full bridge inverter. for do it I need 4 pwm pulses with 1 khz frequency that The pulse width can be changed to drive 4 IGBT switch. I've already made an IGBT driver!
board.
How can I produce these pulses with high accuracy?Can anyone provide me the code to generate it with the timer?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Can you tell us your electronics, programming, arduino, hardware experience?
Tom..... :slight_smile:
To output a PWM signal, you can use pwm_lib or tc_lib from antodom, or/and search for PWM example sketches in the DUE sub forum.
